-   McnPro Box (http://forum.gsmhosting.com/vbb/f532/)
-   -   Successfully unlocked/repaired phones by Mcnpro Box ! (http://forum.gsmhosting.com/vbb/f532/successfully-unlocked-repaired-phones-mcnpro-box-1132408/)
fokal2008 04-25-2009 19:49
good work with mcnpro you are the tools for chiness mobile
see logs
Writing, Please Power Off & On
Connected
Boot Information:
downloading Boot
CPU Type: 6600D
Flash Type: SAMSUNG K5L2931CAM
Flsh Size??01000000(Hex Bytes)
Baudrate set to:921600
Erase Nor Flash...
Erase OK??Time: 97 s
Writing(amd Nor)...
Write OK
>>Time£º 35 m27 s
i need to say tanks for phonecarecenter!!!!!!!
big tanks for you helps
fokal2008 05-04-2009 17:32
SPD FORMATING OK WITH MCNPRO BOX.
Formatting, Please Power Off & On
Connected
Boot Information:
downloading Boot
CPU Type: 6600D
Formatting Nor Flash...
>>Nor Format completed
fokal2008 05-04-2009 17:35
MTK FORMATING OK WITH MCNPRO BOX.
MODE VOL AFTER FORMATING OK PHONE WILL WORK PERFECTLY
you can Set Formatting Addr manully
Please Hold "ON" to connect with the phone...
Connected to Phone.
CPU??6223 Ver: 8A04
CPU ID??7BDE0C00
Downloading Boot...
Nor Flash Code: 00EC257E(25062501)
Nor Flash Size: 0x00800000 Hex Bytes
INT/EXT RAM Size: 0x0000A000+0x00400000
Format Start Addr??0x700000, Size: 0x100000
>>Formatted OK.
PhoneCareCenter 07-13-2009 16:41
MTK 6223 CPU
Read Firmware:
<<if CPU is 6223D May Be Not Supported>>
Connected to Phone.
CPU: 6223 Ver: 8A05 SW:8A00
CPU ID: 7E8C0C00
Downloading Boot...
Nor Flash Code: 0001227E(22212201)
Nor Flash Size: 0x01000000 Hex Bytes
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
Read OK.
>>total: 4 mins23 s
Formating:
Connected to Phone.
CPU ID: 7E8C0C00
Downloading Boot...
Format Start Addr: 0xC40000, Size: 0x3C0000
>>Formatted OK.
McnPro Team
PhoneCareCenter 07-13-2009 16:53
Spreadtrum 6600D
Pinout Detection:
Scanning (please waiting...)
Scanning results:
VCC:14,GND:4,RXD:8,TXD:6,BOOT:10
>>[V:14 G:4 10 R:8 T:6] Apply to Box
Formatting:
Connected
Boot Information:
downloading Boot
CPU Type: 6600D
Flsh Size£؛01000000(Hex Bytes)
McnPro Team
Spreadtrum 6600D
Pinout Detection:
Scanning results:
Formatting:
Connected
Boot Information:
downloading Boot
CPU Type: 6600D
McnPro Team
PhoneCareCenter 07-13-2009 17:08
MTK 6225 CPU
Pinout Detection:
Scanning results:
CPU: 6225
VCC:1,GND:3 8,RXD:7,TXD:6
>>[V:1 G:3 8 R:7 T:6] Apply to Box
Reading Firmware:
Connected to Phone.
CPU: 6225 Ver: 8A05 SW:8A00
CPU ID: 03DD0800
Downloading Boot...
Nor Flash Code: 00980003(00000000)
INT/EXT RAM Size: 0x0000C000+0x00400000
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
Read OK.
>>total: 4 mins23 s
Formatting:
Connected to Phone.
CPU ID: 03DD0800
Downloading Boot...
Format Start Addr: 0xE00000, Size: 0x200000
>>Formatted OK.
McnPro Team
Mcnbox 07-18-2009 16:25
MTK 6223 :
Detail :
LC6223_07A_PCB01_GSM_MT6223_S00.MAUI_07A_W07_36_MP _V13.BIN
Scan RX TX:
  Scanning results:
  CPU: 6223
  GND:5,RXD:3,TXD:2
>>[G:5 R:3 T:2] Apply to Box
Reading :
  Connected to Phone.
  CPU ID: 56100C00
  Downloading Boot...
  Verifying Baud...
  Set Baud:921600 OK.
  Reading(Nor)...
  Read OK.
>>total:  2 mins8 s
Flash phone:
  Connected to Phone.
  CPU ID: 56100C00
  Downloading Boot...
  Verifying Baud...
  Set Baud:921600 OK.
  Proceding MTK6223 CPU encryption...
  the file is no encrypt 1
  Writing(Nor)...
  Write OK.
  Total:  4 mins16 s
Mcnbox 08-25-2009 17:55
Reading phone General Information.
Reading phone General Info:
Scan RX TX:
  Welcome to use McnBox!
  serial port now: COM5
  S/N:MCN200xxxxxx - xxxx Firmware Ver:V1.04 CheckSum:xxxx-xxxx
  Box Connected !
  The Box High-speed Serial port: COM5
  Scanning results:
  CPU: MT6226BA.
  VCC:6,GND:1 10,RXD:12,TXD:7
>>[V:6 G:1 10 R:12 T:7] Apply to Box
Read General Info:
  Connected to Phone.
  CPU: 6226 Ver: 8A02  SW:8A01
  CPU ID: 41DC7088
  Downloading Boot...
  Nor Flash Code: 00EC257E(25082501)
  INT/EXT RAM  Size: 0x00047000+0x00400000
>>Keep the phone on, if you do other operation
Mcnbox 08-25-2009 17:58
Pickroof lock Code
Pickroof lock Code:
  Connected to Phone.
  CPU: 6226 Ver: 8A02
  CPUID: 41DC7088
  Read Information From the Phone...
>>Have not found Pickroof lock Code of this phone
PhoneCareCenter 08-26-2009 17:04
Pinout Scan
Scanning results:
CPU: MT6226BA.
VCC:4 5,GND:6 17 18,RXD:12,TXD:10
>>[V:4 5 G:6 17 18 R:12 T:10] Apply to Box
Read Flash
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
Read OK.
total: 4 mins21 s
Format
Connected to Phone.
CPU ID: 391B11D2
Downloading Boot...
Formatted OK.
Fast & Easy
McnPro Team
Mcnbox 08-30-2009 00:03
6600m SPD with new beta version 2.7.1 reading /backup
Connecting...
Connected
Loading Boot...
CPU    Type: 6600M/E
Flash  Type: Nor
Flash    ID: 00EC257E(25082501)
Flash  Size: 1000000(16m)
Flash Model: K5l6331CAM
Reading...
Operation completed
Mcnbox 08-30-2009 00:08
6600m SPD with new beta version 2.7.1 flashing
Connecting...
Connected
Loading Boot...
CPU    Type: 6600M/E
Flash  Type: Nor
Flashing...
Operation completed
Mcnbox 10-28-2009 20:33
Test MTK Chipset CPU: MT6229
Scan RX TX :
  Selected COM16
  Initialize in progress...
  Checking data, wait...
  Serial number: MCN200xxxxx - xxxxx
  Firmware version: V1.05
  Checksum value: 3883-xxxx
  Box Connected!
  Box Operating at high speed port: COM16
  Start Scanning...
  Scan Results:
  MTK Chipset CPU: MT6229.
  VCC:1 2,GND:8 11 15,RXD:5,TXD:6
>>[V:1 2 G:8 11 15 R:5 T:6] Apply to Box
Mcnbox 10-28-2009 20:35
Read General Info:
  Connected to Phone.
  CPU: 6229 Ver: 8A02  SW:8A02
  CPU ID: 02200101
  Downloading Boot...
  Nand Flash Type: [TOSHIBA] TC58NVG0S3AFT
  Nand Flash Code: 009800F1(00800095)
  Nand Flash Size: 0x08400000 Hex Bytes
  INT/EXT RAM  Size: 0x00020000+0x00000000
Page generated in 0.44073 seconds with 5 queries
