04-08-2009, 15:41 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: :::::::EMIRATES:::::::
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | nokia 3555b unlocking problem but phone restricted JAFbox Opened.. Please wait.. Rebooting phone ================== READING PHONE INFORMATION ======================== MCU SW version : V 05.07 12-12-07 RM-257 (c) Nokia IMEI : 359556011625744 CONFIG KEY: 8000000000000000 PROVIDER KEY: 3102000000000000 Provider : T-Mobile;U.S.A. Counters : 0/3 , 0/10 SP Lock Status : Locked ================== AUTO Backup PM-308 ======================== MCU SW version : V 05.07 12-12-07 RM-257 (c) Nokia IMEI : 359556011625744 Reading PM 308 PM 308 Size : 8192 PM 308 save to E:\jaleel calicut\bb5\backup\359556011625744_63339.pm PM 308 reading done. ================== 1st Boot ======================== RAPx ID : 000000010000022600010006010C192101003000 EM ID 1 : 00000295 EM ID 2 : 00000B22 RAPx PubID : 1B400006F96D0254F7A6FA2825DBC82188B37660 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROM ID: 273F6D55DFAAF68F Boot OK Auto Selected rap3gv3 ================== 2nd Boot ======================== Write PATCH 1 .. - Phone-ACK 0x550200003D3D Server verification.. Write PATCH 2 .. PKEY Verified OK.. - Phone-ACK 0x550200E402E6 Write PATCH 3 .. - Phone-ACK 0x550200483971 >>> phone reply : HELLO U >> : ok Write PATCH 4 .. >>> phone reply : 550200040004 - Phone-ACK 0x550200F054A4 >>> phone reply : 550200010001 >>> phone reply : 550200010001 >>> phone reply : HELLO U Sending PM308 buffer in flash mode... >>> phone reply : HELLO Test Custom Code >> : Test call... >> : cpsr - 0x0000001F >> : p15_1 - 0x0005307F >> : p15_2 - 0x0005117F >> : p15_3 - 0x0005317F >> : esn_init ret - 0x00000001, <tmp_buff2> - 0x00000027 >> : esn_read ret - 0x00000001, <tmp_buff2> - 0x00000022 >> : BB5+ ptr - 0x0004B840 Test custom done.. Please wait while reading calculated SPData.. Read Done!.. Unlock Data saved to : E:\jaleel calicut\bb5\Unlock Data\359556011625744_ 63404 _unlocked.pm Rebooting Phone sending unlock data.. MCU SW version : V 05.07 12-12-07 RM-257 (c) Nokia IMEI : 359556011625744 >>> phone reply : 5512000023000C103200030001 Rebooting Phone Reading phone information after unlocking process.. MCU SW version : V 05.07 12-12-07 RM-257 (c) Nokia IMEI : 359556011625744 CONFIG KEY: 8000000000000000 PROVIDER KEY: 3102000000000000 Provider : T-Mobile;U.S.A. Counters : 0/3 , 0/10 SP Lock Status : Locked Unlocking Done.... =========================================== Operation time started : 6:33:27 AM Operation time End : 6:34:25 AM =========================================== |
04-08-2009, 18:40 | #2 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Davao City, Philippines
Member: 723959 Status: Offline Thanks Meter: 46 | which unlocker did you use? try the free software of zulea i have one tested 3555d then open the free software of zulea connect jaf or ufs box click phone info Searching for JAF box ... JAF box detected Box firmware version: 1B0 Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-257 Version: V_05.07_12-12-07_RM-257_(c)_Nokia IMEI: 359556011512397 SP LOCK status: Config Key: 8000000000000000 Provider Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310310 Block 11: CLOSED Type 5 Data: 310580 Block 12: CLOSED Type 5 Data: 310660 Block 13: CLOSED Type 5 Data: 310800 Block 14: CLOSED Type 5 Data: 310202 Counters: 0/3, 0/10 Phone is Locked Read Phone Info OK earching for JAF box ... JAF box detected Box firmware version: 1B0 Searching for phone ... Phone found on FBUS interface Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-257 Version: V_05.07_12-12-07_RM-257_(c)_Nokia IMEI: 359556011512397 SP LOCK status: Config Key: 8000000000000000 Provider Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310310 Block 11: CLOSED Type 5 Data: 310580 Block 12: CLOSED Type 5 Data: 310660 Block 13: CLOSED Type 5 Data: 310800 Block 14: CLOSED Type 5 Data: 310203 Counters: 0/3, 0/10 Phone is Locked Read Phone Info OK Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-257 Version: V_05.07_12-12-07_RM-257_(c)_Nokia IMEI: 359556011512397 SP LOCK status: Config Key: 8000000000000000 Provider Key: 3102000000000000 Counters: 0/3, 0/10 Phone is Locked Reading PM Field 308 Subfield 1 with length 8192 bytes PM308 readed OK BB5 FLASH bb5challenge ... ASIC ID: 000000010000022600010006010C192101003000 HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F CMT Boot Ready HELLO start JAF BB5Plus No TP by [c]Cinek started. ok Initial PM 308 sent Certificates sent Unlocked PM 308 SL buffer received Unlocked PM 308 field build OK After unlock. Searching for phone ... Phone found on FBUS interface Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-257 Version: V_05.07_12-12-07_RM-257_(c)_Nokia IMEI: 359556011512397 SP LOCK status: Config Key: 8000000000000000 Provider Key: 0010100000000000 Block 1: OPEN Type 5 Data: 00101F Counters: 0/3, 0/10 Phone is Unlocked Read Phone Info OK Successfully done. finish |
04-08-2009, 19:04 | #4 (permalink) | |
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | 3555b Quote: JAF box detected Box firmware version: 1B1 Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-257 Version: V 05.07 12-12-07 RM-257 (c) Nokia IMEI: 359556011625744 SP LOCK status: Config Key: 8000000000000000 Provider Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310310 Block 11: CLOSED Type 5 Data: 310580 Block 12: CLOSED Type 5 Data: 310660 Block 13: CLOSED Type 5 Data: 310800 Block 14: CLOSED Type 5 Data: 310202 Counters: 0/3, 0/10 Phone is Locked Read Phone Info OK Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-257 Version: V 05.07 12-12-07 RM-257 (c) Nokia IMEI: 359556011625744 SP LOCK status: Config Key: 8000000000000000 Provider Key: 3102000000000000 Counters: 0/3, 0/10 Phone is Locked Reading PM Field 120 Subfield 0 with length 464 bytes Reading PM Field 308 Subfield 1 with length 8192 bytes Saving to file: RM-257_359556011625744_PM120_PM308_Locked_08-04-2009_095854.bin Saving to file: RM-257_359556011625744_120_and_308_Locked_08-04-2009_095854.pm PM120 and PM308 backup OK BB5 FLASH bb5challenge ... ASIC ID: 000000010000022600010006010C192101003000 HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F CMT Boot Ready Initial PM 308 sent Certificates sent Unlocked PM 308 SL buffer received Unlocked PM 308 field build OK After unlock. Searching for phone ... Phone found on FBUS interface Writting PM Field 120 Subfield 0 with length 56 bytes Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Fields 120 and 308 written OK Waiting for phone to power up ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-257 Version: V 05.07 12-12-07 RM-257 (c) Nokia IMEI: 359556011625744 SP LOCK status: Config Key: 8000000000000000 Provider Key: 0010100000000000 Block 1: OPEN Type 5 Data: 00101F Counters: 0/3, 0/10 Phone is Unlocked Read Phone Info OK Successfully done. thankyou very much i am remember it this one | |
Nokia 3555b unlocked succsesfull | telecomindia | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 09-18-2009 11:18 |
nokia 3555b mic problem | uburo22 | Nokia Hardware & Hardware Repair | 2 | 10-08-2008 00:33 |
Unlock cable + Nokia 3650 unlock problems... | Aleksandre | WD2 & APE (Symbian Phones) | 0 | 01-08-2004 09:34 |
Nokia 6610 Unlocking problem | Giulianiarad | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 11-02-2003 00:57 |
Nokia 3510 Unlock Problem | 13061972 | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 11-23-2002 02:59 |
