Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnPro Box
Old 04-14-2011, 15:46   #76 (permalink)
Member: 1536420
Thanks Meter: 42
Success read flsh flie spd cpu
Welcome to use McnBox!
Selected COM21
Baud setting ...
Set Baud done
Initialize in progress ...
Checking data ...
Serial No. MCN*******
Firmware V1.09
Checksum ******
Box Connected!
Ready working at COM21
Scanning pin status,please waiting...
Pin-status Scan Done
Scanning,waiting...
Operation done, Pin detect out.
BOOT : 8 USB D-: 4 USB D+: 6 Spread
Total expend 93 seconds
Press [ Save ] to save Pinout
[G:10 D-:4 D+:6 Up:2 3 5 9 11 12 13 14 Down:1 7 8] Apply to Box
If Scan other phone, please click [Stop]
Checking SCI USB2Serial port, wait...
SCI USB2Serial Port: COM24
Connecting, wait...
Phone Connected!
Info: Spreadtrum Boot Block version 2.0
Initialize boot...
Boot Not support,Please Try other boot.
Connecting, wait...
Phone Connected!
Initialize boot...
CPU Info 6600L/WT6226
Flash Type NOR
Flash ID 00980003(00000001)
Flash Model TOSHIBA TV00570002CDGB
Flash Size 0x1000000(16.0M)
Start Reading...
Read Done!
File saved: D:\MUSIC\6600L_WT6226_TOSHIBA TV00570002CDGB.bin
The Following User Says Thank You to ranen telecom For This Useful Post:
Old 04-27-2011, 16:28   #77 (permalink)
fcs
Member: 223545
Thanks Meter: 2
THANKS MCN
HP IMO W8000
Selected COM4
Baud setting ...
Set Baud done
Checking data ...
Serial No. MCN20100xxxxxx
Firmware V1.09
Checksum C17C-E4BE
Box Connected!
Ready working at COM4
Start Scanning...
Results:
CPU: MT6268.
GND:6,RXD:5,TXD:4
[G:6 R:5 T:4] Apply to Box
READ==============
Press and Holding Power button now !
Connecting, wait...
Phone detected, wait..
CPU: 6268 Ver: 8B01 SW:8B01
CPU ID:
Initialize Boot6 ...
Flash(Nand) Type [ST] NAND01GR3B
Flash(Nand) Code 002000A1(00000015)
Flash(Nand) Size 0x08400000 Hex Bytes
Checking baud¡*
Set Baud:921600 Done.
Start Reading(Nand)...
Read done !
total: 37 mins 1 s
File saved: C:\Documents and Settings\attack\My Documents\imo w8000.bin
FORMAT==================================
Connecting, wait...
CPU ID:
Start formatting (Nand) ...
Formatting Nand Flash...2000000--5FFFFFF
Format (nand) Done!
WRITE IMEI=============================
Phone should be Switched on
Phone detected, wait...
SN to be changed...
Done, SN1: 35357404193435-4
SN to be changed...
Done, SN2: 35357404194435-0
The Following User Says Thank You to fcs For This Useful Post:
Old 05-03-2011, 14:41   #78 (permalink)
hacell's Avatar
Member: 1150088
Sonork: ============
Thanks Meter: 254
read, backup and format MTK 6238
Selected COM3
Baud setting ...
Set Baud done
Checking data ...
Serial No. MCN2xxxxxxxxx
Firmware V1.09
Checksum 79C1-59BE
Box Connected!
Ready working at COM3
Start Scanning...
Results:
MTK Chipset CPU: MT6238.
GND:3,RXD:1,TXD:5
[G:3 R:1 T:5] Apply to Box
Connecting, wait...
CPU: 6238 Ver: 0001 SW:8A00
CPU ID: 00000D00
Initialize Boot4 ...
Flash(Nand) Type [HYNIX] HY27UF16561A/M
Flash(Nand) Code 009800C1(009000D5)
Checking baud¡*
Read done !
Time used: 61 mins 5 s
File saved: E:\Firmware China & Software\File\K-touch\E329\E329
Connecting, wait...
CPU ID: 00000D00
Formatting Nand Flash...3200000--4DFFFFF
Format (nand) Done!
Handset restar and not connect internet after format handset normally
hacell
The Following User Says Thank You to hacell For This Useful Post:
Old 05-06-2011, 06:44   #79 (permalink)
hacell's Avatar
Member: 1150088
Thanks Meter: 254
Change imei MTK 6223 ic flash toshiba
Handset problem searching network because imei empty
Selected COM3 COM27
Baud setting ...
Set Baud done
Checking data ...
Serial No. MCN2xxxxxxxxxx
Firmware V1.09
Checksum 79C1-59BE
Box Connected!
[V:4 G:5 R:3 T:2] Apply to Box
Connecting, wait...
CPU: 6223 Ver: 8A05 SW:8A00
CPU ID: 61BF0C00
Please select Boot5
Flash(Nor) Type: [TOSHIBA] TV00570002CDGB, TC58FVM7TDD
Flash(Nor) Code: 00980003(00000000)
Flash(Nor) Size: 0x01000000 Hex Bytes
Start Formatting (Nor)...
Start Addr: 0xE00000, Size: 0x200000
Format Done !
SN to be changed...
OK, SN1: 35610100518541-2
The File Information:
LIWAA23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.M2T_MT2 3P_825_G10_COMBO_V01_17.BIN
Checking Unlock Code, wait...
Press [STOP] to exit
Connecting, wait...
CPU ID: 61BF0C00
Please select Boot5
Checking baud¡*
Set Baud:921600 OK.
Start Writing(Nor)...
Write Done !
Time used: 8 m 38 s
SN to be changed...
OK, SN2: 35610100518541-2
Just format and rebuild imei
hacell
Old 05-06-2011, 14:48   #80 (permalink)
hacell's Avatar
Member: 1150088
Thanks Meter: 254
MTK 6268 with ic flash toshiba
Selected COM3
Baud setting ...
Set Baud done
Checking data ...
Serial No. MCN2xxxxxxxxxxxxx
Firmware V1.09
Checksum 79C1-59BE
Box Connected!
Start Scanning...
Results:
CPU: MT6268.
GND:7,RXD:3,TXD:2,BOOT:1
[G:7 R:3 T:2 Up:1] Apply to Box
CPU ID:
Initialize Boot7 ...
Flash(Nand) Type [TOSHIBA] TC58NWG0S8C
Flash(Nand) Code 009800C1(00900055)
Formatting Nand Flash...4000000--3FFFFFF
Format (nand) Done!
Used boot 7, format and done
no need format manual and no project id not found. Just very simple
hacell
Old 05-09-2011, 13:45   #81 (permalink)
Member: 1406655
Thanks Meter: 4
Read, backup and format LG GB270 100% OK
Selected COM79
Baud setting ...
Set Baud done
Checking data ...
Serial No. MCNxxxxxxxxxxxxxxxxxx
Firmware V1.09
Checksum 48F9-61BE
Box Connected!
Ready working at COM79
Start Scanning...
Results:
MTK Chipset CPU: MT6226BA.
VCC:9 10,GND:1 18,RXD:16,TXD:17,BOOT:2
[V:9 10 G:1 2 18 R:16 T:17] Apply to Box
CPU: 6226 Ver: 8A02 SW:8A01
CPU ID: 68FEAC23
Flash(Nor) Type [INTEL] PF48F40xxM0x0xx
Flash(Nor) Code 00898901(00000000)
Flash(Nor) Size 0x02000000 Hex Bytes
Checking baud،*
Start Reading(Nor)...
The phone information:
A7220_PCB01_GPRS_MT6226_S01.GB270-00-V10E-ESA-XX-AUG-03-2009.BIN
Read Done !
Time used: 8 mins 20 s
File Saved: C:\Documents and Settings\Admin\Desktop\A7220_PCB01_GPRS_MT6226_S01 .GB270-00-V10E-ESA-XX-AUG-03-2009.BIN
Connecting, wait...
CPU ID: 68FEAC23
Auto Format Addr
Start Addr: 0x1E00000, Size: 0x200000
Format Done !
The Following 2 Users Say Thank You to tungnx For This Useful Post:
Old 05-10-2011, 08:33   #82 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Today i'm very happy with mcnpro updat to 3.07
is the best for update.
now 1 click button tuch calibration can repair tuch
thank so much mcnbox team.
Start Scanning...
Results:
MTK Chipset CPU: MT6225.
GND:4,RXD:8,TXD:5,BOOT:1
[G:4 R:8 T:5 Up:1] Apply to Box
Connecting, wait...
CPU: 6225 Ver: 8A05
CPUID: 03AC0500
Release Power Button now
Phone detected
Done
The Following 2 Users Say Thank You to 089999945 For This Useful Post:
Old 05-10-2011, 10:50   #83 (permalink)
Member: 1535842
Thanks Meter: 3
Sukses read/format/write imei C6-00 MT6253
Read
Start Scanning...
Results:
MTK Chipset CPU: MT6253.
GND:5,RXD:3,TXD:4
[G:5 R:3 T:4] Apply to Box
Connecting, wait...
CPU: 6253 Ver: 8A02  SW:8A00
CPU ID: 00000F00
Flash(Nor) Type  [SAMSUNG] K5N2833ATB
Flash(Nor) Code  00EC2404(00000000)
Flash(Nor) Size  0x01000000 Hex Bytes
Checking baud...
MTK53_09A_GEMINI_PCB01_GPRS_MT6253_S00.HX918B_F_BQ12_KL_RQ_V03.BIN
Read Done !
Time used:  4 mins 12 s
File Saved: D:\Flasher\MCN\Read\C6-00_MTK53_09A_GEMINI_PCB01_GPRS_MT6253_S00.HX918B_F_BQ12_KL_RQ_V03
Format/Write Imei
Start Scanning...
Results:
GND:5,RXD:3,TXD:4
Connecting, wait...
CPU ID: 00000F00
Start Addr: 0xF00000, Size: 0x100000
Format Done !
SN to be changed...
Done, SN1: 35751201120115-2
2nd method, please turn off the phone before rd/wr
Connecting, wait...
CPU: 6253 Ver: 8A02
CPUID: 00000F00
Phone detected
Wr IMEI2 Done: 35751201120115-1
Selected COM6
Baud setting ...
Set Baud done
Checking data ...
Serial No. MCN20XXxxxxxxxxx
Firmware V1.10
Checksum 3781-19BE
Box Connected!
Ready working at COM6
The Following User Says Thank You to animaxcell For This Useful Post:
Old 05-10-2011, 16:06   #84 (permalink)
Member: 562132
Thanks Meter: 86
V 3.07 IT.S GOOD AND MORE FAST
MOBILE BERYLE CAN,T BOOT AT 3.06 BUT BOOT GOOD AT V3.07
Selected COM30 COM5
Baud setting ...
Set Baud done
Checking data ...
Serial No. MCN2008xxxxxxxx
Firmware V1.10
Checksum 942F-B7BE
Box Connected!
Ready working at COM30
Start Scanning...
Results:
GND:8 10,RXD:1,TXD:3,BOOT:5
[G:5 8 10 R:1 T:3] Apply to Box
Connecting, wait...
Phone Connected!
Initialize boot...
Boot Error. ID: s0006
Connecting, wait...
Phone Connected!
Initialize boot...
Connecting, wait...
Phone Connected!
Initialize boot...
CPU Info 6600L/WT6228
Flash Type NOR
Flash ID 002088C0(FFFFFFFF)
Flash Model ST M58WR064HU
Flash Size 0x800000(8.0M)
Check firmware,Wait...
Privacy Code: 5
Privacy Code: 1234
Connecting, wait...
Phone Connected!
Initialize boot...
Flash Type NOR
Start Reading...
Read Done!
File saved: E:\flashes\china read good\spread good\BERYL G602\6600L_WT6228_ST M58WR064HU.bin
THANKS MCN PRO TEAM
The Following User Says Thank You to almalizy For This Useful Post:
Old 05-10-2011, 18:27   #85 (permalink)
Member: 562132
Thanks Meter: 86
X6I 4SIM
Selected COM30 COM5
Baud setting ...
Set Baud done
Checking data ...
Serial No. MCN20xxxxxxxxxxxx
Firmware V1.10
Checksum 942F-B7BE
Box Connected!
Start Scanning...
Results:
VCC:3,GND:9 12,RXD:7,TXD:6
[V:3 G:9 12 R:7 T:6] Apply to Box
Connecting, wait...
CPU ID: 00000F00
Flash(Nor) Type [INTEL] PF38F30xxM0x1xx
Flash(Nor) Code 00898903(00000000)
Checking baud...
HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00.B052-2E_L138_V102.BIN_FLNPF38F3040M0Y3DE
Read Done !
Time used: 4 mins 13 s
File Saved: E:\flashes\china read good\4 SIM\X6I\HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00. B052-2E_L138_V102.BIN_FLNPF38F3040M0Y3DE
Connecting, wait...
CPU: 6253 Ver: 8A02
CPUID: 00000F00
Phone detected
Infr: MT6253_B052-2E_L138_V102_HEXING53_09A_GEMINI_HW_Melody_V0.0
NV Data saved to: E:\flashes\china read good\4 SIM\X6I\NV_MT6253_B052-2E_L138_V102_HEXING53_09A_GEMINI_HW_Melody_V0.0
Backup Done.
TANKS MCNPRO
Old 05-10-2011, 19:22   #86 (permalink)
Member: 562132
Thanks Meter: 86
F600 TINMO
Start Scanning...
Results:
SPD Chipset
VCC:16,GND:1 5,RXD:11,TXD:13,BOOT:15
[V:16 G:1 5 15 R:11 T:13] Apply to Box
Connecting, wait...
User Abort
Connecting, wait...
User Abort
Connecting, wait...
User Abort
Detect Charge-pin...
Vcc-Pin16 Set to empty
Detect Charge-pin complete
Scanning,waiting...
USB D-: 9 USB D+: 8 Spread
Total expend 4 seconds
BOOT: 11 set as oInvert
USB D-: 9 USB D+: 8 GND:1 5
[G:1 5 11 D-:9 D+:8] Apply to Box
SCI USB2Serial Port: COM34
Connecting, wait...
Phone Connected!
Initialize boot...
Connecting, wait...
Connecting, wait...
Phone Connected!
Initialize boot...
Flash Type NOR
Start Reading...
Read Done!
File saved: E:\flashes\china read good\spread good\F600 LCK CODE IS\6600L_WT6226_TOSHIBA TV00570002CDGB.bin
Analysing,Wait...
Unlock Code: 1111
Privacy Code: 1234
Unlock Code: 147369
Connecting, wait...
User Abort
Old 05-11-2011, 16:21   #87 (permalink)
Member: 562132
Thanks Meter: 86
n95y zetel
i can.t calibriat touch at mcn pro v 3.6
and i can.t at spider and at infinity china miracle
but now i do that at mcn pro v 3.7
Start Scanning...
Results:
CPU: MT6225.
VCC:13,GND:12,RXD:14,TXD:1
[V:13 G:12 R:14 T:1] Apply to Box
Connecting, wait...
CPU: 6225 Ver: 8A03
CPUID: 038A0900
Phone detected
Done
tanks mcnpro team
very nice updat
Old 05-16-2011, 09:44   #88 (permalink)
Member: 1536420
Thanks Meter: 42
SPD Flash Model ESMT_MX29GL064E
Selected COM21
Baud setting ...
Set Baud done
Checking data ...
Serial No. **************
Firmware V1.10
Checksum ****-****
Box Connected!
Connecting, wait...
Phone Connected!
Initialize boot...
Flash Type NOR
Flash ID 00C2227E(220C2201)
Start Reading...
Read Done!
File saved: D:\CHINA FLASH FILE COLLECT\China Flash Files.MCN\forme_d80\6600L_WT6228_ESMT_MX29GL064E.b in
IAM USING GPGDRAGON AS PIN FINDER AND WORK ON MCNPRO
THANKYOU MCNPRO TEAM
Old 05-16-2011, 12:15   #89 (permalink)
PhoneCareCenter's Avatar
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@ranen telecom
Good report, however 6600L CPU detection is fully supported by McnPro Box. U might wanna try scannin RX/TX or USB Mode.
McnPro Team
The Following 2 Users Say Thank You to PhoneCareCenter For This Useful Post:
Old 05-16-2011, 17:23   #90 (permalink)
Member: 1536420
Thanks Meter: 42
HELLO MCNPRO TEAM
THIS CPU WORK PERFECT WITH RX/TX
But this wayforced to open a mobile phone
IN USB SCAN SHOW
Not found "BOOT"
IAM SHORE YOU CAN FIX THIS BUG
Selected COM21
Baud setting ...
Set Baud done
Checking data ...
Serial No. MCN************
Firmware V1.10
Checksum ********
Box Connected!
Scanning,waiting...
USB D-: 3 USB D+: 2 Spread
Total expend 3 seconds
Not found "BOOT"[G:6 D-:3 D+:2] Apply to Box
AFTER SHOW THIS MEESSAGE ICANT DOING ANY THING READ , WRITE ...ETC
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.34947 seconds with 9 queries
