Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnPro Box
Old 10-28-2009, 22:11   #16 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Backup /Reading :
  Verifying Baud...
  Set Baud:921600 OK.
  Reading(Nand)...
  Read OK.
  total: 27 mins 5 s
  Save Path:D:\files\MT6229_TOSHIBA_TC58NVG0S3AFT_Tv_mobile.bin
>>Keep the phone on, if you do other operation
Because this is Tv mobile, The flash is 132MB, when Backup /Reading you need wait a little long time !
The Following User Says Thank You to Mcnbox For This Useful Post:
Old 10-28-2009, 22:27   #17 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Test Mt6235 TOSHIBA TV mobile
Scan RX TX:
  Start Scanning...
  Scan Results:
  MTK Chipset CPU: MT6235.
  VCC:17 18,GND:1,RXD:10,TXD:12
  [V:17 18 G:1 R:10 T:12] Apply to Box
Read General info:
  Please Hold "ON" to connect with the phone...
  Connected to Phone.
  CPU: 6235 Ver: 0001  SW:8A01
  CPU ID: 00000320
  Downloading Boot...
  Nand Flash Type: [TOSHIBA] TC58NWG0S8C
  Nand Flash Code: 009800C0(008000D5)
  Nand Flash Size: 0x04200000 Hex Bytes
  INT/EXT RAM  Size: 0x00010000+0x00000000
Old 10-28-2009, 22:33   #18 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Reading / Backup:
  Connected to Phone.
  CPU ID: 00000320
  Downloading Boot...
  Verifying Baud...
  Set Baud:921600 OK.
  Reading(Nand)...
  Read OK.
  total: 5 mins 25 s
Old 10-28-2009, 22:52   #19 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Test Infineon 7870
Scan Rx TX:
  Start Scanning...
  Scan Results:
  GND:9 10,RXD:5,TXD:1
>>[G:9 10 R:5 T:1] Apply to Box
Reading / Backup:
  Power On...
  Connected OK
  Downloading boot...
  Load boot OK
  BaudRate : 921600 OK.
  Send data to phone...
  Flash   ID: 00EC22E0
  Flash Type: SAMSUNG K5A6317CT(K5J6316CT)
  Flash Size: 0x00800000
  reading...
  read Completed
  Time: 3 m0 s
>>File Save to : D:\files\Infineon_7870.bin
Old 10-28-2009, 22:54   #20 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Flashing:
  Power On...
  Connected OK
  Downloading boot...
  Load boot OK
  Flash   ID: 00EC22E0
>>flashing...
Unlock :
  Scaning password...
  Possible Password:
  2727
  08573
>>Scan completed.
Old 11-10-2009, 08:01   #21 (permalink)
bestncheap's Avatar
Member: 19785
Thanks Meter: 1,242
Thumbs up Successfully unlocked/repaired phones by Mcnpro Box !
This The phone
this the log
Scan Pinout
CPU: MT6235.
VCC:5,GND:4 7,RXD:10,TXD:9
>>[V:5 G:4 7 R:10 T:9] Apply to Box
Read Flash
Connected to Phone.
CPU ID: 00000300
Downloading Boot...
Nand Flash Type: [HYNIX] HY27UF082G2M/A
Nand Flash Code: 009800F0(00800095)
Verifying Baud...
Set Baud:921600 OK.
Reading(Nand)...
Read OK.
total: 30 mins41 s
Save Path:F:\BACKUP CHINA\Aego\Aego-i50
BnC
The Following User Says Thank You to bestncheap For This Useful Post:
Old 12-24-2009, 11:54   #22 (permalink)
Member: 923150
Thanks Meter: 4
Start Scanning...
Scan Results:
Type:5212
GND:1 2 3,RXD:8,TXD:7
>>[G:1 2 3 R:8 T:7] Apply to Box
Power On...
Connected OK
Loading boot...
Baud Rate:921600 Ok!
Flash ID: 0020880D
Flash Type: ST M36L0R8060T1
Flash Size: 0x2000000
Uploading...
Upload Completed
>>File Save to :C:\Program Files\Mcnbox Team\NX-200D.cla
Good Job McnPro Box...
The Following User Says Thank You to Saudara For This Useful Post:
Old 11-03-2010, 19:10   #23 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Successfully unlocked/repaired phones by Mcnpro Box !
Here is the Thread which for post Successfully unlocked/repaired phones by Mcnpro Box ! Lets see how our box Powerful 、Professional and easily to use !
Thanks for your Suppot !
Best regards !
Mcnbox
The Following 4 Users Say Thank You to Mcnbox For This Useful Post:
Old 11-03-2010, 19:15   #24 (permalink)
hacell's Avatar
Member: 1150088
Sonork: ============
Thanks Meter: 254
Etouch 505 pro dead
Firts post repair E Touch 505 TV pro....
Welcome to use McnBox!
Selected COM3
Baud setting ...
Set Baud done
Initialize in progress ...
Checking data ...
Serial No. MCNXXXXXXXXXX
Firmware V1.08
Checksum 79C1-59BE
Box Connected!
Ready working at COM3
Start Scanning...
Results:
MTK Chipset CPU: MT6225.
VCC:1,GND:10,RXD:3,TXD:9
[V:1 G:10 R:3 T:9] Apply to Box
Phone detected, wait..
CPU: 6225 Ver: 8A05 SW:8A00
CPU ID: 03EB0200
Initialize Boot4 ...
Flash(Nor) Type: [TOSHIBA] TV00570002CDGB, TC58FVM7TDD
Flash(Nor) Code: 00980003(00000000)
Flash(Nor) Size: 0x01000000 Hex Bytes
Checking baudí*
Set Baud:921600 Done.
Start Reading(Nor)...
The phone information:
K370M00_PCB01_GPRS_MT6225_S00.M_RK3766711_M28102_V 1_1_0_0M1127.BIN
Read Done !
Time used: 4 mins13 s
File Saved: E:\Firmware China & Software\File\eTouch\K370M00_PCB01_GPRS_MT6225_S00 .M_RK3766711_M28102_V1_1_0_0M1127.BIN
Press and Holding Power button now !
Connecting, wait...
CPU ID: 03EB0200
Start Formatting (Nor)...
Start Addr: 0xE00000, Size: 0x200000
Format Done !
After format handset alive and to repair invalid sim repair imei with tick 2nd method
2nd method, please turn off the phone before rd/wr
Connecting, wait...
CPU: 6225 Ver: 8A05
CPUID: 03EB0200
Release Power Button now
Phone detected
Wr IMEI1 Done: 35206204002521-9
Connecting, wait...
CPU: 6225 Ver: 8A05
CPUID: 03EB0200
Phone detected
Wr IMEI2 Done: 35206204004622-3
hacell
The Following 3 Users Say Thank You to hacell For This Useful Post:
Old 11-04-2010, 10:28   #25 (permalink)
hacell's Avatar
Member: 1150088
Thanks Meter: 254
Post Nexian G 922 LCD blank
Serial No. MCNxxxxxxxxx
Firmware V1.08
Checksum 79C1-59BE
Box Connected!
[V:8 G:1 R:13 T:6] Apply to Box
Connecting, wait...
CPU: 6223 Ver: 8A05 SW:8A00
CPU ID: D5860C00
Please select Boot5
Checking baudí*
TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E01A_NO AM_PR_R1_0_V17_INDONESIA.BIN
Read Done !
Time used: 4 mins14 s
File Saved: E:\Firmware China & Software\File\Nexian\G 800\TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E01 A_NOAM_PR_R1_0_V17_INDONESIA.BIN
Connecting, wait...
CPU ID: D5860C00
Please select Boot5
Start Addr: 0xE00000, Size: 0x1F0000
Format Done !
hacell
Old 11-06-2010, 04:40   #26 (permalink)
Member: 503304
Sonork: 100.1585733
Thanks Meter: 34
Format mßy H688 MT6205 SPANSION
QMOBILE ME114
Qmobile q130
Format Imobile TV 640 mt6235
Post logs here only !
The Following 4 Users Say Thank You to hohoangkhoi For This Useful Post:
Old 11-12-2010, 08:46   #27 (permalink)
hacell's Avatar
Member: 1150088
Thanks Meter: 254
Talking Nexcom 689 dead
Selected COM3 COM9
Baud setting ...
Set Baud done
Checking data ...
Firmware V1.08
Checksum 79C1-59BE
Box Connected!
[G:5 R:4 T:3] Apply to Box
Connecting, wait...
CPU ID: B3460C00
Please select Boot5
Checking baudí*
MAGCOMM23C_09A_PCB01_GPRS_MT6223P_S00.F96Z08NEXV01 _01B04.BIN
Read Done !
File Saved: E:\Firmware China & Software\File\NEXCOM\NC689\MAGCOMM23C_09A_PCB01_GP RS_MT6223P_S00.F96Z08NEXV01_01B04m.BIN
Connecting, wait...
CPU ID: B3460C00
Please select Boot5
Format Done !
hacell
The Following 2 Users Say Thank You to hacell For This Useful Post:
Old 12-02-2010, 11:28   #28 (permalink)
gulka's Avatar
Member: 276322
Thanks Meter: 272
SPD Nokia C2-00
Please add support for changing and editing the language and fonts
[G:10 D-:4 D+:6 oL:1 2 oI:3 5 7 9] Apply to Box
Checking SCI USB2Serial port, wait...
SCI USB2Serial Port: COM95
Connecting, wait...
Phone Connected!
Info: Spreadtrum Boot Block version 2.0
Initialize boot...
CPU Info 6600L/WT6226
Flash Type NOR
Flash ID 00980096(00003400)
Flash Model TOSHIBA TV00560002EDGB
Flash Size 0x800000(8,0M)
Start Writing...
Write Done!
http://www.rapidshare.com/files/434437625/c2.rar
The Following User Says Thank You to gulka For This Useful Post:
Old 12-04-2010, 09:37   #29 (permalink)
gulka's Avatar
Member: 276322
Thanks Meter: 272
Fly Q110 TV
Start Scanning...
Results:
CPU: MT6223.
GND:8 10,RXD:3,TXD:1
[G:8 10 R:3 T:1] Apply to Box
CPU ID: 8A640C00
Please select Boot5
Flash(Nor) Type: [SPANSION] S71PL127N
Flash(Nor) Code: 0001227E(22202200)
Checking baudЎ*
TINNO23C_08B_GEMINI_PCB01_GPRS_MT6223_S00.Q110_PR_F1_FLY_06_07.BIN
Read Done !
Time used:  4 mins15 s
File Saved: D:\TINNO23C_08B_GEMINI_PCB01_GPRS_MT6223_S00.Q110_PR_F1_FLY_06_07.BIN
The Following 2 Users Say Thank You to gulka For This Useful Post:
Old 12-07-2010, 11:26   #30 (permalink)
karismajaya's Avatar
Member: 42805
Thanks Meter: 16
nexian G923
1 phone = restart
1 phone other = dead phone
success all
use boot 5, baut 921600
Selected COM26
Baud setting ...
Set Baud done
Checking data ...
Serial No. MCNxxxxxxxxxxxx
Firmware V1.08
Checksum CF7E-E6BE
Box Connected!
Ready working at COM26
Start Scanning...
Results:
CPU: MT6225.
The File Information:
TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E506B_PR1 _F1_WAM_ID_TELKMOSEL_01_02.BIN
Connecting, wait...
CPU ID: 03060400
Initialize Boot5 ...
Flash Type: [SPANSION] S29WS256N
Flash(Nor) Code: 0001227E(22302200)
Flash(Nor) Size: 0x02000000 Hex Bytes
Set Baud Done
Start Writing(Nor)...
Write Done !
The Following 3 Users Say Thank You to karismajaya For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.59779 seconds with 8 queries
