10-14-2009, 16:41 | #36 (permalink) |
Product Manager Join Date: Aug 2007 Location: Inside Java
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | @tiioo852 Full Backup takes 4minutes, which is fast enough. That way all your Customers information is Saved incase anything should go Wrong. Will consider looking into EEprom Backup only. McnPro Team |
11-02-2009, 21:55 | #37 (permalink) |
No Life Poster Join Date: Oct 2003 Age: 43
Member: 40602 Status: Offline Thanks Meter: 118 | One thing when installing new version, could you add an option to save all previous pinouts database? Coz i found out after i installing new version without uninstalling old version. I think this would be great since i lost all of it and regret that i hadn't write it down all the pinouts br, s1emens |
11-03-2009, 03:31 | #38 (permalink) | |
Product Manager Join Date: Mar 2008
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Quote:
Software already have the functions which can export / import all the pinouts database , you can saving that anytime as wished , Every customer can sharing the pinouts database for each others. And when you install the new version , if you did not uninstall the old version , the database still keep in the computer , never lost ! Check the result and let me know ! Thanks ! Mcnbox team | |
11-03-2009, 16:25 | #39 (permalink) |
Member: 40602 Status: Offline Thanks Meter: 118 | I clearly install the new version and it didn't ask to uninstall previous version, installation goes smoothly. After done, open mcnpro and no pinouts ever saved. Can you tell me which file does the pinout database is kept? so that i can manually backup those files. thanks br, s1emens |
11-03-2009, 20:57 | #40 (permalink) |
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | @s1emens Press Pinouts Tab, then Press Export. Then at Cable Name select All, then Select all & Press Export. Once U install new Version u can then Import the saved Pinouts using the Import Button. Good Luck |
11-10-2009, 16:57 | #43 (permalink) |
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | @sobujkhan Advertisments are being done. Thanks for the Suggestion. McnPro Team Last edited by PhoneCareCenter; 11-10-2009 at 17:03. |
Do you want BB5King to have counter? | Bi0H4z4rD | The Market Feed Back | 22 | 11-08-2008 17:38 |
***to sir .::JaVVaD::. why do you want me to be banned*** | Lucky Titico | The Market Feed Back | 19 | 02-20-2008 10:44 |
What phones do you want to add in new versions of Uni-Dongle? | OvidelGSM | Uni Dongle | 16 | 09-20-2007 13:01 |
What features do you want see in next release(s)? | WotanServer.com | WotanServer | 23 | 11-27-2006 23:59 |
