Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > McnBox Team Products > McnPro Box
Old 06-07-2011, 10:27   #1 (permalink)
Member: 1260512
Sonork: 100.1605447
pls help me i can't use button unlock format....SPD <<SOLVED>>
pls help me i can't use button unlock, format, Read, write on SPD
all the time for spd .
pls help me.
thanks.
Old 06-07-2011, 10:48   #2 (permalink)
MDK23's Avatar
Member: 467636
Sonork: Double Kanon
hi bro
after usb scan .install spd drivers (u find frivČers in mcnbox folder) check in devise manager if all is istalled correctelly clic appy u will see change in comport from 6 to newest one
after that u can use all spd fonction
for more info read manual Regarding SPD 6600 Series CPU working with Mcnpro Box
The Following User Says Thank You to MDK23 For This Useful Post:
Old 06-08-2011, 03:28   #3 (permalink)
Member: 1260512
Sonork: 100.1605447
Originally Posted by MDK23 View Post
hi bro
after usb scan .install spd drivers (u find drivers in mcnbox folder) check in devise manager if all is istalled correctelly clic appy u will see change in comport from 6 to newest one
i install driver spd already but still the same problem
and still show com 6 not chang to other
don't know y?
pls help me.
thanks.
Old 06-08-2011, 04:20   #4 (permalink)
Member: 1260512
Sonork: 100.1605447
Now my problem solved
thanks.
Operation done, Pin detect out.
BOOT: 7 set as oInvert
USB D-: 5 USB D+: 4 GND:9 12
Press [ Save ] to save Pinout
[G:7 9 12 D-:5 D+:4] Apply to Box
If Scan other phone, please click [Stop]
Checking SCI USB2Serial port, wait...
SCI USB2Serial Port: COM103
Connecting, wait...
Phone Connected!
Info: Spreadtrum Boot Block version 2.0
Initialize boot...
CPU Info 6600L/WT6226
Flash Type NOR
Flash ID 00980096
Flash Model TOSHIBA TV00560002EDGB
Flash Size 0x800000(8.0M)
Start Reading...
The Following User Says Thank You to 089999945 For This Useful Post:
Old 06-08-2011, 09:06   #5 (permalink)
MDK23's Avatar
Member: 467636
i am happy to see this
topic closed
The Following 3 Users Say Thank You to MDK23 For This Useful Post:
Page generated in 0.32874 seconds with 10 queries
