Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Pegasus
Old 11-18-2011, 14:43   #16 (permalink)
Gsmserver's Avatar
Member: 21077
Pegasus Box v1.1.7 is out! We have added support for S5610, S3770 Samsung cell phones!
Pegasus Box v1.1.7 Release Notes:
Added support for the following Samsung models:
  • S5610Read Unlock Codes/Simlock Codes/Phone Codes.
  • S3770Read Unlock Codes/Simlock Codes/Phone Codes.
  • Added Factory Reset option to all Qualcomm phones. In order to use this option, modem port should be present in the system.
  • Galaxy S series root exploit updated.
  • Fixed few errors in the manual.
  • Fixed some minor bugs.
Download Pegasus Box v1.1.7
_______________________
WBR,
Pegasus Box Team
Old 01-04-2012, 16:27   #17 (permalink)
Gsmserver's Avatar
Member: 21077
Pegasus Box v1.1.8 is out! We have added support for a wide range of Samsung cell phones.
Pegasus Box v1.1.8 Release Notes:
  • S5360Read Unlock Codes/Direct Unlock/Rebuild IMEI/Factory Reset/Switch To Download Mode.
  • S5363Read Unlock Codes/Direct Unlock/Rebuild IMEI/Factory Reset/Switch To Download Mode.
  • S5360BRead Unlock Codes/Direct Unlock/Rebuild IMEI/Factory Reset/Switch To Download Mode.
  • S5360LRead Unlock Codes/Direct Unlock/Rebuild IMEI/Factory Reset/Switch To Download Mode.
  • S5360TRead Unlock Codes/Direct Unlock/Rebuild IMEI/Factory Reset/Switch To Download Mode.
  • B5510Read Unlock Codes/Direct Unlock/Rebuild IMEI/Factory Reset/Switch To Download Mode.
  • B5510BRead Unlock Codes/Direct Unlock/Rebuild IMEI/Factory Reset/Switch To Download Mode.
  • B5510LRead Unlock Codes/Direct Unlock/Rebuild IMEI/Factory Reset/Switch To Download Mode.
  • B5512Read Unlock Codes/Direct Unlock/Rebuild IMEI/Factory Reset/Switch To Download Mode.
  • S5570iRead Unlock Codes/Direct Unlock/Rebuild IMEI/Factory Reset/Switch To Download Mode.
  • S5830iRead Unlock Codes/Direct Unlock/Rebuild IMEI/Factory Reset/Switch To Download Mode.
  • S6102Read Unlock Codes/Direct Unlock/Rebuild IMEI/Factory Reset/Switch To Download Mode.
  • T679Read Unlock Codes/Direct Unlock/Rebuild IMEI/Factory Reset.
  • T679MRead Unlock Codes/Direct Unlock/Rebuild IMEI/Factory Reset.
  • I857Read Unlock Codes/Direct Unlock/Rebuild IMEI/Factory Reset.
  • I927Read Unlock Codes/Direct Unlock/Factory Reset.
  • I927RRead Unlock Codes/Direct Unlock/Factory Reset.
  • C3303iRead Unlock Codes/Direct Unlock/Rebuild IMEI/Factory Reset.
  • E1190Read Unlock Codes/Direct Unlock/Rebuild IMEI/Factory Reset/Read Flash/Write Flash.
  • I9001Direct Unlock bug fixed.
Download Pegasus Box v1.1.8
WBR,
Pegasus Box Team
Old 01-23-2012, 15:46   #18 (permalink)
Gsmserver's Avatar
Member: 21077
Pegasus Box v1.1.9 is out! We have added IMEI and Serial Number (MSL Address) Repair for a wide range of Samsung cell phones. Phones with IMEI 0049.... are also supported!
Pegasus Box v1.1.9 Release Notes:
Added IMEI and Serial Number (MSL Address) Repair for the following Samsung cell phones:
  • Samsung I9000
  • Samsung I9000B
  • Samsung I9000L
  • Samsung I9000M
  • Samsung I9000T
  • Samsung I9003
  • Samsung I9003B
  • Samsung I9003L
  • Samsung I9008
  • Samsung I9010
  • Samsung I9088
  • Samsung I896
  • Samsung I897
  • Samsung I987
  • Samsung P1000
  • Samsung P1000L
  • Samsung P1000M
  • Samsung P1000N
  • Samsung P1000R
  • Samsung P1000T
  • Samsung T849
  • Samsung T959
  • Samsung T959D
  • Samsung I9100
  • Samsung I9100L
  • Samsung I927
  • Samsung I927R
  • Samsung I777
  • Samsung T959V
  • Samsung T759
  • Samsung T959P
  • Samsung I997
  • Samsung T839
P.S. On January 24th our servers will be down for maintenance. Servers will be stopped at 12:00 CET for about 4-5 hours.
P.S.S. If you have a locked Samsung I9020, I9023 or I9250 cell phone, please contact us to test our new beta solution.
Download Pegasus Box v1.1.9
WBR,
Pegasus Box Team
Old 03-08-2012, 12:30   #19 (permalink)
GSM_Support's Avatar
Member: 121052
Pegasus Box v1.2.0 is out! Added support for a wide range of Samsung cell phones.
Pegasus Box v1.2.0 Release Notes:
  • Added support for the following Samsung models:
    • I717 - added Direct Unlock.
    • I717D - added Direct Unlock.
    • I717M - added Direct Unlock.
    • I717R - added Direct Unlock.
    • I727 - added Fast Direct Unlock.
    • I727R - added Fast Direct Unlock.
    • T989 - added Fast Direct Unlock.
    • T989D - added Fast Direct Unlock.
    • A817 - added Read Unlock Codes.
    • T369R - added world's first Read Unlock Codes/Direct Unlock/Repair IMEI/Read Flash/Write Flash.
    • E1230 - added Read Unlock Codes/Direct Unlock/Repair IMEI/Read Flash/Write Flash.
    • E1232B - added Read Unlock Codes/Direct Unlock/Repair IMEI/Read Flash/Write Flash.
  • Fixed minor bugs in the software.
Download Pegasus Box 1.2.0
____________________________
WBR,
Pegasus Box Team
Old 03-08-2012, 12:32   #20 (permalink)
Member: 121052
Pegasus Box v1.2.1 is out! Added support for a wide range of Samsung cell phones.
Pegasus Box v1.2.1 Release Notes:
With this release following issues were resolved:
  • Android rooting bug fixed
  • I717 Unlock bug fixed
Download Pegasus Box 1.2.1
Please notice that due to
WBR,
Pegasus Box Team
Best Regards
GSMServer team
Old 03-28-2012, 15:04   #21 (permalink)
Gsmserver's Avatar
Member: 21077
Pegasus Box v1.2.2 is out! Added Direct Unlock for Samsung S5690, S5690L, S5690R, S5690M, I8350, I8350T.
Pegasus Box v1.2.2 Release Notes:
  • S5690 - Direct Unlock
  • S5690L - Direct Unlock
  • S5690R - Direct Unlock
  • S5690M - Direct Unlock
  • I8350 - Read Unlock Code/Direct Unlock/Rebuild IMEI
  • I8350T - Read Unlock Code/Direct Unlock/Rebuild IMEI
Added new very fast root method (it takes just a few seconds) for the following models (Android 2.3.6 all versions are supported now without downgrade):
  • S5360
  • S5360B
  • S5360L
  • S5360T
  • S5363
  • B5510
  • B5510B
  • B5510L
  • B5512
  • S5570i
  • S5830i
  • S6102
Download Pegasus Box v1.2.2
WBR,
Pegasus Box Team
The Following 3 Users Say Thank You to Gsmserver For This Useful Post:
Old 05-09-2012, 11:57   #22 (permalink)
Gsmserver's Avatar
Member: 21077
Pegasus Box v1.2.4 is out! Added support for E2600, C3350 and E2652 Samsung mobiles.
Pegasus Box v1.2.4 Release Notes:
  • E2600 - added Read Unlock Codes, Unlock, Repair IMEI, Original Firmware Converter, Write Firmware, Read MCU Flash.
  • C3350 - added Read Unlock Codes, Unlock, Repair IMEI, Original Firmware Converter, Write Firmware, Read MCU Flash.
  • E2652 - added Read Unlock Codes, Unlock, Repair Primary and Secondary IMEI, Original Firmware Converter, Write Firmware, Read MCU Flash.
This release is dedicated in memory of all who struggled in WWII and sacrificed their lives in fight against Nаzism.
Download Pegasus Box v1.2.4
WBR,
Pegasus Box Team
The Following 2 Users Say Thank You to Gsmserver For This Useful Post:
Old 06-13-2012, 13:34   #23 (permalink)
Member: 121052
Pegasus Box v1.2.6 is out! Added support for a wide range of Samsung mobiles.
Pegasus Box v1.2.6 Release Notes:
  • S5220 - added Read Unlock Codes, Unlock, Read Phone Code, Repair IMEI, Factory Reset, Write Firmware, Original Firmware Converter.
  • S5222 - added Read Unlock Codes, Unlock, Read Phone Code, Repair Primary IMEI, Repair Secondary IMEI, Write Firmware, Original Firmware Converter.
  • S7500 - added Unlock, Repair IMEI, Factory Reset.
  • S7500L - added Unlock, Repair IMEI, Factory Reset.
  • S7508 - added Unlock, Repair IMEI, Factory Reset.
  • S6500/S6500D - Unlock Bug fixed.
Download Pegasus Box v1.2.6
WBR,
Pegasus Box Team
The Following User Says Thank You to GSM_Support For This Useful Post:
Old 11-07-2012, 14:31   #24 (permalink)
Gsmserver's Avatar
Member: 21077
PEGASUS BOX 1.2.9 IS OUT!
As you remember Pegasus Team was the first to released "no patch/flash mode" solution for Swift phones. So here is the next revolutionary update for this platform.
PEGASUS BOX 1.2.9 RELEASE NOTES:
  • E1200 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1200M - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1200T - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1205L - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1202 - world's first super fast Unlock Code Reading/Unlock/Primary IMEI Repair/Secondary IMEI Repair/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1085L - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1086L - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1086i - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1086il - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1080 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1080f - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1080i - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1080w - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1050 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1150 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1150i - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1153 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1155L - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1170 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1170i - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1170t - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1172 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1180 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1190 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • E1195 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
  • C3330 - Read Unlock Codes/Unlock/Repair IMEI/Write Firmware/Convert Original Firmware
  • C3312 - Read Unlock Codes/Unlock/Primary IMEI Repair/Secondary IMEI Repair/Write Firmware/Convert Original Firmware
  • S5839I - Read Unlock Codes/Unlock/Repair IMEI
  • S5270K - Read Unlock Codes
  • I827 - Direct Unlock/Repair IMEI
Download Pegasus Box v1.2.9
Old 11-16-2012, 15:51   #25 (permalink)
Member: 121052
Dear Users,
Pegasus Box v1.3.0 is out! Added Direct Unlock feature for Samsung I9305, I9305T, N7105, I317, i317m, T889 mobile devices.
With this release we are glad to introduce to you such new features and improvements:
  • I9305 - added direct unlock (thanks to mr Duzz)
  • I9305T - added direct unlock
  • N7105 - added direct unlock
  • I317 - added direct unlock
  • i317m - added direct unlock (thanks to mr darltech)
  • T889 - added direct unlock
  • minor bug fixes
Download Pegasus Box v1.3.0
Best Regards
GSMServer team
Old 01-14-2013, 16:20   #26 (permalink)
Gsmserver's Avatar
Member: 21077
For over two years of its existence Pegasus managed to bring you dozens of great updates,
tons of new features and a lot of improvements. And today we give you our 1001st
supported phone. With this update you get Read Unlock Codes for a wide range of Samsung
devices and Direct Unlock, Repair IMEI for Samsung I8190.
Pegasus Box v1.3.3 Release Notes:
  • S7560M - added Read Unlock Codes.
  • S730M - added Read Unlock Codes.
  • I8190 - added Direct Unlock, Repair IMEI (manual root required).
  • S6500 - added Read Unlock Codes.
  • S6500D - added Read Unlock Codes.
  • S6500L - added Read Unlock Codes.
  • S6500T - added Read Unlock Codes.
  • S7500 - added Read Unlock Codes.
  • S7508 - added Read Unlock Codes.
  • S7500L - added Read Unlock Codes.
  • S7500T - added Read Unlock Codes.
  • S7500W - added Read Unlock Codes.
  • S7562 - added Read Unlock Codes.
  • S7562L - added Read Unlock Codes.
  • SC01E - added Read Unlock Codes.
  • SC03E - added Read Unlock Codes.
  • T779 - added Read Unlock Codes.
  • I497 - added Read Unlock Codes.
  • I437 - added Read Unlock Codes.
  • I667 - added Read Unlock Codes.
  • I827 - added Read Unlock Codes.
  • I827D - added Read Unlock Codes.
Download Pegasus Box v1.3.3
The Following User Says Thank You to Gsmserver For This Useful Post:
FLASH BOX WANTED!!!!!! J Wanted Products 9 07-14-2012 20:42
==== FREE DOWNLOAD ==== site updated cimbalo GSM Mobile Links 31 04-29-2012 20:43
i WANT TO BUY NOKIA BOX !!! Eric Wanted Products 8 02-14-2011 12:23
New Nokia BOX for you!!! gsmEsteve Main Sales Section 0 11-18-2000 16:09
Software update HitMan Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 12-13-1999 18:54
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.44139 seconds with 10 queries
