Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnPro Box
Old 11-24-2010, 10:57   #16 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Originally Posted by hacell View Post
I have chines phones sim 2 (CDMA) can not be used. What is MCN can repair this handset ? how?
for information this handset use MTK 6225...for GSM can use but for CDMA can't use. If try insert card in handset information Power on CDMA
Maybe MCN team can solved this problem...After format stiil same
hacell
Try to using box scan CDMA pinout ,and do format
The Following User Says Thank You to Mcnbox For This Useful Post:
Old 11-25-2010, 05:19   #17 (permalink)
hacell's Avatar
Member: 1150088
Sonork: ============
Thanks Meter: 254
Don't connect sir.....maybe have file flash
UNISCOPE25_GEMINI_PCB01_GPRS_MT6225_S00.U25GEMINI_ V08B31.BIN
Big thank you
br
hacell
Old 11-25-2010, 12:16   #18 (permalink)
Member: 1322918
Sonork: afagsn
Thanks Meter: 2
skip screen calibration
can MCN Pro skip screen calibration now or not yet???
Old 11-25-2010, 12:33   #19 (permalink)
Member: 1322918
Sonork: afagsn
Thanks Meter: 2
My mean is how skip screen calibration if touchscreen damage.
Old 11-25-2010, 16:28   #20 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
First i suggest you which you have to take a little time read our section prior/old Thread regarding the issue !
Sure, you have using backup/write LCD data function to skip this
Old 12-02-2010, 14:59   #21 (permalink)
gulka's Avatar
Member: 276322
Thanks Meter: 293
V158 or TDS-12-1
HI
Possible to flash and unlock this model?
Start Scanning...
Results:
CPU:7880
VCC:6,GND:5,RXD:3,TXD:2
[V:6 G:5 R:3 T:2] Apply to Box
Connecting...
 Press Power button now !
Connected OK
Initialize boot...
Load boot OK
BaudRate : 921600 OK.
Send data to phone...
Flash   ID: 007F22C4
If the Flash Size judgement is inaccurate,Please manually set the size
The Following 2 Users Say Thank You to gulka For This Useful Post:
Old 12-02-2010, 17:42   #22 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Backup first , then flash , post reslut here !
Best regards!
Mcnbox
Old 12-02-2010, 22:00   #23 (permalink)
Member: 534960
Thanks Meter: 3
mcnpro help!!!!
i format this phone and the display just white out now. here is the logs
Welcome to use McnBox!
Selected COM51
Baud setting ...
Set Baud done
Initialize in progress ...
Checking data ...
Serial No. ************
Firmware V1.08
Checksum AD17-8FBE
Box Connected!
Ready working at COM51
Start Scanning...
User Abort
Pinout has been cleared
Start Scanning...
User Abort
Start Scanning...
Results:
SPD Chipset
VCC:14,GND:4,RXD:8,TXD:6,BOOT:10
[V:14 G:4 10 R:8 T:6] Apply to Box
Analyzer CPU ID...
CPU ID: 6600D050
Connecting, wait...
Port error, Occupied or non-exist!
Press and Holding Power button now !
Start Scanning...
Can't Identify chipset,Please scan again
Start Scanning...
Results:
SPD Chipset
Connecting, wait...
Phone Connected!
Info: Spreadtrum Boot Block version 2.0
Initialize boot...
CPU Info 6600D
Flash Type NOR
Flash ID 00EC257E(25082501)
Flash Model K5L2931CAM
Flash Size 0x1000000(16.0M)
Start Formatting,Wait...
Start Addr:F20000 Size:C0000
Format Done.
Start Scanning...
Results:
SPD Chipset
Connecting, wait...
Phone Connected!
Initialize boot...
CPU Info 6600D
Flash Type NOR
Start Reading...
Read Done!
Saved Path:C:\Documents and Settings\Owner\My Documents\coco
Connecting, wait...
User Abort
Start Scanning...
Results:
SPD Chipset
Connecting, wait...
Phone Connected!
Initialize boot...
CPU Info 6600D
Flash Type NOR
Format Done.
The Following User Says Thank You to sammy1985 For This Useful Post:
Old 12-02-2010, 22:22   #24 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
What's the condition of your phone before format, this is my first time heared about 6600D after format get white screen issue !
Best regards !
Mcnbox
Old 12-03-2010, 04:23   #25 (permalink)
nanoy's Avatar
Member: 724814
Thanks Meter: 94
at 3:01 version .... nv backup data takes 8 minutes
previous version takes very long ...
thanks MCNteam
Old 12-06-2010, 16:26   #26 (permalink)
Member: 1402040
opinion of a box MCNpro user
After buying a Mcnpro and all the cables (350 USD approx), after losing considerable time on several forums (more than three weeks), after contacting the 7/24h and leave several messages, here I am obliged to summon help for a product I bought and which is delivered without any notice (in any language).
Mcnpro Version 3.01
1) Windows 7 does not recognize my MCNpro (Vista installed drivers several times)
2) Two phones are supported. (MTK 6235)
With Chinari Editor:
- For a phone, opening the file "bin" only visible language, English.
For the other phone, no language appears.
3) Two phones are not supported (MTK 6235 Fliyng F073 and XYH001 6223DA MTK)
Hoping that this is not my naivety (I read the description of this product that all MTK was supported Compatible with Windows 7, ... etc.) that pushed me to buy this product, thank you advance for all the support you can give me.
Old 12-07-2010, 11:48   #27 (permalink)
Member: 105314
Sonork: 100.102361
Thanks Meter: 7
Mcnpro Version 3.01
Windows 7 Working for me perfect , i did not see anything wrong , i have attach a photo
The Following 2 Users Say Thank You to asiagary For This Useful Post:
Old 12-07-2010, 12:24   #28 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
@mich00
Win7 should be working fine without any problem , as we can see above photo from gary ,I don't know why dont working for you ! Please double check !
For editor , this we are still working around, BTW, we are the first of world support MT6235 and MT6253 in Editor. Can you upload those file somewhere , i will taking a look that for sure !
I am very interesting if you can post the logs detail here ! and the phone photos etc.
Thanks!
Best regards !
Mcnbox
Old 12-07-2010, 12:34   #29 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
thanks MCNteam
Nv data which special for MT6253, well, working for all MTK phones.
Due some of MT6253 phone very strange, after format some time will be lose signal or IMEI and so on , so we are high recommend all the Mcnpro Box user before you format Mt6253 Phone , You 'd better Backup Nvdata to be safety.
This one of solution for this moment , seems other related box did not support this
All the best !
Mcnbox
Old 12-07-2010, 13:22   #30 (permalink)
hacell's Avatar
Member: 1150088
Thanks Meter: 254
About CDMA qulacom MCN pro box can read tx rx but cannot to read and backup maybe in new isntaller can to repair qualcom CDMA like haier, nexian model C 951 and ETC
hacell
The Following User Says Thank You to hacell For This Useful Post:
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.25697 seconds with 9 queries
