Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Pegasus
Old 05-03-2012, 15:03   #1 (permalink)
Gsmserver's Avatar
Member: 21077
Post Pegasus Box 1.2.3 - public discussion thread
Pegasus Box v1.2.3 is out! Added world's first support for I677 and support for I937, I847,C3750, C3752 and C5010E Samsung mobiles.
Pegasus Box v1.2.3 Release Notes:
  • I677 - world's first Read Unlock Codes, Direct Unlock, Repair IMEI.
  • I937 - Read Unlock Codes, Direct Unlock, Repair IMEI.
  • I847 - Direct Unlock.
  • C3750 - Read Unlock Codes, Direct Unlock, Repair IMEI, Read/Write Full Flash, Patch MSL, added original firmware converter as requested by our customers (new converters for other platforms will be added in next updates).
  • C3752 - Read Unlock Codes, Direct Unlock, Repair primary and secondary IMEI, Read/Write Full Flash, Patch MSL, added original firmware converter as requested by our customers (new converters for other platforms will be added in next updates).
  • C5010E - Read Unlock Codes.
  • Improved unlock procedure for Samsung I717, I727 and T989 phones.
  • Significantly improved patching procedure for most Infineon-based phones, no full reflash required
Download Pegasus Box v1.2.3
_______________________
WBR,
Pegasus Box Team
The Following 3 Users Say Thank You to Gsmserver For This Useful Post:
Old 05-03-2012, 22:29   #2 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688 Piranhabox
thanks for update gsmserver team
more update to come
Old 05-04-2012, 02:28   #3 (permalink)
Member: 534777
I677 Unlock done.
Thanx Pegasus team. have unlocked my first I677 (focus flash) thanx to your latest update.
very appreciative.
we look forward to A187 solution soon.
best wishes
Old 05-08-2012, 21:38   #4 (permalink)
Member: 1737202
Hi,
What is the port 'cable services' I can not connect my I9100 via this connection !
The section of the com remains inactive (What is this connector has).
I just know I connect via USB but it uses the pilot Samsung USB.
I have no options or other Backup!
In the device manager I do not see either the PEGASUS ? this is normal ?
Is there a link to a better expliquation
thank you in advance for help
@+ Pyrana
Old 05-10-2012, 10:49   #5 (permalink)
Member: 1565828
@ Pyrana,
Read carefully detailed step by step manual on the phone connection and perform stps mentioned there.
It is placed in the left part of the software after phone model get selected.
Best Regards
GSMServer team
Old 05-10-2012, 18:23   #6 (permalink)
Member: 1737202
Originally Posted by PegasusBox View Post
@ Pyrana,
Best Regards
GSMServer team
Re Hi,
I guess it must be Boot-Loader V2 for all functions, but I can not register on the site, it does not work!
When I log on Pegasus, I have a connection to the USB port (the port is cennexion SAMSUNG USB modem) and can only see the information from my phone.
I do not have the Backup function, and other change IEMI.
(My rom is an ICS LP7 Stock)
NB: I have an RJ45 cable to micro-usb provided, it is used for what purpose ?
There is the USB to micro USB which allows to connect
Sorry for my English, I'm French
Pyrana (Alan)
Old 05-11-2012, 09:13   #7 (permalink)
Member: 1737202
Screen:
Insert Imege !!!! No found !!! ??
Old 05-11-2012, 09:51   #8 (permalink)
Member: 1565828
@ Pyrana,
For I9100, as it is stated in the Pegasus Software:
Instructions
  1. Power On phone without Sim card
  2. In phone menu go to "Settings"->"Application"->"Development"->.
  3. Enable "USB Debugging"
  4. Connect phone to USB data cable
  5. Install required drivers if prompted
  6. Click "Connect Button"
  7. If the set has android version 2.3.5 or higher one, you have to root it manually using unsecure flashing kernel
Phone suppose to be connected to PC via USB cable.
Explain in more details what issues you are dealing with the Boot-Loader.com
Detailed Video Tutorial on the registration operation at Boot-Loader.com available by this link.
Best Regards
GSMServer team
Old 05-11-2012, 10:30   #9 (permalink)
Member: 1737202
re re hi,
I really do all this, This is my root, but I do not have the Boot-Loader V2.
I'm doing everything right to save me, but each time the record does not!
I tried with my address be, with my Gmail address but nothing works.
I even posted a message to ask why this does not work but no answer.
I wanted to post the screen, but the function does not work on the forum?
is it normal for you I did that SAMSUNG USB modem as a port only ? not Com1 or other ?
Thanks for your help, (it is hard for me to post in English)
Old 05-11-2012, 10:44   #10 (permalink)
Member: 1565828
@ Pyrana,
PM me your Boot-Loader.com username and box serial number, i'll try to check what can be wrong with your Boot-Loader.com account.
Best Regards
GSMServer team
Old 05-11-2012, 23:23   #11 (permalink)
Member: 1737202
Sorry to French
Ok registration OK
Mais comment repatrier les fichiers pour Galaxy S2 I9100 ? dans la liste de download Pegasus c'est tous de N° dont je ne comprends rien! il n'y a pas de 9100 !, mais des Axxx Bxxx, Cxxx !!!!
Une aide SVP
One Click One unlock motorola android series MBxxx srockyou Motorola Android based phones 411 05-14-2013 11:47
HELP: Ericsson A1018s Imei Change ! wescam Old Ericsson Phones & Sony Phones 3 05-27-2012 17:31
u8650 unlock fail kamimobile FuriouS TeaM Products 10 05-22-2012 12:43
Power of Master Box=Post here Success Stories which Done with Master Bo& Other Failed Unlock-King-PK Mastertools 9 05-10-2012 10:16
help unlock w395 [ANSWERD] rahim13310 GPG-Setool3 1 04-29-2012 05:53
Page generated in 0.38559 seconds with 11 queries
