03-23-2011, 09:59 | #16 (permalink) |
Freak Poster Join Date: Mar 2011
Member: 1536420 Status: Offline Thanks Meter: 42 | factory set spd success SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810 Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Check firmware,Wait... Analyzed Completed. Factory Setting... Done. |
The Following User Says Thank You to ranen telecom For This Useful Post: |
03-23-2011, 10:19 | #17 (permalink) |
Member: 1536420 Status: Offline Thanks Meter: 42 | write flash file to spd ok Welcome to use McnBox! Selected COM21 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN******* Firmware V1.09 Checksum ****-**** Box Connected! Ready working at COM21 Scanning pin status,please waiting... ->........................ Pin-status Scan Done Scanning,waiting... ->@@ Operation done, Pin detect out. BOOTŁ؛2 3 4 5 10 11 12 USB D-: 7 USB D+: 8 Spread Press [ Save ] to save Pinout Total expend 1 seconds ... ->#........... ... Press [ Save ] to save Pinout [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box If Scan other phone, please click [Stop] [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Not support,Please Try other boot. Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810(FFFFFFFF) Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Start Writing... Write Done! |
03-23-2011, 10:36 | #18 (permalink) |
Member: 1536420 Status: Offline Thanks Meter: 42 | format spd ok Welcome to use McnBox! Selected COM21 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN********* Firmware V1.09 Checksum ********* Box Connected! Ready working at COM21 Scanning pin status,please waiting... ->........................ Pin-status Scan Done Scanning,waiting... ->@@ Operation done, Pin detect out. BOOTŁ؛2 3 4 5 10 11 12 USB D-: 7 USB D+: 8 Spread Press [ Save ] to save Pinout Total expend 1 seconds ... ->#........... ... Press [ Save ] to save Pinout [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box If Scan other phone, please click [Stop] [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Not support,Please Try other boot. Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810(FFFFFFFF) Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Start Writing... Write Done! [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box Boot Not support. Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810 Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Check firmware,Wait... Analyzed Completed. Factory Setting... Done. Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810 Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Start Writing... Write Done! Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Reapply Pinouts to Box or Pwr on/off [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810 Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Check firmware,Wait... Analyzed Completed. Factory Setting... Done. Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810 Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Start Writing... Write Done! Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Reapply Pinouts to Box or Pwr on/off [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810 Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Check firmware,Wait... Done.. Start Formatting,Wait... Start Addr:7A0000 Size:40000 Format Done. |
03-23-2011, 10:46 | #19 (permalink) | |
Member: 1536420 Status: Offline Thanks Meter: 42 | to mcn Quote:
all opration whith mcn box cpu spd read , write , format , unlock , set imei direct and factory set work whith me ok without press any button ************************** **************************** but there is asmall bug whith factory set after factory set phone dead not work but problem sloved by write backup flash file *************************** after phone work itest format button safe 100/100 phone not dead ********************** ***************** please mcn pro fix this bug thankyou again mcnproteam | |
03-23-2011, 11:10 | #20 (permalink) | |
Product Manager Join Date: Mar 2008
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Quote:
thanks for reprot this bugs, will double check then | |
The Following User Says Thank You to Mcnbox For This Useful Post: |
03-23-2011, 15:31 | #23 (permalink) |
Member: 1536420 Status: Offline Thanks Meter: 42 | read and write spd (nand 66.0m) [SIZE="3"]hello mcn team mcn success read flash flie and write flash size (nand 66.0m) lephone 3 sim _2gsm_1cdmaWelcome to use McnBox! Selected COM21 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN****************** Firmware V1.09 Checksum ********* Box Connected! Ready working at COM21 Scanning pin status,please waiting... ->............................. Pin-status Scan Done Scanning,waiting... ->=....... Operation done, Pin detect out. BOOT : 11 USB D-: 4 USB D+: 6 Spread Total expend 50 seconds ... ->#........... ... ->#....... Operation done, Pin detect out. BOOT: 1 set as oInvert USB D-: 4 USB D+: 6 GND:3 10 Press [ Save ] to save Pinout [G:1 3 10 D-:4 D+:6] Apply to Box If Scan other phone, please click [Stop] [G:1 3 10 D-:4 D+:6] Apply to Box [G:1 3 10 D-:4 D+:6] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Done. Setting baudrate... 921600 Set baud Done CPU Info 6600R Flash Type NAND Flash ID 00AD0076 Flash Model Hynix HY27US08121A Flash Size 0x4200000(66.0M)Start Reading... Read Done! File saved: D:\China Flash Files.mcn\lephone_3sim_a2\6600R_Hynix HY27US08121A.bin[/SIZE]*************************** ************************** write flash file ********* ******** Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Done. Setting baudrate... 921600 Set baud Done CPU Info 6600R Flash Type NAND Flash ID 00AD0076 Flash Model Hynix HY27US08121A Flash Size 0x4200000(66.0M) Check firmware,Wait... Privacy Code: 1234 [G:1 3 10 D-:4 D+:6] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Done. Setting baudrate... 921600 Set baud Done CPU Info 6600R Flash Type NAND Flash ID 00AD0076 Flash Model Hynix HY27US08121A Flash Size 0x4200000(66.0M) Erasing Flash... Erase Done! Start Writing... Write Done************** ************** before this update any one test this phone read flash file and backup same flash phone become dead i test this version phone ok not dead but format not support please mcn fix this bug i try to check nand button same resulte this is log>>>>>>>>>>>>>>>>>Selected COM21Current occupied port COM24 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN************* Firmware V1.09 Checksum ************* Box Connected! Ready working at COM21 Scanning pin status,please waiting... ->............................. Pin-status Scan Done Scanning,waiting... ->=.. Operation done, Pin detect out. USB D-: 4 USB D+: 6 Spread Total expend 6 seconds ... ->#........... ... ->#........... Operation done, Pin detect out. BOOT: 1 set as oInvert USB D-: 4 USB D+: 6 GND:3 10 Press [ Save ] to save Pinout [G:1 3 10 D-:4 D+:6] Apply to Box If Scan other phone, please click [Stop] [G:1 3 10 D-:4 D+:6] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Done. Setting baudrate... 921600 Set baud Done CPU Info 6600R Flash Type NAND Flash ID 00AD0076 Flash Model Hynix HY27US08121A Flash Size 0x4200000(66.0M) NAND Not support. Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Done. Setting baudrate... 921600 Set baud Done CPU Info 6600R Flash Type NAND Flash ID 00AD0076 Flash Model Hynix HY27US08121A Flash Size 0x4200000(66.0M) NAND Not support. |
03-23-2011, 18:54 | #26 (permalink) |
Member: 1536420 Status: Offline Thanks Meter: 42 | to mcn hello mcn team iam trying to format phone whith version (3.0.6 test) and format success and this is log>>>>>>>>>>>>> Welcome to use McnBox! Selected COM21 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN******* Firmware V1.09 Checksum *****-**** Box Connected! Ready working at COM21 ================================== Suggest: Power supply with the tran-clamp to read the pin-status Scanning pin-status,please waiting... ->............................. Pin-status Scan Done ------------------------------- Scanning,waiting... ->*.. Operation done, Pin detect out. BOOT : 1 USB D-: 4 USB D+: 6 Total expend 71 seconds ... >>=.--------- ... Press [ Save ] to save Pinout [G:3 10 D-:4 D+:6 oL:2 7 9 11 12 13 14 oI:1 5 8] Apply to Box If Scan other phone, please click [Stop] [G:3 10 D-:4 D+:6 oL:2 7 9 11 12 13 14 oI:1 5 8] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Error. ID: D0000 [G:3 10 D-:4 D+:6 oL:2 7 9 11 12 13 14 oI:1 5 8] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Error. ID: B1020 [G:3 10 D-:4 D+:6 oL:2 7 9 11 12 13 14 oI:1 5 8] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Error. ID: D0000 [G:3 10 D-:4 D+:6 oL:2 7 9 11 12 13 14 oI:1 5 8] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600R Flash Type NAND Flash ID 00AD0076 Flash Model Hynix HY27US08121A Flash Size 0x4200000(66.0M) Format Error. ID: R1002 [G:3 10 D-:4 D+:6 oL:2 7 9 11 12 13 14 oI:1 5 8] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Done. Flash Type NAND Start Formatting,Wait... Format Done. |
03-24-2011, 05:06 | #27 (permalink) |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Regarding Nand format, you have to choose related boot then do the job, auto Initialize boot sometime will be give you the result above ! 3.06 stable version and 3.06 test version using same bootloader , well , next version , i try to making it better ! Mcnbox |
03-24-2011, 13:09 | #28 (permalink) |
No Life Poster Join Date: May 2006 Location: Mountains
Member: 276322 Status: Offline Thanks Meter: 293 | FLY E170 Format no support Welcome to use McnBox! Selected COM6 COM2 COM3 COM13 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN____________ Firmware V1.09 Checksum E057-CFBE Box Connected! Ready working at COM6 ------------------------------- Start Scanning... -> Results: CPU: MT6235. VCC:5 6,GND:18 19 20,RXD:13,TXD:11,BOOT:7 [V:5 6 G:7 18 19 20 R:13 T:11] Apply to Box Phone detected, wait.. CPU: 6235 Ver: 8A04 SW:8A01 CPU ID: 00000300 Initialize Boot5 ... Nand Flash Type [TOSHIBA] TC58NVG0S3AFT Nand Flash Code 009800D1(00900015) Nand Flash Size 0x8400000 Hex Bytes not support Format Initialize Boot6 ... Phone not support on this boot, or cpu dead Initialize Boot7 ... Phone not support on this boot, or cpu dead |
03-25-2011, 04:26 | #29 (permalink) |
Insane Poster Join Date: May 2008
Member: 778173 Status: Offline Thanks Meter: 8 | cayon reanding erro Welcome to use McnBox! Selected COM6 COM7 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCNxxxxxxxxx Firmware V1.09 Checksum A617-8FBE Box Connected! Ready working at COM6 ------------------------------- Start Scanning... ->. Results: CPU: MT6226M. VCC:8,GND:1 2,RXD:7,TXD:6 [V:8 G:1 2 R:7 T:6] Apply to Box [V:8 G:1 2 R:7 T:6] Apply to Box Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6226MS Ver: 02 SW:8B01 CPU ID: C14E120B Initialize Boot4 ... Flash(Nor) Type [SAMSUNG] K5L2931CAM Flash(Nor) Code 00EC257E(25082501) Flash(Nor) Size 0x01000000 Hex Bytes Checking baudĄ* Set Baud:921600 Done. Start Reading(Nor)... The phone information: QIHUI26_GEMINI_PCB01_GPRS_MT6226M_S01.T98B_HY_06_2 _0T03_081128.BIN Reading Error |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
