06-30-2009, 17:38 | #1 (permalink) |
Product Manager Join Date: Mar 2008
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | How is working Spreadtrum CPU with Mcnpro Box >> KD900_SPREADTRUM_6600ME_CPU_SAMSUNG_K5L2931CAM USB San: Code: Suggest: Power supply with the tran-clamp to read the pin-status Scanning pin-status,please waiting... ->..................................... 13,17,18 Short-pin >>Pin-status Scanning completed ------------------------------- Scanning,waiting... ->= Operation completed, Pinout has scnaned out. USB D-: 9 USB D+: 10 Total time elaps 4 seconds Testing Stability,waiting... >>=........ Scaning other BOOT pin,waiting... >>#=........=...-------------- Operation completed, Pinout has scnaned out. BOOT: 7 set as (oInvert) USB D-: 9 USB D+: 10 GND:8 11 12 16 Click 【Save】 to save Pinout >>If Scanning other phone, please first click 【Stop】 Code: >>[V:13 17 18 G:8 11 12 16 D-:9 D+:10] Apply to Box Code: >>[V:13 17 18 G:8 11 12 16 D-:9 D+:10 oI:7] Apply to Box This step is very important , Apply or saving definition to Box Now we go to Pinouts , select the cable, and findout the definition you saved in above step. Check the picture (When Software detect the phone Out . you can see the software interface at lower right corner, the COM port get changed. the same time you can check in the computer device management control panel the have other port named "SCI USB2Serial" port) Note: If any mistake in this procedure , Software will be not allow you flash / unlock your phone. Reading /Backup: Falsh / unlock phone procedure will be more easily . Just select the files and follow window then can doing. Video : Download Best Regards! Mcnbox Team Last edited by Mcnbox; 07-18-2010 at 11:49. Reason: Add video |
The Following 7 Users Say Thank You to Mcnbox For This Useful Post: |
06-30-2009, 18:03 | #2 (permalink) |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Start to flash KD900 Phone Flash phone: Now start to Flash the phone , i change other USB port 5 connect to Box. after select definition the "SCI USB2Serial" port to 15. You can see after flash the phone ,"SCI USB2Serial" port was exit. which mean if you want to flash other same phone , need to Apply the definition one more time. (unlock or format procedure also need reapply the definition) |
The Following 5 Users Say Thank You to Mcnbox For This Useful Post: |
How is working OM CPU with Mcnpro Box >> | Mcnbox | McnPro Box | 0 | 07-19-2009 10:08 |
<< How is working Anyka CPU with Mcnpro Box | Mcnbox | McnPro Box | 0 | 07-04-2009 10:40 |
How is working ADI Chips with McnPro Box >> | Mcnbox | McnPro Box | 17 | 06-05-2009 14:58 |
How is working INFINEON Chips with McnPro Box >> | Mcnbox | McnPro Box | 0 | 06-02-2009 08:32 |
How to Format MTK Chips with Mcnpro Box >> | PhoneCareCenter | McnPro Box | 9 | 04-10-2009 18:58 |
