Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnPro Box
Old 01-17-2011, 09:38   #61 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro Box official version 3.0.2 Released
What's new for version 3.0.2 ? New!
  • Add new decrypt method for MTK (Special for MTK 6235 & 6253)
  • MTK bootloader improved to be more stable!
  • MTK Nv data function Improved
  • Improved SPD bootloader auto detecting bugs
  • Improved USB Scan to be more stable (Special for SPD & Mstar chips)
  • Other small report bugs fixed
Upgrading from Previous Versions:
  • Version of 3.0.2 request install Suite version 2.0.6 at first, so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section !
The Following 15 Users Say Thank You to Mcnbox For This Useful Post:
Old 01-30-2011, 09:00   #62 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro Box Suite version 2.0.7 Released (Box V3.0.3 and ChinaRes V1.1.6 beta)
Mcnpro Box Suite version 2.0.7 included:
  • Mcnpro Box Official Main version 3.0.3
  • Mcnpro Box ChinaRes Editor version 1.1.6 beta
What's new for Mcnpro box version 3.0.3 ?
  • Improved Spreadtrum IMEI Write
  • Fix Spreadtrum boot automatic detection
  • Add SPD 6600L direct Change IMEI
  • Improved MTK 62xx decryption (For some new Flash IC)
  • Demerge Boot 6 / 7 and add more New flash IC to supported
What's new for ChinaRes Editor version 1.1.6 beta ?
  • Completed redesign for lans page(more easily for user)
  • Add keypad define layout function(beta)
  • Add many dictionary files (Under dic folder)
  • Create dictionary files more easily
  • And many more...
  • Version of 3.0.3 is a maintenance release. so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section !
YES, SURE. MCNBOX TEAM ASSURE OUR CUSTOMERS FOR THE BEST SUPPORT. JUST FEEL THE POWER
Happy new year !
The Following 13 Users Say Thank You to Mcnbox For This Useful Post:
Old 02-18-2011, 14:18   #63 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro box ChinaRes Editor 1.17 released
  • Improved Spreadtrum Language detecting Speed
  • Improved Search Function
  • Fixed Ringtone Mid format preview play
  • Fixed MT6235B detecting language in firmware
  • Corrected other small reported bugs
  • Version of 1.17 is a maintenance release. request install Suite version 2.0.7 at first, so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section!
The Following 10 Users Say Thank You to Mcnbox For This Useful Post:
Old 03-10-2011, 06:47   #64 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro box ChinaRes Editor 1.18 released
  • Fixed Spreadtrum Language detecting bugs
  • Add for Saving phrases in Excel file
  • Fixed MT6235B detecting bugs
  • Version of 1.18 is a maintenance release. request install Suite version 2.0.7 at first, so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section!
The Following 9 Users Say Thank You to Mcnbox For This Useful Post:
Old 03-14-2011, 18:08   #65 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro Box official version 3.0.5 Released
What's new for version 3.0.5 ? New! Hot!
  • Fix decrypt bugs for MTK (Special for MT6253)
  • Add full flash write for MTK 6253
  • Boot 6 /7 detection bugs fixed (Special for MT6268)
  • Improved Spreadtrum bootloader auto detecting bugs
  • Spreadtrum 6600L bugs fixed
  • Mstar bootloader improved
  • Mstar detection bugs fixed
  • Infineon CPU write bugs fixed
  • Mcnpro Box hardware firmware update to 1.09
    Eg.
    Welcome to use McnBox!
    Selected COM5
    Baud setting ...
    Set Baud done
    Initialize in progress ...
    Checking data ...
    Serial No. MCN2************
    Firmware V1.09
    Checksum 4BE0-****
    Box Connected!
    Ready working at COM5
  • Version of 3.0.5 request install Suite version 2.0.7 at first, so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section !
The Following 4 Users Say Thank You to Mcnbox For This Useful Post:
Old 03-23-2011, 08:04   #66 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro Box official version 3.0.6 Released
What's new for version 3.0.6 ? very Hot!
  • Detection bugs fixed for MTK 6253 / 6268 / 6235
  • Improved USB Scan to be more stable (eg. Spreadtrum no need holding power key)
  • Spreadtrum IMEI read /write function Improved
  • Spreadtrum code read function Improved (Direct from file)
  • Add Spreadtrum cpu factory reset function
  • Add Spreadtrum cpu safe format function (beta)
  • Add Spreadtrum read phonebook function (Direct from file)
  • Add Mstar cpu manual format function
  • Add Mstar cpu auto format function
  • Add automatic repower fucntion for all CPUs (highlight function)
  • Version of 3.0.6 request install Suite version 2.0.7 at first, so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section !
The Following 5 Users Say Thank You to Mcnbox For This Useful Post:
Old 04-03-2011, 10:29   #67 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro box ChinaRes Editor 1.19 released
  • Fix Saving phrases to Excel bugs
  • Fixed MT6225x detecting bugs
  • Add Burmese font supported
    If your windows system did not show the language,
    you have to install the myanmar font manualy, then restart
    the software one more time ,the font file was including the
    update pack already
  • Improved Ringtones detecting from bin file
  • Version of 1.19 is a maintenance release. request install Suite version 2.0.7 at first, so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section !
Special thanks Krit from K-boxteam
The Following 6 Users Say Thank You to Mcnbox For This Useful Post:
Old 04-15-2011, 09:07   #68 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Mcnpro box ChinaRes Editor 1.20 released
  • Fix some special file langs detecting bugs for MT6253
  • Improved font detecting speed for MTK
  • Enable font import function for MTK
    Now you can change base on MTK phone to any language as you want.
    eg. If phone(A) have not Myanmar font, you can easily export the font from another phone , and import the font to phone(A)
  • Version of 1.20 is a maintenance release. request install Suite version 2.0.7 at first, so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section !
Special thanks Krit (K-boxteam) And Tony give some idea
Old 05-07-2011, 15:49   #69 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Mcnpro box ChinaRes Editor 1.21 released
  • Add new detection method (langs) for Spreadtrum
  • Add unknow bin flash type option
  • Add few new dict files
  • Improved MTK Nand flash detecting
  • Improved phrase length issue
  • Font import function Improved
  • Rename language function Improved
  • Some special bin files detection supported (reported by user)
  • Version of 1.21 is a maintenance release. so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section !
Old 05-09-2011, 22:52   #70 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro Box Suite version 2.0.8 Released (Box V3.0.7 and ChinaRes V1.2.1)
Mcnpro Box Suite version 2.0.8 included:
  • Mcnpro Box Official Main version 3.0.7 New!!
  • Mcnpro Box ChinaRes Editor version 1.2.1
What's new for Mcnpro box version 3.0.7 ?
  • Mcnpro box main firmware update to 1.10
  • Mstar IMEI change function added (first in the world)
  • Mstar Vcom USB driver added
  • MTK "No licensed to produce" repair function added
  • MTK Touch calibration algorithm improved
  • MTK boot update(Now Support many new Flash ICs)
  • MTK boot "test mode" algorithm improved
  • Spreadtrum USB Scan function Complete changed
  • Spreadtrum boot improved & support all CPUs
  • Spreadtrum New flash ICs added
  • OM CPU add new boot (5230&5210UP)
Information check at Mcnpro Box related section
Version of 3.0.7 is a maintenance release. so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section !
Old 05-10-2011, 11:11   #71 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Mcnpro box ChinaRes Editor 1.22 released
  • Fix excel import/export bugs (thanks cykada)
    • Require completed install Microsoft Office ,eg the addition tools else will be have error when you using open excel file function
  • Improved MTK Nand flash font detecting
  • Font import function Improved (still in beta)
  • Apply button function Improved (thanks nguyenchithan01 report)
  • Version of 1.22 is a maintenance release. (require install suite version 2.08 first) so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section
Old 05-12-2011, 09:49   #72 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Thumbs up Mcnpro Box official version 3.0.8 Released
What's new for version 3.0.8 ? New!
  • Read general info button function bugs fixed (Thanks 79mobile report)
  • MTK bootloader 7 improved to be more stable!
  • Multi com port function Improved
  • Version of 3.0.8 request install Suite version 2.0.8 at first, so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section
Old 05-23-2011, 11:31   #73 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Mcnpro Box official version 3.0.9 Released
What's new for version 3.0.9 ? New!
  • Spreadtrum 3 SIMs IMEI change function added
  • Spreadtrum 8800H/S boot improved
  • Spreadtrum Unlock function improved
  • Spreadtrum read code function improved
  • Mstar Unlock function improved
  • Mstar New boot4 added for 8535n
  • Version of 3.0.9 request install Suite version 2.0.8 at first, so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section
The Following 3 Users Say Thank You to Mcnbox For This Useful Post:
Old 05-27-2011, 07:19   #74 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Mcnpro box ChinaRes Editor 1.23 released
  • Improved language rename change function
  • Improved deleted language function
  • Improved language customize function
  • Improved Font import function
  • Font including Charsets function added
  • Version of 1.23 is a maintenance release. (require install suite version 2.08 first) so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section
Old 06-17-2011, 10:17   #75 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro box ChinaRes Editor 1.24 released
  • Add excel file convert to dict function (in Beta)
  • Improved Font detection method
  • Improved Font import function for stable
  • Version of 1.24 is a maintenance release. (require install suite version 2.08 first) so we are recommend all customers running prior versions upgrade to last version be more stability! As usual, new version is available for all customers with valid, To download that from support section
Page generated in 0.55124 seconds with 8 queries
