Here How To Work With Mcnpro Box [size=12pt]How To Use McnPro Box Work order all instruction McnPro Box[/size] http://www.k-boxteam.com/forum/image...7200910_66.bmp [size=12pt]1. Order position button shows linking up box that uses for linking up box and a program if believing in will succeed to show Comport loud in 2. pictures show Comport choose enough [ when ] computer follows 3. suitabilities s choose Baundrate follow 4. Unlock suitabilities use for discharge to lock a telephone (discharge lock every the network) discharge lock user password (User Code) 5. Foramt this order uses for do Opration format return all factory value includes (ingminus,erase ) data all thus before use this order please store data all otherwise the data might is damaged effectively use this order will must study a handbook for something Foramt give circumspect [ powdery ] before 6. Read use for ironning file a telephone be file reservation that want the file will reserve 7. Flash use for in order to write or call again as you said a program ( file such as NOR Flash or NAND Flash) 8. be listen add for do all language or repair correct the language 9. use for pour a box box grade oval box raft F1 nd for reach enough [ when ] star website loads 10. all that use for seek pinout for a telephone give us is correct Pins Tx and Rx , ( we have can to choose part 2 the choice a mobile phone is like [ model ] that have 1CPU and a telephone is like [ model ] at have 2 CPU) 11. Usb Scan use for part mode entrails USB such as CPU Spreadtrum, Mstar ++ 12. we can use this order for Defind pinouts and record store a position pinouts at correct in parting has each time and we can seek pinouts that store pick up can use by must not part 13. PwrSW again use for close - open (Pwr Off , Pwr On) the pressure is DCV, the trend is D+ D- get free and oval stagger a program 14. use for work which cancellation ++ (Opartion) all 15. in all red frame is give us can choose to change each CPU follow a telephone that want such as MTK, Spreadtrum, Msta ....... 16. this order for choose Bootloader , follow the suitability of the number CPU (if be CPU MTK we can choose Bootloader get straight follow the number cpu get by use the order Read or Read General Info a program will inform to give us chooses Bootloader such as CPU MTK6253= Select Boot7 ) 17. we can choose at us wants to record ironning file chooses the file for or store the file which iron or reserve take keep 18. choose order all mode such as iron LCD Data (open screen litter LCD) Write Eeprom(Nor) ++ a fungus can choose NOR Flash or NAND at we want Flah go to still 19. telephones for set the capacity of get both of like [ model ] Manual and Auto before something 20. Ministry of Interiors for iron to store write or correct Imei for 21. telephones use me punches oval in case of punch oval is damaged or be usable punch oval no or Write LCD Data File 22. use for Boot a telephone reads all value in such as CPU, ic Flash capacity value choose Boot Loader at appropriate 23. Read Phone Book store the list of names in the telephone directory of 24. Write Phone Book customers s write the list of names appeareds 25. Backup NV Data telephone directories s store parameter file stores data all such as Imei signal file format etc. 26. Rp No-licensed listen special repair the symptoms in case of inform that no take permit in Chinese 27. generation somes choose the order follows the usability Wr Calibration for at want me Write LCD Data File write a litter LCD after screen change LCD ( must Read LCD Data keep before ) 28. Rp Badsoftware repair that be damaged 29. Read PF Code decrypt pf which be special password for locking pickproof 30. Analysis Code sun beard password crow for 31. Restore NV Data advice administrations s return 32. Exit parameter values s depart a program or close a program. [/size] |
Permisi agan agan semua ikut nimbrung indosel service bandung Slmt pagi, siang, sore, malam agan sekalian Semoga agan sekalin senantiasa di karunia keberkahan kesehatan kemakmuran dunia akhirat amin. Sy Jhon wiyono dari indosel service bandung ingin kut nimbrung berbagi suka duka, pengetahuan, pengalaman, dan pertanyaan soal semua hal tentang servic menyervice Mari kita mulai.... |
