Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > BB5 No TP By Jafsupport
Old 09-28-2009, 00:08   #1 (permalink)
Member: 1115297
please help anyone! local mode solution! nokia 6500c
hi need solutuion for nokia 6500c to get into local or test mode i connect universal fbus cable rx and tx lights shows on jaf box but still not able to read phone. (into local mode) cable has no problem as i have unlock a nokia 8600 luna
thanks in advance!
Old 10-03-2009, 06:58   #2 (permalink)
Thinh vu's Avatar
Member: 830301
Sonork: heocon
take the camera out of it socket and try again .
The Following User Says Thank You to Thinh vu For This Useful Post:
Old 10-04-2009, 01:35   #3 (permalink)
Member: 1115297
Hi i have already tried that noo look it seems as the jaf
is not giving enough power to the phone even with the adapter universal cable but i dont get it nokia 8600 luna had no problem getin into local mode dnt no wat to do the nokia 6500c is easily able to get to local mode with usb but i need to unlock with fbus ???
Old 10-04-2009, 02:01   #4 (permalink)
jainmunda's Avatar
Member: 84128
solution
FIX 7.1 RESISTER LIKE THIS PICTURE
(BSI TO GND FIX THIS 7.1 RESISTER WITH BATTERY
http://i193.photobucket.com/albums/z...00c5610etc.jpg
INSERT BATTERY WITH HANDSET
POWER ON THE PHONE
THIS TIME PHONE SHOW LOCAL MODE
CONNECT USB CABLE
OPEN JAF SOFTWARSTEP8-SELECT COMMUNICATION MODE TO USB
USE FULL FACTORY RESET(FACTORY RESET DONE)
DISCONNECT PHONE THEN POWER ON WITH OUT SIM
GO PHONE SETTINGS RESET COMPLETE PHONE
The Following User Says Thank You to jainmunda For This Useful Post:
Old 10-04-2009, 12:45   #5 (permalink)
Member: 1115297
POWER ON THE PHONE
CONNECT USB CABLE
hi nokia 6500 classic is easily able to go into local mode with usb but when try universal fbus cable it wont read phone same cable tried on nokia 8600 luna successfuly read phone will this solution make universal fbus cable read nokia 6500 classic phone
Old 10-04-2009, 13:46   #6 (permalink)
Member: 1115297
thank you everyone for your help but problem solve just use different cable not universal fbus cable thanks any way for helping now just need to debrand the handset
The Following User Says Thank You to waqs-786 For This Useful Post:
nokia 6120 local mode solution shahidsattar Nokia Hardware & Hardware-Repair Area 7 07-24-2011 13:52
nokia 1200/1208 local mode solution himanshu taldar Nokia Hardware & Hardware-Repair Area 21 06-10-2009 06:34
nokia 1600 local mode solution is needed barthosyn Nokia Hardware & Hardware-Repair Area 2 10-04-2007 00:23
Page generated in 0.60107 seconds with 11 queries
