Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > McnPro Box
Old 06-27-2009, 12:31   #1 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Arrow Without USB connector how to flash /unlock phone with Mcnpro Box
Cutomer report if Phone without USB connector how to flash /unlock with Mcnpro box .
Here is the step :
1. Don't need to open phone , just check the T/P on the phone , normal beside the SIM card holder or under ticket .
2. Use universal Fbus cable (Nokia) or direct solder the cable on the T/P detect the PINOUT...
( If via universal Fbus cable you need use the service RJ45 Port )
3. Usually those kindly phone have 4 or 5 TP.
4. Select the related cable ,eg. C5T...
5. Then you can doing the things which you wanted .
Enjoy
Logs for phone AUX M822 :
Please Hold "ON" to connect with the phone...
  Connected to Phone.
  CPU:6205 Ver: 8B00 SW:8B00
  CPU ID:
  Downloading Boot...
  Nor Flash Type: [SPANSION] S71GL032R4B
  Nor Flash Code: 0001227E(221A2200)
  Nor Flash Size: 0x00400000 Hex Bytes
  INT/EXT RAM  Size: 0x00008000+0x00100000
  Verifying Baud...
  Set Baud:921600 OK.
  Reading(Nor)...
  Read OK.
>>total: 3 mins17 s
Good Luck !
Mcnbox Team
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on Facebook
The Following 8 Users Say Thank You to Mcnbox For This Useful Post:
Refbacks are Off
GSMCity - GSM Hosting - 1999-2010
Page generated in 0.04677 seconds with 8 queries
