03-17-2011, 09:40 | #61 (permalink) |
Freak Poster Join Date: Mar 2011
Member: 1536420 Status: Offline Thanks Meter: 42 | problem sim card 1,2 show emergency call Welcome to use McnBox! Selected COM20 COM4 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN************ Firmware V1.09 Checksum 5BEA-72BE Box Connected! Ready working at COM20 ------------------------------- Start Scanning... -> Results: CPU: MT6223. VCC:1,GND:4 12,RXD:10,TXD:6 [V:1 G:4 12 R:10 T:6] Apply to Box Phone should be Switched on Phone detected, wait... SN to be changed... Done, SN1: 35921802508979-3 Phone should be Switched on Phone detected, wait... SN to be changed... Done, SN2: 35921802513979-6 now phone work ok |
The Following User Says Thank You to ranen telecom For This Useful Post: |
03-18-2011, 17:25 | #62 (permalink) |
Member: 1536420 Status: Offline Thanks Meter: 42 | success read flash file and nv backup Welcome to use McnBox! Selected COM21 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN******** Firmware V1.09 Checksum 5BEA-72BE Box Connected! Ready working at COM21 ------------------------------- Start Scanning... -> Results: CPU: MT6253. VCC:8,GND:9 10,RXD:1,TXD:3 [V:8 G:9 10 R:1 T:3] Apply to Box Phone detected, wait.. CPU: 6253 Ver: 8A02 SW:8A00 CPU ID: 00000F00 Initialize Boot6 ... Flash(Nor) Type [SPANSION] S29NS128P Flash(Nor) Code 00EC2404(00000000) Flash(Nor) Size 0x01000000 Hex Bytes Checking baud،* Set Baud:921600 Done. Start Reading(Nor)... The phone information: XKSSTEL53_09B_GEMINI_PCB01_GPRS_MT6253_S00.S003_XK L_SAM_V1_8_1013.BIN_FLNK5N2833ATB_AQ12000 Read Done ! Time used: 4 mins 18 s File Saved: D:\China Flash Files.mcn\nokia_xkl-k2\XKSSTEL53_09B_GEMINI_PCB01_GPRS_MT6253_S00.S003 _XKL_SAM_V1_8_1013.BIN_FLNK5N2833ATB_AQ12000 ********************************** *************************************** Welcome to use McnBox! Selected COM21 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN****** Firmware V1.09 Checksum 5BEA-72BE Box Connected! Ready working at COM21 ------------------------------- Start Scanning... -> Results: CPU: MT6253. VCC:8,GND:9 10,RXD:1,TXD:3 [V:8 G:9 10 R:1 T:3] Apply to Box Press and Holding Power button now ! Connecting, wait... CPU: 6253 Ver: 8A02 CPUID: 00000F00 Release Power Button now Phone detected NV Data saved to: D:\China Flash Files.mcn\nokia_xkl-k2\nokia_xkl-k2.nv Backup Done. |
03-19-2011, 08:12 | #63 (permalink) |
No Life Poster Join Date: Oct 2009 Location: love me if you can
Member: 1150088 Status: Offline Sonork: ============ Thanks Meter: 254 | with gpg dead with mcn alive GG 53A dead flash with gpg dragon finish but stiil dead Try using MCN pro handset is normally Chek it log Welcome to use McnBox! Selected COM3 COM6 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCNXXXXXXXXXXXX Firmware V1.09 Checksum 79C1-59BE Box Connected! Ready working at COM3 ------------------------------- Start Scanning... ->....... Results: MTK Chipset CPU: MT6223. GND:10,RXD:1,TXD:7 [G:10 R:1 T:7] Apply to Box [G:10 R:1 T:7] Apply to Box ================================================== ========================== The File Information: MIKI23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.MAUI_09A _W09_36_MP_V9.BIN >> Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6223 Ver: 8A05 SW:8A00 CPU ID: A4AD0C00 Please select Boot5 Initialize Boot4 ... Flash(Nor) Type [SPANSION] S29GL064AT/71GL064NB Flash(Nor) Code 0001227E(22102201) Flash(Nor) Size 0x00800000 Hex Bytes Checking baudĄ* Set Baud:921600 Done. Start Writing(Nor)... Write Done ! Thanks mcn team un still update for user MCN |
The Following User Says Thank You to hacell For This Useful Post: |
03-23-2011, 08:21 | #64 (permalink) |
Product Manager Join Date: Mar 2008
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Box Connected! ........... [G:7 8 11 12 16 D-:9 D+:10] Apply to Box If Scan other phone, please click [Stop] Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM8 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Done. Setting baudrate... 921600 Set baud Done CPU Info 6600M/E Flash Type NOR Flash ID 00EC257E(25082501) Flash Model K5L2931CAM Flash Size 0x1000000(16.0M) Start Reading... Read Done! File saved: D:\mcnpro files\SPD\6600M_E_K5L2931CAM.bin Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM8 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Done. Setting baudrate... 921600 Set baud Done CPU Info 6600M/E Flash Type NOR Flash ID 00EC257E(25082501) Flash Model K5L2931CAM Flash Size 0x1000000(16.0M) Check firmware,Wait... Analyzed Completed. Factory Setting... Done. |
03-23-2011, 09:11 | #65 (permalink) |
Freak Poster Join Date: May 2006 Location: On The Way Age: 49
Member: 272091 Status: Offline Sonork: 100:114011 Thanks Meter: 129 | Welcome to use McnBox! Selected COM63 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCNXXXXXXXXXXXXXX Firmware V1.09 Checksum XXXX-XXXX Box Connected! Ready working at COM63 ------------------------------- Start Scanning... ->...... Results: MTK Chipset CPU: MT6235. GND:10,RXD:3,TXD:1,BOOT:2 [G:10 R:3 T:1 Up:2] Apply to Box [G:10 R:3 T:1 Up:2] Apply to Box Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6235 Ver: 8A04 SW:8A01 CPU ID: 00000300 Initialize Boot4 ... Flash(Nand) Type [HYNIX] H8BCS0PG0MBP Flash(Nand) Code 00AD00A1(00800015) Flash(Nand) Size 0x08400000 Hex Bytes Press and Holding Power button now ! Connecting, wait... CPU: 6235 Ver: 8A04 CPUID: 00000300 Release Power Button now Phone detected Infr: MT6235_IM640_A2_TH-T001[C2098_V3_2_1]_CELLONSZ35_09A_HW_Melody_V0.0 NV Data saved to: F:\SOFT WARE ALL-BOX\McnPro Box\IMOBILE640_NV_MT6235_IM640_A2_TH-T001[C2098_V3_2_1]_CELLONSZ35_09A_HW_Melody_V0.0 Backup Done. THANKS FOR NEW UPDATE. B.R., |
The Following 2 Users Say Thank You to 79mobile For This Useful Post: |
03-23-2011, 09:25 | #66 (permalink) |
Member: 272091 Status: Offline Sonork: 100:114011 Thanks Meter: 129 | Start Scanning... ->....... Results: MTK Chipset CPU: MT6235. VCC:21,GND:1 2 15 16,RXD:19,TXD:18,BOOT:3 [V:21 G:1 2 15 16 R:19 T:18 Up:3] Apply to Box [V:21 G:1 2 15 16 R:19 T:18 Up:3] Apply to Box Press and Holding Power button now ! Connecting, wait... CPU: 6235 Ver: 8A04 CPUID: 00000300 Release Power Button now Phone detected Infr: MT6235_V_1.0.0_F25A_JBL_Melody_V0.0 NV Data saved to: F:\SOFT WARE ALL-BOX\McnPro Box\IPHONE-J8-BLACK_NV_MT6235_V_1.0.0_F25A_JBL_Melody_V0.0 Backup Done. B.R., |
03-23-2011, 09:34 | #67 (permalink) |
Member: 1536420 Status: Offline Thanks Meter: 42 | success read flash file spd Welcome to use McnBox! Selected COM21 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN*********** Firmware V1.09 Checksum ****-**** Box Connected! Ready working at COM21 Scanning pin status,please waiting... ->........................ Pin-status Scan Done Scanning,waiting... ->@@ Operation done, Pin detect out. BOOTŁ؛2 3 4 5 10 11 12 USB D-: 7 USB D+: 8 Spread Press [ Save ] to save Pinout Total expend 1 seconds ... ->#........... ... Press [ Save ] to save Pinout [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box If Scan other phone, please click [Stop] [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Not support,Please Try other boot. Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810(FFFFFFFF) Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Start Reading... Read Done! File saved: D:\China Flash Files.mcn\6600L_WT6228_ST M58WR064ET.bin |
03-23-2011, 09:54 | #68 (permalink) |
Member: 1536420 Status: Offline Thanks Meter: 42 | read user code spd Welcome to use McnBox! Selected COM21 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN*********** Firmware V1.09 Checksum ****-**** Box Connected! Ready working at COM21 Scanning pin status,please waiting... ->........................ Pin-status Scan Done Scanning,waiting... ->@@ Operation done, Pin detect out. BOOTŁ؛2 3 4 5 10 11 12 USB D-: 7 USB D+: 8 Spread Press [ Save ] to save Pinout Total expend 1 seconds ... ->#........... ... Press [ Save ] to save Pinout [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box If Scan other phone, please click [Stop] Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810(FFFFFFFF) Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Check firmware,Wait... Privacy Code: 1234 |
03-23-2011, 09:55 | #69 (permalink) |
Member: 1536420 Status: Offline Thanks Meter: 42 | set new imei direct spd success Checksum 5BEA-72BE Box Connected! Ready working at COM21 Scanning pin status,please waiting... ->........................ Pin-status Scan Done Detect Charge-pin... Vcc-Pin6 Set to empty Detect Charge-pin complete Scanning,waiting... ->@@ Operation done, Pin detect out. BOOTŁ؛2 3 4 5 10 11 12 USB D-: 7 USB D+: 8 Spread Press [ Save ] to save Pinout Total expend 1 seconds ... ->#........... ... Press [ Save ] to save Pinout [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box If Scan other phone, please click [Stop] [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Enter test mode,wait... Test mode,OK ReImei,wait... ReImei Completed. |
03-23-2011, 09:59 | #70 (permalink) |
Member: 1536420 Status: Offline Thanks Meter: 42 | factory set spd success Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810 Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Check firmware,Wait... Analyzed Completed. Factory Setting... Done. |
03-23-2011, 10:19 | #71 (permalink) |
Member: 1536420 Status: Offline Thanks Meter: 42 | write flash file to spd ok Welcome to use McnBox! Selected COM21 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN******* Firmware V1.09 Checksum ****-**** Box Connected! Ready working at COM21 Scanning pin status,please waiting... ->........................ Pin-status Scan Done Scanning,waiting... ->@@ Operation done, Pin detect out. BOOTŁ؛2 3 4 5 10 11 12 USB D-: 7 USB D+: 8 Spread Press [ Save ] to save Pinout Total expend 1 seconds ... ->#........... ... Press [ Save ] to save Pinout [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box If Scan other phone, please click [Stop] [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Not support,Please Try other boot. Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810(FFFFFFFF) Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Start Writing... Write Done! |
03-23-2011, 10:36 | #72 (permalink) |
Member: 1536420 Status: Offline Thanks Meter: 42 | format spd ok Welcome to use McnBox! Selected COM21 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN********* Firmware V1.09 Checksum ********* Box Connected! Ready working at COM21 Scanning pin status,please waiting... ->........................ Pin-status Scan Done Scanning,waiting... ->@@ Operation done, Pin detect out. BOOTŁ؛2 3 4 5 10 11 12 USB D-: 7 USB D+: 8 Spread Press [ Save ] to save Pinout Total expend 1 seconds ... ->#........... ... Press [ Save ] to save Pinout [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box If Scan other phone, please click [Stop] [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Not support,Please Try other boot. Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810(FFFFFFFF) Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Start Writing... Write Done! [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box Boot Not support. Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810 Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Check firmware,Wait... Analyzed Completed. Factory Setting... Done. Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810 Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Start Writing... Write Done! Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Reapply Pinouts to Box or Pwr on/off [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810 Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Check firmware,Wait... Analyzed Completed. Factory Setting... Done. Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810 Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Start Writing... Write Done! Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Reapply Pinouts to Box or Pwr on/off [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box [G:1 3 9 11 D-:7 D+:8 Up:2 4 5 10 12] Apply to Box Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM24 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208810 Flash Model ST M58WR064ET Flash Size 0x800000(8.0M) Check firmware,Wait... Done.. Start Formatting,Wait... Start Addr:7A0000 Size:40000 Format Done. |
04-01-2011, 14:00 | #73 (permalink) |
Member: 1536420 Status: Offline Thanks Meter: 42 | Successfully WRITE FLASH FILE MTK6253 The File Information: UNISCOPE53_09A_PCB01_GPRS_MT6253_S00.V52B99.BIN >> Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6253 Ver: 8A02 SW:8A00 CPU ID: 00000F00 Initialize Boot6 ... Flash(Nor) Type [TOSHIBA] TC58FYM7T8C Flash(Nor) Code 0098009E(00000000) Flash(Nor) Size 0x01000000 Hex Bytes Checking baud،* Set Baud:921600 Done. Start Writing(Nor)... Write Done ! Time used: 4 m 27 s |
04-14-2011, 14:19 | #74 (permalink) |
Member: 1536420 Status: Offline Thanks Meter: 42 | success read flash file MTK 6253 Start Scanning... ->. Results: CPU: MT6253. VCC:8,GND:10,RXD:3,TXD:1 [V:8 G:10 R:3 T:1] Apply to Box Comm Error 001efinitions may be incorrect, to scan again Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6253 Ver: 8A02 SW:8A00 CPU ID: 00000F00 Initialize Boot6 ... Flash(Nor) Type [INTEL] PF38F30xxM0x1xx Flash(Nor) Code 00898903(00000000) Flash(Nor) Size 0x01000000 Hex BytesChecking baud،* Set Baud:921600 Done. Start Reading(Nor)... Read Done ! Time used: 4 mins 16 s File Saved: D:\China Flash Files.mcn\al-namer\al-namer.bin |
04-14-2011, 14:23 | #75 (permalink) |
Member: 1536420 Status: Offline Thanks Meter: 42 | Success read nv file mtk 6253 Press and Holding Power button now ! Connecting, wait... CPU: 6253 Ver: 8A02CPUID: 00000F00 Release Power Button now Phone detected Infr: MT6253_V52B04_09A_HW_Melody_V0.0 NV Data saved to: D:\China Flash Files.mcn\al-namer\NV_MT6253_V52B04_09A_HW_Melody_V0.0 Backup Done. |
