10-26-2010, 22:24 | #47 (permalink) |
No Life Poster Join Date: Mar 2007 Location: ALGERIA Age: 17
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | HI BRO for more information how using mcnbox with all fonction pinot detection flash unlock with diffrent cpus and diffrent familly read the faq http://forum.gsmhosting.com/vbb/f532...2010-a-773075/ for spd cpu http://forum.gsmhosting.com/vbb/f532...ro-box-762428/ http://forum.gsmhosting.com/vbb/f532...o-box-1050768/ http://forum.gsmhosting.com/vbb/f532...ro-box-778648/ any problem dont hesitate just post log |
The Following User Says Thank You to MDK23 For This Useful Post: |
10-27-2010, 11:26 | #49 (permalink) |
Product Manager Join Date: Mar 2008
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Check here : http://forum.gsmhosting.com/vbb/f532...2010-a-773075/ Any question please post here ! Mcnbox |
10-27-2010, 12:08 | #50 (permalink) |
No Life Poster Join Date: Oct 2009 Location: love me if you can
Member: 1150088 Status: Offline Sonork: ============ Thanks Meter: 254 | MTK 6223 cannot reply sms solved Welcome to use McnBox! Selected COM3 COM9 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCNXXXXXXXXXXX Firmware V1.08 Checksum 79C1-59BE Box Connected! Ready working at COM3 [V:11 G:2 6 R:7 T:8] Apply to Box! ------------------------------- Selected COM3 COM9 Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6223 Ver: 8A05 SW:8A00 CPU ID: C4670C00 Please select Boot5 Initialize Boot4 ... Flash(Nor) Type: [SPANSION] S71PL127N Flash(Nor) Code: 0001227E(22202200) Flash(Nor) Size: 0x01000000 Hex Bytes Checking baudĄ* Set Baud:921600 Done. Start Reading(Nor)... The phone information: MIKI23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.MAUI_09A _W09_36_MP_V9.BIN Read Done ! Time used: 4 mins13 s File Saved: E:\Firmware China & Software\File\Cross\CB 80\MIKI23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.MAUI_ 09A_W09_36_MP_V9.BIN Press and Holding Power button now ! Connecting, wait... CPU: 6223 Ver: 8A05 CPUID: C4670C00 Release Power Button now Phone detected Safe Mode Format starting... FFS Format Done Press and Holding Power button now ! Connecting, wait... CPU: 6223 Ver: 8A05 CPUID: C4670C00 Release Power Button now Phone detected Safe Mode Format starting... FFS Format Done Big thank to MCN team ps : fix to flashing infinion brother Br hacell |
10-27-2010, 12:58 | #51 (permalink) |
No Life Poster Join Date: May 2007 Location: Badui My home
Member: 508048 Status: Offline Thanks Meter: 123 | asked WHY ....??? "LOW Baudrate" I AM OFTEN ONCE find HANDPHONE FLASHING ON CHINA NORMAL CONDITION .... HP ..... IF I FLASH USING BACKUP FILE FROM HP HIS OWN SUCCESS IS .. BUT WHEN WE TRY TO FLASH By FIRMWARE DOWNLOAD FROM WHICH WE CAN STOP WHEN FLASHING .. sometimes PROCESS ... AND WARNINGS "LOW baudrate "...... notes: 1.setting MADE same baudrate 2. file size same ; ; ; whether because of the firmware that we can download it mmg is BROKEN or indeed influence baudrate setting ... ARE NOT THE SAME cause appears warning "LOW Baudrate" any body,,,,anyone can explain it |
10-27-2010, 13:46 | #52 (permalink) | |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Quote:
A.) Flash with backup file without problem B.) Flash other file which download from somewhere have problem ,Eg, "LOW baudrate" Correct me if i am wrong ! PS: I had explain before , Sometime a bin file have same name/version, so customer consider which can using for same phone, this is total wrong, due to flash IC are different(and some others) , which mean's even File have same name or same version or same size but which not for same model phone ! (This becos some engineer(factory) forget or laze (or somehow) to change the name(version). Best regards ! Mcnbox | |
The Following User Says Thank You to Mcnbox For This Useful Post: |
10-27-2010, 14:44 | #53 (permalink) |
Member: 1150088 Status: Offline Sonork: ============ Thanks Meter: 254 | Cros CB 80 can't call and sms solved Welcome to use McnBox! Selected COM3 COM9 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCNXXXXXXXXXX Firmware V1.08 Checksum 79C1-59BE Box Connected! Ready working at COM3 ------------------------------- Start Scanning... -> Results: MTK Chipset CPU: MT6223. GND:1 9,RXD:5,TXD:6 [G:1 9 R:5 T:6] Apply to Box Phone detected, wait.. CPU: 6223 Ver: 8A05 SW:8A00 CPU ID: 0B550C00 Please select Boot5 Initialize Boot4 ... Flash(Nor) Type: [SPANSION] S71PL127N Flash(Nor) Code: 0001227E(22202200) Flash(Nor) Size: 0x01000000 Hex Bytes Checking baudĄ* Set Baud:921600 Done. Start Reading(Nor)... The phone information: MIKI23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.MAUI_09A _W09_36_MP_V9.BIN Read Done ! Time used: 4 mins17 s 2nd method, please turn off the phone before rd/wr Press and Holding Power button now ! Connecting, wait... CPU: 6223 Ver: 8A05 CPUID: 0B550C00 Release Power Button now Phone detected Wr IMEI1 Done: 35210610858454-0 Just read and backup. after that write imei Br hacell |
10-27-2010, 14:58 | #54 (permalink) |
Member: 508048 Status: Offline Thanks Meter: 123 | before I say many thanks to the MCN team is very responsive to the user box MCN yes a very clear explanation .. I understand a little now .. and how to overcome this, whether to be with the backup file from the sam phone or any other way, I often encounter in nexian g923 hp g722 n,, and its the same kind of flash chip it regard Roezt |
10-27-2010, 16:53 | #55 (permalink) | |
For chinese mobile phone , you have to made full backup before you try to flash etc. Sure ,if you can ensure 2 phones which 100% same , you can flash the file for each other, otherwise finally only destroy the phone. Best Regards ! Mcnbox | |
10-27-2010, 17:36 | #56 (permalink) |
Member: 1150088 Status: Offline Sonork: ============ Thanks Meter: 254 | K touch H899 dead solved with reflas from file flash read by new handset Welcome to use McnBox! Selected COM3 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCNXXXXXXXXXXX Firmware V1.08 Checksum 79C1-59BE Box Connected! Ready working at COM3 ------------------------------- Start Scanning... -> Results: MTK Chipset CPU: MT6225. GND:5,RXD:3,TXD:2 [G:5 R:3 T:2] Apply to Box Press and Holding Power button now ! Connecting, wait... User Abort [G:5 R:3 T:2] Apply to Box Welcome to use McnBox! Selected COM3 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCNXXXXXXXXX Firmware V1.08 Checksum 79C1-59BE Box Connected! Ready working at COM3 [G:5 R:3 T:2] Apply to Box Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6225 Ver: 8A05 SW:8A00 CPU ID: 03A30F00 Initialize Boot4 ... Flash(Nor) Type: [TOSHIBA] TV00570002CDGB, TC58FVM7TDD Flash(Nor) Code: 00980003(00000000) Flash(Nor) Size: 0x01000000 Hex Bytes Checking baudĄ* Set Baud:921600 Done. Start Reading(Nor)... The phone information: TBG125621_6511_PCB01_GPRS_MT6225_S00.125621_6511_V 1402.BIN Read Done ! Time used: 4 mins17 s File Saved: E:\Firmware China & Software\File\K-touch\K touch H 899\TBG125621_6511_PCB01_GPRS_MT6225_S00.125621_65 11_V1402.BIN Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6225 Ver: 8A05 SW:8A00 CPU ID: 03A30F00 Initialize Boot4 ... Flash(Nor) Type: [TOSHIBA] TV00570002CDGB, TC58FVM7TDD Flash(Nor) Code: 00980003(00000000) Flash(Nor) Size: 0x01000000 Hex Bytes Start Formatting (Nor)... Start Addr: 0xE00000, Size: 0x200000 Format Done ! After format handset still same dead, try to reflash with file read but eror ..i sure file flash from backup is damaged. Serial No. MCNXXXXXXXXXXX Firmware V1.08 Checksum 79C1-59BE Box Connected! Ready working at COM3 [G:5 R:3 T:2] Apply to Box Checking data Ą* wait Verification incorrect , don ' t flash to phone Try backup from handset same and reflash to handset Serial No. MCNXXXXXXXXXXX Firmware V1.08 Checksum 79C1-59BE Box Connected! Ready working at COM3 [G:5 R:3 T:2] Apply to Box The File Information: TBG125621_6511_PCB01_GPRS_MT6225_S00.125621_6511_V 1402.BIN >> Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6225 Ver: 8A05 SW:8A00 CPU ID: 03A30F00 Initialize Boot4 ... Flash(Nor) Type: [TOSHIBA] TV00570002CDGB, TC58FVM7TDD Flash(Nor) Code: 00980003(00000000) Flash(Nor) Size: 0x01000000 Hex Bytes Checking baudĄ* Set Baud:921600 Done. Start Writing(Nor)... Write Done ! Handset okay and problem solved again Br hacell |
10-27-2010, 18:31 | #57 (permalink) | |
Member: 508048 Status: Offline Thanks Meter: 123 | Quote:
but what if the read of the case the same error sometimes, and the results of his errors when flashing the normal case, it has been several times I do just to prove .. What do I wrong or how br | |
10-29-2010, 10:05 | #59 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 910239 Status: Offline Thanks Meter: 23 | Nckia E98 China hi team, i do have this Nckia E98 double sims with lock code. i tried to find out the pin out for this phone but didn't pick up any thing. please help to find out the pinout and solve the lock code. thanks. |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
