04-25-2009, 19:49 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | Successfully unlocked/repaired phones by Mcnpro Box ! see logs Writing, Please Power Off & On Connected Boot Information: downloading Boot CPU Type: 6600D Flash Type: SAMSUNG K5L2931CAM Flash Type: SAMSUNG K5L2931CAM Flsh Size??01000000(Hex Bytes) Baudrate set to:921600 Erase Nor Flash... Erase OK??Time: 97 s Writing(amd Nor)... Write OK >>Time£º 35 m27 s i need to say tanks for phonecarecenter!!!!!!! big tanks for you helps |
The Following 3 Users Say Thank You to fokal2008 For This Useful Post: |
05-04-2009, 17:32 | #2 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | SPD FORMATING OK WITH MCNPRO BOX. Formatting, Please Power Off & On Connected Boot Information: downloading Boot CPU Type: 6600D Flash Type: SAMSUNG K5L2931CAM Flash Type: SAMSUNG K5L2931CAM Flsh Size??01000000(Hex Bytes) Baudrate set to:921600 Formatting Nor Flash... >>Nor Format completed |
The Following 2 Users Say Thank You to fokal2008 For This Useful Post: |
05-04-2009, 17:35 | #3 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | MTK FORMATING OK WITH MCNPRO BOX. MODE VOL AFTER FORMATING OK PHONE WILL WORK PERFECTLY you can Set Formatting Addr manully Please Hold "ON" to connect with the phone... Connected to Phone. CPU??6223 Ver: 8A04 CPU ID??7BDE0C00 Downloading Boot... Nor Flash Code: 00EC257E(25062501) Nor Flash Size: 0x00800000 Hex Bytes INT/EXT RAM Size: 0x0000A000+0x00400000 Formatting Nor Flash... Format Start Addr??0x700000, Size: 0x100000 >>Formatted OK. |
07-13-2009, 16:41 | #4 (permalink) |
Product Manager Join Date: Aug 2007 Location: Inside Java
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | MTK 6223 CPU Read Firmware: Please Hold "ON" to connect with the phone... <<if CPU is 6223D May Be Not Supported>> Connected to Phone. CPU: 6223 Ver: 8A05 SW:8A00 CPU ID: 7E8C0C00 Downloading Boot... Nor Flash Code: 0001227E(22212201) Nor Flash Size: 0x01000000 Hex Bytes INT/EXT RAM Size: 0x0000A000+0x00400000 Verifying Baud... Set Baud:921600 OK. Reading(Nor)... Read OK. >>total: 4 mins23 s Formating: you can Set Formatting Addr manully Please Hold "ON" to connect with the phone... <<if CPU is 6223D May Be Not Supported>> Connected to Phone. CPU: 6223 Ver: 8A05 SW:8A00 CPU ID: 7E8C0C00 Downloading Boot... Nor Flash Code: 0001227E(22212201) Nor Flash Size: 0x01000000 Hex Bytes INT/EXT RAM Size: 0x0000A000+0x00400000 Formatting Nor Flash... Format Start Addr: 0xC40000, Size: 0x3C0000 >>Formatted OK. McnPro Team |
The Following 2 Users Say Thank You to PhoneCareCenter For This Useful Post: |
07-13-2009, 16:53 | #5 (permalink) |
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | Spreadtrum 6600D Pinout Detection: Scanning (please waiting...) ->......... Scanning results: VCC:14,GND:4,RXD:8,TXD:6,BOOT:10 >>[V:14 G:4 10 R:8 T:6] Apply to Box Formatting: Formatting, Please Power Off & On Connected Boot Information: downloading Boot CPU Type: 6600D Flash Type: SAMSUNG K5L2931CAM Flash Type: SAMSUNG K5L2931CAM Flsh Size£؛01000000(Hex Bytes) Baudrate set to:921600 Formatting Nor Flash... >>Nor Format completed McnPro Team |
07-13-2009, 16:53 | #6 (permalink) |
07-13-2009, 17:08 | #7 (permalink) |
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | MTK 6225 CPU Pinout Detection: Scanning (please waiting...) ->. Scanning results: CPU: 6225 VCC:1,GND:3 8,RXD:7,TXD:6 >>[V:1 G:3 8 R:7 T:6] Apply to Box Reading Firmware: Please Hold "ON" to connect with the phone... Connected to Phone. CPU: 6225 Ver: 8A05 SW:8A00 CPU ID: 03DD0800 Downloading Boot... Nor Flash Code: 00980003(00000000) Nor Flash Size: 0x01000000 Hex Bytes INT/EXT RAM Size: 0x0000C000+0x00400000 Verifying Baud... Set Baud:921600 OK. Reading(Nor)... Read OK. >>total: 4 mins23 s Formatting: you can Set Formatting Addr manully Please Hold "ON" to connect with the phone... Connected to Phone. CPU: 6225 Ver: 8A05 SW:8A00 CPU ID: 03DD0800 Downloading Boot... Nor Flash Code: 00980003(00000000) Nor Flash Size: 0x01000000 Hex Bytes INT/EXT RAM Size: 0x0000C000+0x00400000 Formatting Nor Flash... Format Start Addr: 0xE00000, Size: 0x200000 >>Formatted OK. McnPro Team |
07-18-2009, 16:25 | #8 (permalink) |
Product Manager Join Date: Mar 2008
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | MTK 6223 : Detail : LC6223_07A_PCB01_GSM_MT6223_S00.MAUI_07A_W07_36_MP _V13.BIN Scan RX TX: Code: Scanning (please waiting...) ->...... Scanning results: CPU: 6223 GND:5,RXD:3,TXD:2 >>[G:5 R:3 T:2] Apply to Box Reading : Code: Please Hold "ON" to connect with the phone... Connected to Phone. CPU: 6223 Ver: 8A05 SW:8A00 CPU ID: 56100C00 Downloading Boot... Nor Flash Code: 00EC257E(25062501) Nor Flash Size: 0x00800000 Hex Bytes INT/EXT RAM Size: 0x0000A000+0x00400000 Verifying Baud... Set Baud:921600 OK. Reading(Nor)... Read OK. >>total: 2 mins8 s Code: Please Hold "ON" to connect with the phone... Connected to Phone. CPU: 6223 Ver: 8A05 SW:8A00 CPU ID: 56100C00 Downloading Boot... Nor Flash Code: 00EC257E(25062501) Nor Flash Size: 0x00800000 Hex Bytes INT/EXT RAM Size: 0x0000A000+0x00400000 Verifying Baud... Set Baud:921600 OK. Proceding MTK6223 CPU encryption... the file is no encrypt 1 Writing(Nor)... Write OK. Total: 4 mins16 s |
The Following 2 Users Say Thank You to Mcnbox For This Useful Post: |
08-25-2009, 17:55 | #9 (permalink) |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Reading phone General Information. Reading phone General Info: Scan RX TX: Code: Welcome to use McnBox! serial port now: COM5 S/N:MCN200xxxxxx - xxxx Firmware Ver:V1.04 CheckSum:xxxx-xxxx Box Connected ! The Box High-speed Serial port: COM5 ------------------------------- Scanning (please waiting...) ->. Scanning results: CPU: MT6226BA. VCC:6,GND:1 10,RXD:12,TXD:7 >>[V:6 G:1 10 R:12 T:7] Apply to Box Code: Please Hold "ON" to connect with the phone... Connected to Phone. CPU: 6226 Ver: 8A02 SW:8A01 CPU ID: 41DC7088 Downloading Boot... Nor Flash Code: 00EC257E(25082501) Nor Flash Size: 0x01000000 Hex Bytes INT/EXT RAM Size: 0x00047000+0x00400000 >>Keep the phone on, if you do other operation |
08-25-2009, 17:58 | #10 (permalink) |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Pickroof lock Code Pickroof lock Code: Code: Connected to Phone. CPU: 6226 Ver: 8A02 CPUID: 41DC7088 Read Information From the Phone... >>Have not found Pickroof lock Code of this phone |
08-26-2009, 17:04 | #11 (permalink) |
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | Pinout Scan Scanning (please waiting...) ->.. Scanning results: CPU: MT6226BA. VCC:4 5,GND:6 17 18,RXD:12,TXD:10 >>[V:4 5 G:6 17 18 R:12 T:10] Apply to Box Read Flash Verifying Baud... Set Baud:921600 OK. Reading(Nor)... Read OK. total: 4 mins21 s Format you can Set Formatting Addr manully Please Hold "ON" to connect with the phone... Connected to Phone. CPU: 6226 Ver: 8A02 SW:8A01 CPU ID: 391B11D2 Downloading Boot... Nor Flash Code: 00EC257E(25082501) Nor Flash Size: 0x01000000 Hex Bytes INT/EXT RAM Size: 0x00047000+0x00400000 Formatting Nor Flash... Format Start Addr: 0xE00000, Size: 0x200000 Formatted OK. >>Keep the phone on, if you do other operation Fast & Easy McnPro Team |
08-30-2009, 00:03 | #12 (permalink) |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | 6600m SPD with new beta version 2.7.1 reading /backup 6600m SPD with new beta version 2.7.1 reading /backup Code: Connecting... Connected Loading Boot... CPU Type: 6600M/E Flash Type: Nor Flash ID: 00EC257E(25082501) Flash Size: 1000000(16m) Flash Model: K5l6331CAM Reading... Operation completed |
08-30-2009, 00:08 | #13 (permalink) |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | 6600m SPD with new beta version 2.7.1 flashing 6600m SPD with new beta version 2.7.1 flashing Code: Connecting... Connected Loading Boot... CPU Type: 6600M/E Flash Type: Nor Flash ID: 00EC257E(25082501) Flash Size: 1000000(16m) Flash Model: K5l6331CAM Flashing... Operation completed |
10-28-2009, 20:33 | #14 (permalink) |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Test MTK Chipset CPU: MT6229 Scan RX TX : Code: Welcome to use McnBox! Selected COM16 Initialize in progress... Checking data, wait... Serial number: MCN200xxxxx - xxxxx Firmware version: V1.05 Checksum value: 3883-xxxx Box Connected! Box Operating at high speed port: COM16 ------------------------------- Start Scanning... ->.. Scan Results: MTK Chipset CPU: MT6229. VCC:1 2,GND:8 11 15,RXD:5,TXD:6 >>[V:1 2 G:8 11 15 R:5 T:6] Apply to Box |
10-28-2009, 20:35 | #15 (permalink) |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Read General Info: Code: Please Hold "ON" to connect with the phone... Connected to Phone. CPU: 6229 Ver: 8A02 SW:8A02 CPU ID: 02200101 Downloading Boot... Nand Flash Type: [TOSHIBA] TC58NVG0S3AFT Nand Flash Code: 009800F1(00800095) Nand Flash Size: 0x08400000 Hex Bytes INT/EXT RAM Size: 0x00020000+0x00000000 >>Keep the phone on, if you do other operation |
