Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnPro Box
Old 05-15-2013, 07:37   #1 (permalink)
Member: 1763380
Thanks Meter: 86
mcn pro usb scan error
please mcn team guide me step by step to fsolve my promlem to use usb scan, i use windows xp3. here is the log..
Welcome to use McnBox!
Selected COM3
Current occupied port COM3
Baud setting ...
Set Baud done
Initialize in progress ...
Checking data ...
Serial No. MCN201xxxxx
Firmware V1.15
Checksum F95A-C2BE
Software V3.48
Box Connected!
Ready working at COM3
Scanning pin status,please waiting...
Pin-status Scan Done
Scanning,waiting...
Operation done, Pin detect out.
USB D-: 2 USB D+: 3 Spread
Total expend 2 seconds
Not found "BOOT"
[G:5 D-:2 D+:3] Apply to Box
If Scan other phone, please click [Stop]
and in ports, cpu type only appear briefly, then disappear again.
and I can not use 'usb scan' for all types of mobile phones
best regards
Old 05-20-2013, 05:36   #2 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Reinstall SPD driver my friend !
And also check here : http://forum.gsmhosting.com/vbb/f532...o-box-1050768/
Best regards!
Mcnbox
The Following User Says Thank You to Mcnbox For This Useful Post:
Old 05-20-2013, 07:56   #3 (permalink)
Member: 1763380
Thanks Meter: 86
thanks for the repllay.. but how about this
Selected COM3
Baud setting ...
Set Baud done
Checking data ...
Serial No. MCN201xxxxxxx
Firmware V1.15
Checksum F95A-C2BE
Software V3.48
Box Connected!
Scanning,waiting...
USB D-: 5 USB D+: 4 Spread
BOOT: 7 set as oInvert
USB D-: 5 USB D+: 4 GND:9 12
Press [ Save ] to save Pinout
[G:7 9 12 D-:5 D+:4] Apply to Box
[G:9 12 D-:5 D+:4 Down:7] Apply to Box
Checking USB Serial port, wait...
SCI USB2Serial Port: COM39
Connecting, wait...
Press and Holding Power button now !
but i can't find 'oinvert', there is just p down & p_up..
i've installed sci usb driver in ports(com&lpt)
and after a successful install sci usb2serial lost again.
Old 05-23-2013, 02:38   #4 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,534
did you save pinouts? or maybe your phone is boot protected, can you share here your phone picture so i can give you some idea.
br
The Following 3 Users Say Thank You to .::M Irfan::. For This Useful Post:
Old 05-23-2013, 02:56   #5 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,779
Originally Posted by den fatih View Post
please mcn team guide me step by step to fsolve my promlem to use usb scan, i use windows xp3. Here is the log..
Welcome to use mcnbox!
Selected com3
current occupied port com3
baud setting ...
Set baud done
initialize in progress ...
Checking data ...
Serial no. Mcn201xxxxx
firmware v1.15
checksum f95a-c2be
software v3.48
box connected!
Ready working at com3
scanning pin status,please waiting...
Pin-status scan done
scanning,waiting...
Operation done, pin detect out.
Usb d-: 2 usb d+: 3 spread
total expend 2 seconds
Not found "boot"
[g:5 d-:2 d+:3] apply to box
if scan other phone, please click [stop]
And i can not use 'usb scan' for all types of mobile phones
best regards
contact me in yahoo.
The Following User Says Thank You to MARVZ_TG For This Useful Post:
Old 05-23-2013, 03:19   #6 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,534
better give him instruction here so he will solve his problem himself and this thread will help for many other members, just an request dont mind it.
regards
.::M Irfan::.
The Following 4 Users Say Thank You to .::M Irfan::. For This Useful Post:
Old 05-23-2013, 04:04   #7 (permalink)
Member: 1194110
Thanks Meter: 113
I suggest when working with CPU SPD , will be more stable when using a USB cable, not the cable from the Box MCNPro. Of course it requires Boot button.
because voltage is needed to be more stable
The Following User Says Thank You to [aNt] For This Useful Post:
Old 05-23-2013, 11:39   #8 (permalink)
Member: 1763380
Thanks Meter: 86
yes more comfortable with using the usb & I rarely fail, but if there is no boot button, like it or not I have to use a usb scan, especially for spd & Mstar I have never had success just by scan rx tx, so the answer is just to use a usb scan, but the problem as I mentioned above. I have tried as video tutorials for spd usb scan, but it did not work in my mcn ....
br
Old 05-23-2013, 11:43   #9 (permalink)
Member: 1763380
Thanks Meter: 86
regards
.::M Irfan::.
yes I already save the pinouts, but the problem is still same
Old 05-23-2013, 12:37   #10 (permalink)
Member: 1763380
Thanks Meter: 86
team ... whether mcn already support flash, format, backup for nexian android phone A850? the problem is there is only android logo image,
I've tried rx tx, usb scan, also usb but not detected ....
sorry I did not make a new tread, because I just was given 1 day to fix it.
Old 05-23-2013, 13:02   #11 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,779
regards
.::M Irfan::.
here
try this 2 option ( use standard micro usb )
this procedure applicable all CHINA phone MTK & SPD
option *1
*1 check usb
*2 insert usb & install driver
*3 click read or format wait until finish
option 2
*1 check usb
* press bootkey try home button or volume down or up
post result
Old 05-23-2013, 16:55   #12 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,534
do as directed by MARVZ_TG i hope this will solve your problem!
if not you ahve to be sure whixh exactly cpu chip inside in your phone!
try and post result.
br
Old 05-24-2013, 11:52   #13 (permalink)
Member: 1763380
Thanks Meter: 86
I have carried out two options, scan usb not detected, usb with the boot, not well, I have hit all the buttons but no reaction ... no results at all, I've also tried using sproccom but no results, but on youtube by using sproccom tool can successfully flashing A850 .. I do not know if I was not careful or do not understand ... heee
existing 3 mobile phone with this condition, and all of them failed miserably ....
salam
Old 05-24-2013, 12:49   #14 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,534
salam
what is your phone current condition? one more thing you have to try different key combination to find boot key! can you please open phone and confirm what exactly cpu chip inside in phone this is help us to solve your problem easily!
try with different keys to boot and post screenshot instead logs.
br
The Following User Says Thank You to .::M Irfan::. For This Useful Post:
Old 05-24-2013, 23:29   #15 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,779
salam
hi can you take a picture your phone back of baterry
Page generated in 0.28011 seconds with 10 queries
