How is working Spreadtrum CPU with Mcnpro Box >> Phone: KD900 KD900_SPREADTRUM_6600ME_CPU_SAMSUNG_K5L2931CAM USB San: Code: Suggest: Power supply with the tran-clamp to read the pin-status Code: >>[V:13 17 18 G:8 11 12 16 D-:9 D+:10] Apply to Box Code: >>[V:13 17 18 G:8 11 12 16 D-:9 D+:10 oI:7] Apply to Box This step is very important , Apply or saving definition to Box Now we go to Pinouts , select the cable, and findout the definition you saved in above step. Check the picture (When Software detect the phone Out . you can see the software interface at lower right corner, the COM port get changed. the same time you can check in the computer device management control panel the have other port named "SCI USB2Serial" port) http://img39.imageshack.us/img39/8863/spdr.jpg http://img15.imageshack.us/img15/4106/spd2o.jpg Note: If any mistake in this procedure , Software will be not allow you flash / unlock your phone. Reading /Backup: http://img132.imageshack.us/img132/8468/spd4.jpg Falsh / unlock phone procedure will be more easily . Just select the files and follow window then can doing. Video : Download Best Regards! Mcnbox Team |
Start to flash KD900 Phone Flash phone: Now start to Flash the phone , i change other USB port 5 connect to Box. after select definition the "SCI USB2Serial" port to 15. http://img3.imageshack.us/img3/4198/spd5.jpg http://img209.imageshack.us/img209/4299/spd6.jpg You can see after flash the phone ,"SCI USB2Serial" port was exit. which mean if you want to flash other same phone , need to Apply the definition one more time. (unlock or format procedure also need reapply the definition) |
Start to format KD900. of course this step very fast , 5 second was enough. http://img522.imageshack.us/img522/208/spd7.jpg |
