10-28-2009, 22:11 | #16 (permalink) |
Product Manager Join Date: Mar 2008
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Code: Verifying Baud... Set Baud:921600 OK. Reading(Nand)... Size: 0x8400000 Read OK. total: 27 mins 5 s Save Path:D:\files\MT6229_TOSHIBA_TC58NVG0S3AFT_Tv_mobile.bin >>Keep the phone on, if you do other operation |
The Following User Says Thank You to Mcnbox For This Useful Post: |
10-28-2009, 22:27 | #17 (permalink) |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Test Mt6235 TOSHIBA TV mobile Scan RX TX: Code: Start Scanning... ->.... Scan Results: MTK Chipset CPU: MT6235. VCC:17 18,GND:1,RXD:10,TXD:12 [V:17 18 G:1 R:10 T:12] Apply to Box >>[V:17 18 G:1 R:10 T:12] Apply to Box Read General info: Code: Please Hold "ON" to connect with the phone... Connected to Phone. CPU: 6235 Ver: 0001 SW:8A01 CPU ID: 00000320 Downloading Boot... Nand Flash Type: [TOSHIBA] TC58NWG0S8C Nand Flash Code: 009800C0(008000D5) Nand Flash Size: 0x04200000 Hex Bytes INT/EXT RAM Size: 0x00010000+0x00000000 >>Keep the phone on, if you do other operation |
10-28-2009, 22:33 | #18 (permalink) |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Reading / Backup: Code: Please Hold "ON" to connect with the phone... Connected to Phone. CPU: 6235 Ver: 0001 SW:8A01 CPU ID: 00000320 Downloading Boot... Nand Flash Type: [TOSHIBA] TC58NWG0S8C Nand Flash Code: 009800C0(008000D5) Nand Flash Size: 0x04200000 Hex Bytes INT/EXT RAM Size: 0x00010000+0x00000000 Verifying Baud... Set Baud:921600 OK. Reading(Nand)... Size: 0x4200000 Read OK. total: 5 mins 25 s |
10-28-2009, 22:52 | #19 (permalink) |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Test Infineon 7870 Scan Rx TX: Code: Start Scanning... ->..... Scan Results: GND:9 10,RXD:5,TXD:1 >>[G:9 10 R:5 T:1] Apply to Box Code: Power On... Connected OK Downloading boot... Load boot OK BaudRate : 921600 OK. Send data to phone... Flash ID: 00EC22E0 Flash Type: SAMSUNG K5A6317CT(K5J6316CT) Flash Size: 0x00800000 reading... read Completed Time: 3 m0 s >>File Save to : D:\files\Infineon_7870.bin |
10-28-2009, 22:54 | #20 (permalink) |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Flashing: Code: Power On... Connected OK Downloading boot... Load boot OK BaudRate : 921600 OK. Send data to phone... Flash ID: 00EC22E0 Flash Type: SAMSUNG K5A6317CT(K5J6316CT) Flash Size: 0x00800000 >>flashing... Unlock : Code: Scaning password... Possible Password: 2727 08573 >>Scan completed. |
11-10-2009, 09:01 | #21 (permalink) |
No Life Poster Join Date: Jan 2003 Location: bestncheap Age: 43
Member: 19785 Status: Offline Thanks Meter: 1,242 | Successfully unlocked/repaired phones by Mcnpro Box ! This The phone this the log Scan Pinout CPU: MT6235. VCC:5,GND:4 7,RXD:10,TXD:9 >>[V:5 G:4 7 R:10 T:9] Apply to Box Read Flash Please Hold "ON" to connect with the phone... Connected to Phone. CPU: 6235 Ver: 0001 SW:8A01 CPU ID: 00000300 Downloading Boot... Nand Flash Type: [HYNIX] HY27UF082G2M/A Nand Flash Code: 009800F0(00800095) Nand Flash Size: 0x04200000 Hex Bytes INT/EXT RAM Size: 0x00010000+0x00000000 Verifying Baud... Set Baud:921600 OK. Reading(Nand)... Size: 0x4200000 Read OK. total: 30 mins41 s Save Path:F:\BACKUP CHINA\Aego\Aego-i50 >>Keep the phone on, if you do other operation BR BnC |
The Following User Says Thank You to bestncheap For This Useful Post: |
12-24-2009, 12:54 | #22 (permalink) |
Junior Member Join Date: Dec 2008 Location: Bekasi
Member: 923150 Status: Offline Thanks Meter: 7 | Successfully unlocked/repaired phones by Mcnpro Box ! Start Scanning... ->.... Scan Results: Type:5212 GND:1 2 3,RXD:8,TXD:7 >>[G:1 2 3 R:8 T:7] Apply to Box Power On... Connected OK Loading boot... Baud Rate:921600 Ok! Flash ID: 0020880D Flash Type: ST M36L0R8060T1 Flash Size: 0x2000000 Uploading... Upload Completed >>File Save to :C:\Program Files\Mcnbox Team\NX-200D.cla Good Job McnPro Box... |
The Following User Says Thank You to Saudara For This Useful Post: |
11-03-2010, 19:10 | #23 (permalink) |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Successfully unlocked/repaired phones by Mcnpro Box ! Here is the Thread which for post Successfully unlocked/repaired phones by Mcnpro Box ! Lets see how our box Powerful 、Professional and easily to use ! Thanks for your Suppot ! Best regards ! Mcnbox |
The Following 4 Users Say Thank You to Mcnbox For This Useful Post: |
11-03-2010, 19:15 | #24 (permalink) |
No Life Poster Join Date: Oct 2009 Location: love me if you can
Member: 1150088 Status: Offline Sonork: ============ Thanks Meter: 254 | Etouch 505 pro dead Firts post repair E Touch 505 TV pro.... Welcome to use McnBox! Selected COM3 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCNXXXXXXXXXX Firmware V1.08 Checksum 79C1-59BE Box Connected! Ready working at COM3 ------------------------------- Start Scanning... -> Results: MTK Chipset CPU: MT6225. VCC:1,GND:10,RXD:3,TXD:9 [V:1 G:10 R:3 T:9] Apply to Box Phone detected, wait.. CPU: 6225 Ver: 8A05 SW:8A00 CPU ID: 03EB0200 Initialize Boot4 ... Flash(Nor) Type: [TOSHIBA] TV00570002CDGB, TC58FVM7TDD Flash(Nor) Code: 00980003(00000000) Flash(Nor) Size: 0x01000000 Hex Bytes Checking baud¡* Set Baud:921600 Done. Start Reading(Nor)... The phone information: K370M00_PCB01_GPRS_MT6225_S00.M_RK3766711_M28102_V 1_1_0_0M1127.BIN Read Done ! Time used: 4 mins13 s File Saved: E:\Firmware China & Software\File\eTouch\K370M00_PCB01_GPRS_MT6225_S00 .M_RK3766711_M28102_V1_1_0_0M1127.BIN Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6225 Ver: 8A05 SW:8A00 CPU ID: 03EB0200 Initialize Boot4 ... Flash(Nor) Type: [TOSHIBA] TV00570002CDGB, TC58FVM7TDD Flash(Nor) Code: 00980003(00000000) Flash(Nor) Size: 0x01000000 Hex Bytes Start Formatting (Nor)... Start Addr: 0xE00000, Size: 0x200000 Format Done ! After format handset alive and to repair invalid sim repair imei with tick 2nd method 2nd method, please turn off the phone before rd/wr Press and Holding Power button now ! Connecting, wait... CPU: 6225 Ver: 8A05 CPUID: 03EB0200 Release Power Button now Phone detected Wr IMEI1 Done: 35206204002521-9 Press and Holding Power button now ! Connecting, wait... CPU: 6225 Ver: 8A05 CPUID: 03EB0200 Release Power Button now Phone detected Wr IMEI2 Done: 35206204004622-3 ------------------------------- Br hacell |
The Following 3 Users Say Thank You to hacell For This Useful Post: |
11-04-2010, 10:28 | #25 (permalink) |
Member: 1150088 Status: Offline Sonork: ============ Thanks Meter: 254 | Nexian G 922 LCD blank Serial No. MCNxxxxxxxxx Firmware V1.08 Checksum 79C1-59BE Box Connected! Ready working at COM3 ------------------------------- [V:8 G:1 R:13 T:6] Apply to Box Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6223 Ver: 8A05 SW:8A00 CPU ID: D5860C00 Please select Boot5 Initialize Boot4 ... Flash(Nor) Type: [TOSHIBA] TV00570002CDGB, TC58FVM7TDD Flash(Nor) Code: 00980003(00000000) Flash(Nor) Size: 0x01000000 Hex Bytes Checking baud¡* Set Baud:921600 Done. Start Reading(Nor)... The phone information: TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E01A_NO AM_PR_R1_0_V17_INDONESIA.BIN Read Done ! Time used: 4 mins14 s File Saved: E:\Firmware China & Software\File\Nexian\G 800\TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E01 A_NOAM_PR_R1_0_V17_INDONESIA.BIN Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6223 Ver: 8A05 SW:8A00 CPU ID: D5860C00 Please select Boot5 Initialize Boot4 ... Flash(Nor) Type: [TOSHIBA] TV00570002CDGB, TC58FVM7TDD Flash(Nor) Code: 00980003(00000000) Flash(Nor) Size: 0x01000000 Hex Bytes Start Formatting (Nor)... Start Addr: 0xE00000, Size: 0x1F0000 Format Done ! Br hacell |
11-06-2010, 04:40 | #26 (permalink) |
Banned Join Date: May 2007 Location: nokia service tool
Member: 503304 Status: Offline Sonork: 100.1585733 Thanks Meter: 34 | Format máy H688 MT6205 SPANSION QMOBILE ME114 Qmobile q130 Format Imobile TV 640 mt6235 ----------------------- Post logs here only ! Last edited by Mcnbox; 11-06-2010 at 05:44. |
The Following 4 Users Say Thank You to hohoangkhoi For This Useful Post: |
11-12-2010, 09:46 | #27 (permalink) |
Member: 1150088 Status: Offline Sonork: ============ Thanks Meter: 254 | Nexcom 689 dead Welcome to use McnBox! Selected COM3 COM9 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCNXXXXXXXXX Firmware V1.08 Checksum 79C1-59BE Box Connected! Ready working at COM3 [G:5 R:4 T:3] Apply to Box Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6223 Ver: 8A05 SW:8A00 CPU ID: B3460C00 Please select Boot5 Initialize Boot4 ... Flash(Nor) Type: [TOSHIBA] TV00570002CDGB, TC58FVM7TDD Flash(Nor) Code: 00980003(00000000) Flash(Nor) Size: 0x01000000 Hex Bytes Checking baud¡* Set Baud:921600 Done. Start Reading(Nor)... The phone information: MAGCOMM23C_09A_PCB01_GPRS_MT6223P_S00.F96Z08NEXV01 _01B04.BIN Read Done ! Time used: 4 mins13 s File Saved: E:\Firmware China & Software\File\NEXCOM\NC689\MAGCOMM23C_09A_PCB01_GP RS_MT6223P_S00.F96Z08NEXV01_01B04m.BIN Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6223 Ver: 8A05 SW:8A00 CPU ID: B3460C00 Please select Boot5 Initialize Boot4 ... Flash(Nor) Type: [TOSHIBA] TV00570002CDGB, TC58FVM7TDD Flash(Nor) Code: 00980003(00000000) Flash(Nor) Size: 0x01000000 Hex Bytes Start Formatting (Nor)... Start Addr: 0xE00000, Size: 0x200000 Format Done ! Br hacell |
12-02-2010, 12:28 | #28 (permalink) |
No Life Poster Join Date: May 2006 Location: Mountains
Member: 276322 Status: Offline Thanks Meter: 293 | SPD Nokia C2-00 Please add support for changing and editing the language and fonts [G:10 D-:4 D+:6 oL:1 2 oI:3 5 7 9] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM95 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6226 Flash Type NOR Flash ID 00980096(00003400) Flash Model TOSHIBA TV00560002EDGB Flash Size 0x800000(8,0M) Start Writing... Write Done! http://www.rapidshare.com/files/434437625/c2.rar |
The Following User Says Thank You to gulka For This Useful Post: |
12-04-2010, 10:37 | #29 (permalink) |
Member: 276322 Status: Offline Thanks Meter: 293 | Fly Q110 TV Code: Start Scanning... ->...... Results: CPU: MT6223. GND:8 10,RXD:3,TXD:1 [G:8 10 R:3 T:1] Apply to Box Phone detected, wait.. CPU: 6223 Ver: 8A05 SW:8A00 CPU ID: 8A640C00 Please select Boot5 Initialize Boot4 ... Flash(Nor) Type: [SPANSION] S71PL127N Flash(Nor) Code: 0001227E(22202200) Flash(Nor) Size: 0x01000000 Hex Bytes Checking baudЎ* Set Baud:921600 Done. Start Reading(Nor)... The phone information: TINNO23C_08B_GEMINI_PCB01_GPRS_MT6223_S00.Q110_PR_F1_FLY_06_07.BIN Read Done ! Time used: 4 mins15 s File Saved: D:\TINNO23C_08B_GEMINI_PCB01_GPRS_MT6223_S00.Q110_PR_F1_FLY_06_07.BIN |
12-07-2010, 12:26 | #30 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Bali Age: 46
Member: 42805 Status: Offline Thanks Meter: 16 | nexian G923 1 phone = restart 1 phone other = dead phone success all ----------------- use boot 5, baut 921600 --------------------------------------------------------------------------- Welcome to use McnBox! Selected COM26 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCNxxxxxxxxxxxx Firmware V1.08 Checksum CF7E-E6BE Box Connected! Ready working at COM26 ------------------------------- Start Scanning... ->....... Results: CPU: MT6225. GND:8 10,RXD:3,TXD:1 [G:8 10 R:3 T:1] Apply to Box [G:8 10 R:3 T:1] Apply to Box The File Information: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E506B_PR1 _F1_WAM_ID_TELKMOSEL_01_02.BIN >> The File Information: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E506B_PR1 _F1_WAM_ID_TELKMOSEL_01_02.BIN >> Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6225 Ver: 8A05 SW:8A00 CPU ID: 03060400 Initialize Boot5 ... Flash Type: [SPANSION] S29WS256N Flash(Nor) Code: 0001227E(22302200) Flash(Nor) Size: 0x02000000 Hex Bytes Set Baud Done Start Writing(Nor)... Write Done ! |
The Following 3 Users Say Thank You to karismajaya For This Useful Post: |
