Flashing SPD Using USB cable & MCN software Credit Goes to Ashakaas Dealing with SPD chip is never so easy ! Now for latest spd chips we can read/format/write with stable connection ! Credit goes to Mr. Ashakaas in his thread : ( http://forum.gsmhosting.com/vbb/f532...akaas-1457478/ ) .I make this thread for others who cant understand Indonesian. I make it simple : 1. Open mcn pro 2. Find the boot keypad/button on phone.Try one by one , for phone with touchscreen is easier. Hold one button,for example,menu key then connect the phone usb cable (not box cable) with battery or no battery, connect to pc. If the pc find new "usb device" then it will be the spreadrum usb driver (sci driver). See the com number of spd driver in Device Manager of your pc. Try other button if no usb device pops up on your pc. 3. Click Reconnect on mcn software, choose the com of spd device. That is all. The connection will be very stable ! Just choose the spd boot (auto , boot9, boot10 or boot 12) & you are ready to repair here is log for SPD touchscreen chinese phone with boot 12(sc6800h)(test) : Welcome to use McnBox! Selected COM3 Initialize in progress... Checking data, wait... Serial number: MCN200xxxxxx Firmware version: V1.15 Checksum value: 902B-B3BE Software V3.26 Box Connected! Box Operating at high speed port: COM3 Connecting, wait... Phone Connected! Info: SPRD3 Initialize boot12... CPU Info 6800H Flash Type NAND Flash ID 00AD00A1 Flash Model HYNIX_H8BCS0CG0MBR Flash Size 0x8400000(132.0M) Start Reading... Read Done! File saved: G:\DONLOT\6800H_HYNIX_H8BCS0CG0MBR.bin Thanks to bro Ashakaas ( sy bisa handle hp spd diatas setelah baca thread anda ) best regards to MCN Pro Team & all MCN box users |
sip mas bro ................. |
kalo chipset sc6610/20 uda nyoba belom ya?? soalnya punya satu hape buka kode ,ngak bisa boot dengan mcn |
@mantok for this chipset sc6610/20 you can try, try each button including volume + or volume - . (coba tiap tombol) |
tested spd 6610 tested spd 6610 tested gstar b83 ,boot key call 1 http://forum.gsmhosting.com/vbb/atta...1&d=1334392889 |
tested 6610 flash 1 Attachment(s) |
great woek bro........ |
i found bug for spd 6610 for phone Movi B3 here is log : using boot 10 Welcome to use McnBox! Selected COM3 COM4 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN2008xxxxxxxxx Firmware V1.15 Checksum 902B-B3BE Software V3.27 Box Connected! Ready working at COM3 Connecting, wait... Port error, Occupied or non-exist! Press and Holding Power button now ! Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot10... CPU Info 6610 Flash Type NOR Flash ID 00C80040(00170000) Flash Model GD25Q64 Flash Size 0x800000(8.0M) Start Reading... Read Done! File saved: C:\Documents and Settings\ton2\My Documents\6610_GD25Q64.bin File not for SPD when i open the backup file , get this message 'File not for SPD' And when i try to read the phonelock here is log : Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot10... CPU Info 6610 Flash Type NOR Flash ID 00C80040(00170000) Flash Model GD25Q64 Flash Size 0x800000(8.0M) Check firmware,Wait... No Code found I also try to Factory Reset using boot 10 but cant solve, the phone still locked. Boot 10 can't do nothing good for this spd 6610 !!! but here is another log using boot 9 : Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot9... CPU Info 6610 Flash Type NOR Flash ID E59FF018(E59FF018) Flash Model UNKNOWN Flash Size 0x1000000(16.0M) Start Reading... Read Done! File saved: C:\Documents and Settings\ton2\My Documents\6610_UNKNOWN.bin when i open the backup file , no message like above. The backup file maybe good but see the 'Flash Model UNKNOWN'? I won't flash back the file with this log. and the flash size are different ! But luckily boot 9 succeeds to read the code , log : Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot9... CPU Info 6610 Flash Type NOR Flash ID E59FF018(E59FF018) Flash Model UNKNOWN Flash Size 0x1000000(16.0M) Check firmware,Wait... Unlock Code: 171922 Privacy Code: 171922 Mcn team please solve the problem of this SPD chip, because some users here have posted reports for dead phone if they format this spd 6610 with boot 10 and can't revive the phone if they use the backup file (with message 'File not for SPD') best regards |
ada yg sukses write spd 6800hi (maxtron 233) gak bro .aku flash slalu matot . |
maxtron 223 chipset 6800 |
mantap, thx bro..... |
i have tried this but the phone distconnects before i am able to do anything. |
kalo ini kira-kira dimana letak kesalahannya boss Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Please put the baud set 115200, try again. Ready to read/write again, please remove the power supply clip or battery and then re-loaded it. Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Analyzing USB device, please wait... Find USB device:SCI USB2Serial (COM15), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Please put the baud set 115200, try again. >>Ready to read/write again, please remove the power supply clip or battery and then re-loaded it. please help me... |
thanks to bro ashakass, ilmu nya sangat bermafaat.. |
