Regarding SPD 6600 Series CPU working with Mcnpro Box Regarding SPD 6600 Series CPU working with Mcnpro Box. ( of course still very easy to play ) 1. All most 6600 Series CPU normal we are using USB Scan detect. 2. If always found "Unknow USB device" etc. which means your operation is wrong , and phone still did not connect well . 3. The Right Operation:
if you can have problem , Please post here , let's help you around ! Best Regards ! Mcnbox Team. |
ok after scan i install corectly the drivers but the optons of spd stay inactive on the soft .I cannot read or unlock ......what is wrong ? |
@elhadjioumar Try Using the Latest Version of McnPro Software, also try to Scan TX - RX on some SpreadTrum CPU's to solve your problem, if detected, then continue with Unlock, Format, Flash Options.... Good Luck |
hello sir, i'm new in mcnbow user i confuse about using mcn to find pin, read and format for spreadtrum cpu i have read your explaination about "connect phone via usb cable" this cable , you mean service cable? i find all my cable for service cable jack, no usb cable or i must buy for it? thanks :) |
Best regards ! Mcnbox |
sir, i have done as you told, but after the program found usb d+ and usb d- the 'unlock, format, read, and flash' icons become hidden whats wrong? thanks |
A,) After pinout detect ,then Apply it to Box B,) The sametime you can see the software interface near bottom right corner, the COM port get changed. and in computer device management control panel there have other port named "SCI USB2Serial" port too. C,) Then do what you wanna to do for your phone Best regards ! Mcnbox |
Hello sir pls tell ,me when i scan usb scan he new hardware but whice driver i selected spd cpu she auto install driver pls hellp me |
A), Driver at C:\Program Files\Mcnbox Team\Mcnpro Box\Drivers\Mobile divers B), Just choose this folder then install Any problem , post here , we will help around , don't worry ! Best regards ! Mcnbox |
thanks.. |
Mcnbox |
--------------- Welcome to use McnBox! Selected COM11 COM12 COM10 COM7 Initialize in progress... Checking data, wait... Serial number: MCN2009xxxxxxxxxxxxxxxx Firmware version: V1.06 Checksum value: 2E95-0DBE Box Connected! Box Operating at high speed port: COM12 [G:1 5 10 11 12 13 18 D-:9 D+:8] Apply to Box Format ------------- Formatting, Please Power Off & On Start connecting, wait Boot Info: Initialize Boot... CPU : 6600R Flash(Nand) CODE: 00AD0076 Flash(Nand) Type: NF_HY27XS08121M Flash(Nand) Size: 04200000 Read ------------ Start connecting, wait Boot Info: Initialize Boot... CPU : 6600R Flash(Nand) CODE: 00AD0076 Flash(Nand) Type: NF_HY27XS08121M Flash(Nand) Size: 04200000 Completed Unlock ----------- cant unlock... sory log unlock i forget to save.... |
@Jatnick If u used the New Method, your File will still be in McnPro Folder in the Programmes Folder of your Hard Disk (Where McnPro is Installed).. Just add the file and Press Unlock.. McnPro Team |
I checked today , 6600R have some bugs, this problem should be fixed at next version . Mcnbox |
