What is Mcnpro Box ? F.A.Q All in one Thread (Update 11-11-2011) Mcnpro Box F.A.Q All in one Thread: What is Mcnpro box ? McnPro Box is Professional Phone Software Solution, the best software for china mobile . - Support all chinese mobile chips such as MTK, ADI/AD, Spreadtrum, Skyworks, TI(Texas Ins), Infineon, AGERE, OM(Philips), Anyka, CDMA etc.
- Pinfinder was included, Support automatical identification ,Scan the phone's pinouts definition in few seconds.
- Built-in USB detection chip which make USB detection the phone more fast and more accuracy.
- Negative / positive can be converted fully automated. It is more convenient to detect tail socket.
- High speed serial port PL2303 and FT232 and 24pins COM which makes route unlimited.
- Scan VCC, GND, TXD, RXD and high-voltage startup route (or low-voltage startup route).
- Perfect over-voltage protection hardware design
- Standalone software (no Internet connection required)
- Chinese USB stand mode mobile phone feature supported for future
- Automatic box hardware upgrade /repair function supported
- It is a unibox so such some free software you can direct use
MTK(Mediatek) CPU - All MTK CPU based models support
- Write/Read (Backup) Full flash for phones
- Write/Read (Backup/ Restore) NV data for phones
- Write/Read eeprom for phones(MTK Nor flash)
- Write/Read firmware for phones(MTK Nor/Nand flash)
- Smart Write function fast for flash phones(MTK Nor)
- Automatic fix SMS backdoor (First in the world)
- Normal Format phone(Can backup LCD data before format)
- Manual Format phone(Can backup LCD data before format)
- Safely Format (SSF) phone(Can backup LCD data before format)
- Touchscreen calibration (repair phones with damaged touchscreen)
- Can backup LCD data before format after write LCD data back to fix calibration issue
- Can repair "No licensed to produce"
- Direct unlock User/Pf code for phones
- Direct read unlock User/Pf code from firmware, no need connect phone
- Automatic firmware version detection and save original firmware version information in Log file during flash/format
- Automatic CPU/ Chips infomation detection
- Automatic repair/recalculate security area
- Upgrade/downgrade phone firmware
- Repair software-related problems
- Via flash to repair dead phones
- Repair "Bad Software" fault for all MTK Cpu based models
- Can Empty board flashing(After flash chip replacement)
- Save operation process results in Log file
- Can backup/write Phone book by txt file
- Reset phone settings to defaults (factory state)
- Read/write IMEI for all MTK based models
SPD(Spreadtrum) CPU - All Spreadtrum CPU based models support
- Format phone automatic or manual format both support
- Direct unlock User code phones
- Direct read unlock User code from firmware, no need connect phone
- Reset phone settings to defaults (factory state) when flash
- Read/write IMEI for all SPD based models during flash
- Read Phone book direct from file
INF(Infineon) CPU - 7850 7870 7880 Infineon CPU based models support
- Automatic repair/recalculate SIM LOCK
AGE(AGERE) CPU- AGERE CPU based models support
Anyka CPU- 3224 CPU based models support
Si4904 CPU - AMD/SAMSUNG INTEL CPU based models support
- Allow don't change IMEI during flash
ADI/AD CPU - MSP430 Herc/Hermes CPU based models support
SKY(Skyworks) CPU - SKY CPU based models support
TI (Texas Ins) CPU - TI CPU based models support
OM (Philips) CPU - OM(Philips) CPU based models support. eg, 5212UP etc
CDMA (QUALCOMM) - Write/Read (Backup) Full flash for phones
Mstar CPU - Write/Read (Backup) Full flash (Nor/Nand) for phones
- Format phone by automatic or manualy
- Read/write IMEI (First in the world)
AD6905 CPU - Write/Read (Backup) Full flash for phones
- Read/write IMEI for all AD6905 based models
About ChinaRes Editor:
This is free solution for all mcnpro box customer,Can edit your China mobile phone resource, like Language、Ringtons、Photos and Fonts, Working for China Phone Platforms like MTK、 Spreadtrum etc.
Feature:- Spreadtrum (Nand、Nor), MTK Supported
- Translation by dictionary
- Manual translation
- Change language name in the phone menu
- UNICODE Supported
- Media (Photos Ringtons)and fonts Import & Export
- Edit (Customize) Language
Package content :
- 1 pcs Mcnpro box.
- 48 pcs cable.
- 1 pcs 9V DC. |
