05-22-2011, 12:57 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Indonesia-D.K.I Jaya
Member: 1104396 Status: Offline Sonork: 290480 Thanks Meter: 19 | format not success i try to format but it is not progress what should i do sir ???? Checksum ED44-DCBE Box Connected! Ready working at COM8 ------------------------------- Start Scanning... ->....... Results: CPU: MT6235. RXD:4,TXD:5 [R:4 T:5] Apply to Box Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6235 Ver: 8B00 SW:8A01 CPU ID: 00000300 Initialize Boot4 ... ERR Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6235 Ver: 8B00 SW:8A01 CPU ID: 00000300 Initialize Boot6 ... Flash(Nand) Type [ST] NAND01GW3B Flash(Nand) Code 002000F1(0000001D) Flash(Nand) Size 0x08400000 Hex Bytes Start formatting (Nand) ... (can't run format) |
05-22-2011, 13:30 | #2 (permalink) |
No Life Poster Join Date: Mar 2007 Location: ALGERIA Age: 17
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | Have u bckp?witch stat was ur phone? TO FORMAT Change bootloader to 5 or 7 |
The Following User Says Thank You to MDK23 For This Useful Post: |
05-23-2011, 09:51 | #3 (permalink) |
Member: 1104396 Status: Offline Sonork: 290480 Thanks Meter: 19 | i have flashed my phone backup again....but still same problem boot 5 and 7 already too ( see the highlight ) Welcome to use McnBox! Selected COM8 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN2011************ Firmware V1.10 Checksum ED44-DCBE Box Connected! Ready working at COM8 ------------------------------- Start Scanning... >>->....... User Abort ------------------------------- Start Scanning... ->....... Results: CPU: MT6235. RXD:4,TXD:5 [R:4 T:5] Apply to Box Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6235 Ver: 8B00 SW:8A01 CPU ID: 00000300 Initialize Boot5 ... Nand Flash Type [ST] NAND01GW3B Nand Flash Code 002000F1(0000001D) Nand Flash Size 0x8400000 Hex Bytes not support Format Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6235 Ver: 8B00 SW:8A01 CPU ID: 00000300 Initialize Boot7 ... Flash(Nand) Type [ST] NAND01GW3B Flash(Nand) Code 002000F1(0000001D) Flash(Nand) Size 0x08400000 Hex Bytes Start formatting (Nand) ...still not goin' process Last edited by Mcnbox; 05-23-2011 at 11:10. Reason: S/N edited |
The Following User Says Thank You to maknyuss For This Useful Post: |
05-23-2011, 14:50 | #6 (permalink) | |
Freak Poster Join Date: May 2009 Location: *JAVA*
Member: 1026340 Status: Offline Sonork: 100.1621159 Thanks Meter: 142 | Quote:
I think ic damaged cpu rehoot his first cpu ic re new reflash with MCN | |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
hope it is not too comercial | aleksj | Wanted Products | 0 | 06-12-2000 13:22 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
