Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnPro Box
Old 08-25-2010, 15:24   #46 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Mcnpro Box official version 2.9.1 Released
What's new for version 2.9.1 ?
  • Fixed MT6253 unlock bugs (Boot 6/7)
  • Improved MT6253 Read/Write operation(Boot 6/7).
  • Improved boot5 detection operation.
  • Corrected other small reported bugs(Eg, MT6223 SVME6462UT 00C222C9).
Upgrading from Previous Versions:
  • Version of 2.9.1 is a maintenance release. so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section !
The Following 12 Users Say Thank You to Mcnbox For This Useful Post:
Old 08-29-2010, 20:03   #47 (permalink)
MDK23's Avatar
Member: 467636
Sonork: Double Kanon
Thanks Meter: 2,618
Thumbs up Mcnpro Box official version 2.9.2 Released
What's new for version 2.9.2 ?
* Fixed knows bugs for Boot 7
* Added smart write function for Boot5
* Boot5 detection operation Improved
* Default format function changed
* FFS format operation Improved
* Version of 2.9.2 is a maintenance release. so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section !
* Version of 2.9.2 required install Mcnpro Box Suite version 2.0.3 first, To download that from support section !
Best Regards !
Mcnbox Team
The Following 7 Users Say Thank You to MDK23 For This Useful Post:
Old 09-03-2010, 08:56   #48 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Mcnpro box ChinaRes Editor 1.10 released
What's new for ChinaRes Editor 1.10 ?
  • Improve Language detection method
  • Fonts fucntion improved
ChinaRes Editor 1.10 is a maintenance release. To download that from support section !
The Following 7 Users Say Thank You to Mcnbox For This Useful Post:
Old 09-05-2010, 14:56   #49 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
What's new for ChinaRes Editor 1.11 ?
  • Fix Language detection method bugs
  • Fix when translation array bugs
ChinaRes Editor 1.11 is a maintenance release. To download that from support section !
Old 09-10-2010, 11:04   #50 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro box ChinaRes Editor 1.12 released
What's new for ChinaRes Editor 1.12 ?
  • Improved Langs detection method bugs
  • Fix some bugs for MT6253
  • Non-show part of langs after using other tool edited (eg,MT6225) bugs fixed
ChinaRes Editor 1.12 is a maintenance release. To download that from support section !
How to Install ChinaRes_Editor_1.12 ?
A,)Required install Mcnpro Box Suite version 2.0.3 first
B,)Download ChinaRes_Editor_1.12.rar
C,)Extract to C:\Program Files\Mcnbox Team\Mcnpro Box\resource folder
D,)Run Mcnbox.exe
E,)Go to File tools --> ChinaRes Editor
The Following 10 Users Say Thank You to Mcnbox For This Useful Post:
Old 09-15-2010, 00:49   #51 (permalink)
MDK23's Avatar
Member: 467636
Thanks Meter: 2,618
Thumbs up Mcnpro Box official version 2.9.3 Released
What's new for version 2.9.3 ?
  • Improved MT6253 Pinout detection
  • Smart write operation improved
  • Nand flash Read/Write operations improved
  • Add Some new Nand flash for MT6235 (Thanks ktommyx report)
  • Spreadtrum CPU Pinout detect Speed improved(Now just few second)
  • Backup / read file saved by phone firmware name
  • Box firmware upgrade to 1.08(1.07 have not public Realese only for beta tester )
  • Version of 2.9.3 is a maintenance release. so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section !
  • Version of 2.9.3 required install Mcnpro Box Suite version 2.0.3 first
Many new flash files available in support area
Best Regards !
Mcnbox Team
The Following 10 Users Say Thank You to MDK23 For This Useful Post:
Old 09-17-2010, 15:38   #52 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro Box Suite version 2.0.5 Released !!!
Mcnpro Box Suite version 2.0.5 included:
  • Mcnpro Box Official Main version 2.95
  • Mcnpro Box ChinaRes Editor version 1.12
What's new for version 2.95 ?
  • Spreadtrum Pinout detect improved
  • Fix small bugs for Spreadtrum Read/Write
  • MTK Smart write (For nor) more stable/fast
  • Nand flash Write operations improved
  • Auto logs save function add (under Box_data folder)
  • Version of 2.9.5 is a maintenance release. so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section !
Old 09-24-2010, 12:12   #53 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro Box official version 2.9.6 Released
What's new for version 2.9.6 ?
  • Add MTK full flash format function
  • Add MTK Analysis Code direct from flash file(Beta)
  • Smart write operation improved , Now more fast.
  • Change logs showing (Now in one page)
  • Some other Reported Bugs were also fixed
  • Version of 2.9.6 is a maintenance release. so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section !
  • Version of 2.9.6 required install Mcnpro Box Suite version 2.0.5 first
The Following 6 Users Say Thank You to Mcnbox For This Useful Post:
Old 10-18-2010, 04:34   #54 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro Box official version 2.9.7 Released
What's new for version 2.9.7 ?
  • Add Mstar CPU supported
  • Full support Nor / Nand flash Read / Write
  • Full support Nor / Nand flash unlock
What's new for ChinaRes Editor 1.13 ?
  • Fix some bugs for detection MTK Bin file
  • Fixed bug with incorrect language pack rebuilding (Length etc.)
ChinaRes Editor 1.13 is a maintenance release. To download that from support section !
  • As usual, 2.97 version is available for all customers with valid, To download that from support section !
Old 10-25-2010, 13:55   #55 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Mcnpro Box official version 2.9.8 Released
What's new for version 2.9.8 ?
  • Improved boot detection of SpreadTrum CPU (Using new method)
  • Add many new Flash IC support for SpreadTrum
  • Add few new Flash IC support for Infineon
  • Fixed reported bugs for MTK
  • As usual, 2.9.8 version is available for all customers with valid, To download that from support section !
The Following 8 Users Say Thank You to Mcnbox For This Useful Post:
Old 10-31-2010, 08:36   #56 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro Box Suite version 2.0.6 Released (Box V2.9.9 and ChinaRes V1.1.3)
Mcnpro Box Suite version 2.0.6 included:
  • Mcnpro Box Official Main version 2.9.9 NEW !!
  • Mcnpro Box ChinaRes Editor version 1.1.3
What's new for version 2.9.9 ?
  • Add Spreadtrum boot automatic detection(Beta)
    • You can choose auto let SW automatic detection boot
    • You can mamual choose the related boot
  • Add Sci USB2Serial driver version 1.4.4.8 supported
  • Fixed unlock bugs for Spreadtrum 6600M/E
  • Improved Spreadtrum IMEI Write
  • Mstar Nand flash Write operations improved
  • Mstar knows bug fixed.Eg, SIM Unlock
  • Version of 2.9.9 is a maintenance release. so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section !
The Following 2 Users Say Thank You to Mcnbox For This Useful Post:
Old 11-21-2010, 12:47   #57 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro Box official version 3.0.0 Released
I would like to announce that version 3.0.0 of Mcnpro Box is now available. If you have Mcnpro Box , now you can download that from our official Support area !
What's new for version 3.0.0 ?
  • Add SMS backdoor Feature for MTK and SPD (First in the world)
  • Add MTK NV data backup /Restore Function
  • Fix bugs for MTK Boot5 when Read flash
  • Other small report bugs fixed
  • Version of 3.0.0 request install Suite version 2.0.6 at first, so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section !
Old 12-02-2010, 20:56   #58 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro Box official version 3.0.1 Released (ChinaRes Editor 1.14)
What's new for ChinaRes Editor 1.14 ?
  • Add Modify language function by entire Row
  • Add saving per language dict file function
  • Add per language dict file(MDIC) load function
  • Add Modify language by entire Row in dictionary
  • Improved MTK detecting language in firmware (More fast)
  • Fix delete Language bugs
  • Many internal bugfix'es
What's new for version 3.0.1 ? New!
  • Fix Some MT6253 format lose IMEI/signal bugs
  • Fix when Backup NV data software blink bugs
  • Improved MTK NV data backup speed
  • Add some new Flash IC support for SpreadTrum
  • Improved SpreadTrum SC6600L boot to be more stable
  • Version of 3.0.1 request install Suite version 2.0.6 at first, so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section !
Old 12-21-2010, 20:25   #59 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Mcnpro box ChinaRes Editor 1.15 released
What's new for ChinaRes Editor 1.15 ?
  • Add Spreadtrum SC6600L/RT/WT6226 CPU Support
  • Improved MTK detecting language in firmware (Special for MT6225)
  • Improved Language detecting Speed
ChinaRes Editor 1.15 is a maintenance release. To download that from support section !
The Following 4 Users Say Thank You to Mcnbox For This Useful Post:
Old 01-09-2011, 09:21   #60 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro box Official version 3.0.11 Released
What's new for version 3.0.11 ? New!
  • Fix MTK 6235 Read/Write bugs (For Nand)
  • Improved MTK boot 4 5 6 7 (Merge boot 6/7 for this moment)
  • Add to support more new flash ICs
  • Version of 3.0.11 request install Suite version 2.0.6 at first, so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section !
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
Page generated in 0.57160 seconds with 8 queries
