Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnPro Box
Old 05-21-2013, 12:13   #121 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro Box official version 3.5.0 Released
What's new for Mcnpro box version 3.5.0 ? New!!
  • Improve MTK 6583/9 6577 Read & Write & Format Function
  • Update Main software to V3.5.0
Upgrading from Previous Versions:
  • As usual, Version 3.5.0 request install Suite version 2.1.6 at first,We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section , You also can using updater direct upgrade your software online!
The Following 4 Users Say Thank You to Mcnbox For This Useful Post:
Old 06-03-2013, 16:02   #122 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Mcnpro Box official version 3.5.2 Released
What's new for Mcnpro box version 3.5.2 ? New!! Hot !!
  • Improve MTK onekey Root function to be more stable
  • Fix MTK 657x Read & Write & Format Function bugs
  • SPD Android oneclick Root function added
  • SPD unlock function new method added
  • SPD Read IMEI New method added
  • SPD new flash ICs added
  • CoolSand New flash ICs added
  • CoolSand unlock function Improved
  • Android Read info function added
  • Android Reset /wipe function added
  • Android Reboot recovery function added
  • Update Main software to V3.5.2 (V3.5.1 is beta test version. so non release for public)
  • As usual, Version 3.5.2 request install Suite version 2.1.6 at first,We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section , You also can using updater direct upgrade your software online!
The Following 6 Users Say Thank You to Mcnbox For This Useful Post:
Old 07-17-2013, 05:59   #123 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro Box official version 3.5.3 Released
What's new for Mcnpro box version 3.5.3 ? New!! Hot !!
  • SPD Read 8810 / 6531 bug fixed
  • Android Read info function Improved
  • Android wipe function Improved
  • Update Main software to V3.5.3
  • As usual, Version 3.5.3 request install Suite version 2.1.6 at first,We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section , You also can using updater direct upgrade your software online!
Old 07-19-2013, 09:09   #124 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Mcnpro Box official version 3.5.4 Released
What's new for Mcnpro box version 3.5.4 ? New!!
  • SPD bootloader bug fixed
  • Update Main software to V3.5.4
  • As usual, Version 3.5.4 request install Suite version 2.1.6 at first,We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section , You also can using updater direct upgrade your software online!
The Following 5 Users Say Thank You to Mcnbox For This Useful Post:
Old 08-04-2013, 12:31   #125 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro Box official version 3.5.5 Released
What's new for Mcnpro box version 3.5.5 ? New!!
  • MTK 657x Format Function bugs fixed
  • SPD SC6531 bootloader improved
  • SPD SC65xx IMEI function improved
  • SPD 6820 /8810 full improved
  • CoolSand new flash ICs added
  • Some small reported bugs fixed
  • As usual, Version 3.5.5 request install Suite version 2.1.6 at first,We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section , You also can using updater direct upgrade your software online!
The Following 8 Users Say Thank You to Mcnbox For This Useful Post:
Old 01-04-2014, 08:58   #126 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Thumbs up Mcnpro Box official version 3.5.7 Released
What's new for Mcnpro box version 3.5.7 ? New!!
  • Android ADB Root /FastRoot /Wipe function added
  • CoolSand reported bugs fixed
  • CoolSand new Flash ICs added
  • Spreadtrum new Flash ICs added (8810/6820 etc)
  • Spreadtrum ADB Full flash backup function added
  • Spreadtrum ADB Root function added
  • Improve Spreadtrum Write Function for new CPU
  • Improve Mstar Write Function for new CPU
  • Update Main software to V3.5.7
  • Other small report bugs fixed
  • As usual, Version 3.5.7 request install Suite version 2.1.7 at first,We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section , You also can using updater direct upgrade your software online!
Old 08-25-2014, 17:06   #127 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Mcnpro Box official version 3.5.8 Released
  • MTK add 65xx (6575/77/89/92) supported
  • MTK Nand Read/Write Flash improved
  • MTK Unlock function add new method
  • MTK Android format function improved
  • Spreadtrum 6531 Now supported
  • Spreadtrum 8810/6820 New Flash ICs added
  • Spreadtrum Add SC6500 supported
  • Android Pattern Code unlock improved
  • Android add ADB Root
  • Android add google lock remove function
  • Android Wipe ,Reset Gmail, Reboot recovery function updated
  • Many small reported bugs fixed
The Following 2 Users Say Thank You to Mcnbox For This Useful Post:
Old 01-30-2015, 23:54   #128 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro Box official version 3.5.9 Released
  • MTK add new flash IC supported
  • MTK Android write Nand Flash improved
  • MTK 6260 Read /Write improved
  • Spreadtrum 8810/6820 Format /Unlock improved
  • Spreadtrum Add SC6500 New Flash ICs added
  • Spreadtrum Add SC6500 Format improved
  • Spreadtrum Add SC65xx read function improved
  • Spreadtrum Add SC6531 Format improved
  • Spreadtrum Add SC6531 New Flash ICs added
The Following 7 Users Say Thank You to Mcnbox For This Useful Post:
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
Page generated in 0.37172 seconds with 8 queries
