Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > McnBox Team Products > McnPro Box
Old 04-12-2012, 19:29   #1 (permalink)
Member: 756567
Flashing SPD Using USB cable & MCN software Credit Goes to Ashakaas
Dealing with SPD chip is never so easy ! Now for latest spd chips we can read/format/write with stable connection ! Credit goes to Mr. Ashakaas in his thread : ( flash spredtrum dg box mcn pro tanpa rx tx hanya kabel usb hp by ashakaas ) .I make this thread for others who cant understand Indonesian. I make it simple :
1. Open mcn pro
2. Find the boot keypad/button on phone.Try one by one , for phone with touchscreen is easier. Hold one button,for example,menu key then connect the phone usb cable (not box cable) with battery or no battery, connect to pc. If the pc find new "usb device" then it will be the spreadrum usb driver (sci driver). See the com number of spd driver in Device Manager of your pc. Try other button if no usb device pops up on your pc.
3. Click Reconnect on mcn software, choose the com of spd device. That is all. The connection will be very stable ! Just choose the spd boot (auto , boot9, boot10 or boot 12) & you are ready to repair
here is log for SPD touchscreen chinese phone with boot 12(sc6800h)(test) :
Welcome to use McnBox!
Selected COM3
Initialize in progress...
Checking data, wait...
Serial number: MCN200xxxxxx
Firmware version: V1.15
Checksum value: 902B-B3BE
Software V3.26
Box Connected!
Box Operating at high speed port: COM3
Connecting, wait...
Phone Connected!
Info: SPRD3
Initialize boot12...
CPU Info 6800H
Flash Type NAND
Flash ID 00AD00A1
Flash Model HYNIX_H8BCS0CG0MBR
Flash Size 0x8400000(132.0M)
Start Reading...
Read Done!
File saved: G:\DONLOT\6800H_HYNIX_H8BCS0CG0MBR.bin
Thanks to bro Ashakaas ( sy bisa handle hp spd diatas setelah baca thread anda )
best regards to MCN Pro Team & all MCN box users
The Following 4 Users Say Thank You to tiioo852 For This Useful Post:
Old 04-12-2012, 19:58   #2 (permalink)
Member: 986603
sip mas bro .................
Old 04-13-2012, 19:13   #3 (permalink)
Member: 251293
kalo chipset sc6610/20 uda nyoba belom ya?? soalnya punya satu hape buka kode ,ngak bisa boot dengan mcn
Old 04-14-2012, 04:54   #4 (permalink)
Member: 756567
@mantok
for this chipset sc6610/20 you can try, try each button including volume + or volume - . (coba tiap tombol)
Old 04-14-2012, 09:44   #5 (permalink)
ashakaass's Avatar
Member: 1695196
Sonork: 100.1623915
Talking tested spd 6610
tested spd 6610
tested gstar b83 ,boot key call 1
The Following User Says Thank You to ashakaass For This Useful Post:
Old 04-14-2012, 09:56   #6 (permalink)
ashakaass's Avatar
Member: 1695196
Sonork: 100.1623915
tested 6610 flash
tested 6610 flash
Old 04-14-2012, 18:04   #7 (permalink)
ROEZT's Avatar
Member: 508048
great woek bro........
Old 04-20-2012, 19:43   #8 (permalink)
Member: 756567
i found bug for spd 6610 for phone Movi B3 here is log :
using boot 10
Selected COM3 COM4
Baud setting ...
Set Baud done
Initialize in progress ...
Checking data ...
Serial No. MCN2008xxxxxxxxx
Firmware V1.15
Checksum 902B-B3BE
Software V3.27
Box Connected!
Ready working at COM3
Connecting, wait...
Port error, Occupied or non-exist!
Press and Holding Power button now !
Connecting, wait...
Phone Connected!
Info: Spreadtrum Boot Block version 2.0
Initialize boot10...
CPU Info 6610
Flash Type NOR
Flash ID 00C80040(00170000)
Flash Model GD25Q64
Flash Size 0x800000(8.0M)
Start Reading...
Read Done!
File saved: C:\Documents and Settings\ton2\My Documents\6610_GD25Q64.bin
File not for SPD
when i open the backup file , get this message 'File not for SPD'
And when i try to read the phonelock here is log :
Phone Connected!
CPU Info 6610
Flash Type NOR
Flash Model GD25Q64
Check firmware,Wait...
No Code found
I also try to Factory Reset using boot 10 but cant solve, the phone still locked.
Boot 10 can't do nothing good for this spd 6610 !!!
but here is another log using boot 9 :
Phone Connected!
Initialize boot9...
CPU Info 6610
Flash Type NOR
Flash ID E59FF018(E59FF018)
Flash Model UNKNOWN
Flash Size 0x1000000(16.0M)
Start Reading...
Read Done!
File saved: C:\Documents and Settings\ton2\My Documents\6610_UNKNOWN.bin
when i open the backup file , no message like above.
The backup file maybe good but see the 'Flash Model UNKNOWN'? I won't flash back the file with this log.
and the flash size are different !
But luckily boot 9 succeeds to read the code , log :
Phone Connected!
Initialize boot9...
CPU Info 6610
Flash Type NOR
Flash Model UNKNOWN
Unlock Code: 171922
Privacy Code: 171922
Mcn team please solve the problem of this SPD chip, because some users here have posted reports
for dead phone if they format this spd 6610 with boot 10 and can't revive the phone if they use the backup file (with message 'File not for SPD')
best regards
Old 04-21-2012, 13:39   #9 (permalink)
Member: 1195159
ada yg sukses write spd 6800hi (maxtron 233) gak bro .aku flash slalu matot .
Old 04-28-2012, 10:37   #10 (permalink)
Member: 251293
maxtron 223 chipset 6800
The Following User Says Thank You to mantok For This Useful Post:
Old 02-12-2013, 08:58   #11 (permalink)
Member: 1469565
mantap, thx bro.....
Old 02-17-2013, 10:46   #12 (permalink)
Member: 32705
i have tried this but the phone distconnects before i am able to do anything.
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 12-10-2012 04:46
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-19-1999 17:41
Page generated in 0.34506 seconds with 12 queries
