Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > No more Support JAF Products. > JAF No Tp Unlocker by Cinek
Old 03-26-2009, 03:28   #1 (permalink)
Member: 200475
6500S cannot unlock when key code count reach 3
Hi
I have report in the other thread before, not all 6500S can be unlocked At first, I think maybe the firmware version, then I have tried to upgrade to the same version that can be unlocked before, still doesn't work. Today I just realised that all the 6500S that I can't unlock no matter which version it is, the key code count has reach 3 ( max ).
So, is there a way we can reset the counter ? I believe it should be able to unlock after reset to zero.
pls advice.
SS
Old 03-26-2009, 04:11   #2 (permalink)
Member: 200475
I just reset the counter to "zero" by editing the PM in field 120. However, still coming up error the shut down the program. So, can you advice what to do :-
Below is the log for this phone :-
Powering the phone...
Reading...
MCU SW version: V 06.60
07-03-08
RM-240
(c) Nokia
HW version: 1000
PCI version:
RFIC version:  17141714
DSP version:
ICPR71_08w09
LCD version: SHARP
PPM version: V 06.60
07-03-08
RM-240
(c) Nokia
T
BT MCM version: 2222-143
Retu version: 15
Tahvo version: 22
Production serial number: CJJ846914
Product code: 0556483
Module code: 0203327
Basic production code: 0543753
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 357659012763779
IMEI spare to net: 3A 75 56 09 21 67 73 07
IMEI SV to net: 33 75 56 09 21 67 73 37 F3
LOCK STATUS:
CONFIG KEY: 8000000000000002
PROVIDER KEY: 5050600042465540
Provider: Hutchinson 3G;Australia
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: CLOSED -> Lock Data: 50506F
Block 2:
Lock 1: CLOSED -> Lock Data: 50599F
Block 3:
Lock 1: CLOSED -> Lock Data: 00101F
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-240.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0556483
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-240\
Searching for default location of ini...
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-240\
Scanning ini files...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-240\rm240__07.12.mcusw
PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-240\rm240__07.12.ppm_t
CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-240\rm240__07.12_ism_009.image_3_au
APE Variant file: NONE
Languages in ppm: English,Vietnamese,Tagalog,Chinese Simpl,Chinese Trad
Done!
Old 03-26-2009, 23:32   #3 (permalink)
nicacel's Avatar
Member: 111014
did u try Repair SL zone with cinek's unlocker?
No more rpl when key code count is bloked with new phones RAP3G v3.xx mily2 Nokia Base Band 5 ( BB-5 ) 28 10-22-2008 20:56
key code count BB5 . with DCTxBB5 v2.0.5.3 Cake HWK 3 06-17-2007 12:40
what a ? After writing RPL , key code count still blocked !!! (Nokia 6280) BrockPhoenix MT-BOX 1 04-20-2007 06:02
N70 Key Code Count a8nsli Nokia Base Band 5 ( BB-5 ) 4 04-09-2007 14:37
Page generated in 0.43158 seconds with 11 queries
