03-26-2009, 12:20 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 39
Member: 138583 Status: Offline Thanks Meter: 120 | E62 Cant unlock Detected PKEY: 90005C8B Card life counter: 26.97% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B0, Driver version: 20416, Library version: 30118 JAF DCT4/BB5 LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Archivos de programa\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Archivos de programa\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.6.0 Changing mode...Done! Booting phone... Error sync the phone... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: Vp 2.0618.06.17 10-08-06 RM-88 (c) Nokia. HW version: 1020 PCI version: RFIC version: ذ 17191719 DSP version: ذtexas_pb32V37_06wk31 Retu version: 32 Tahvo version: 52 Production serial number: SGH253698 Product code: 0530924 Module code: Basic production code: 0524511 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 357951006026523 IMEI spare to net: 3A 75 59 01 60 20 56 02 IMEI SV to net: 33 75 59 01 60 20 56 02 F2 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 3101700000000000 Provider: CINGULAR - Pacific Bell Wireless;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310150 Block 2: Lock 1: CLOSED -> Lock Data: 310150 Block 3: Lock 1: CLOSED -> Lock Data: 310170 Block 4: Lock 1: CLOSED -> Lock Data: 310170 Block 5: Lock 1: CLOSED -> Lock Data: 310410 Block 6: Lock 1: CLOSED -> Lock Data: 310410 Block 7: Lock 1: CLOSED -> Lock Data: 311180 Block 8: Lock 1: CLOSED -> Lock Data: 311180 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-88.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0530924 Searching for JAF saved location of ini... Checking path: C:\Archivos de programa\Nokia\Phoenix\Products\RM-88\ Searching for default location of ini... Checking path: C:\Archivos de programa\Archivos comunes\Nokia\DataPackage\Products\RM-88\ Searching for JAF saved location of ini... Checking path: C:\Archivos de programa\Nokia\Phoenix\Products\RM-88\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Archivos de programa\ODEON\JAF\ProgData\357951006026523_CRT_ba ckup_1355253.pm Done! Backup LCK OK! Setting local mode... Reading simlock data... LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 3101700000000000 Provider: CINGULAR - Pacific Bell Wireless;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310150 Block 2: Lock 1: CLOSED -> Lock Data: 310150 Block 3: Lock 1: CLOSED -> Lock Data: 310170 Block 4: Lock 1: CLOSED -> Lock Data: 310170 Block 5: Lock 1: CLOSED -> Lock Data: 310410 Block 6: Lock 1: CLOSED -> Lock Data: 310410 Block 7: Lock 1: CLOSED -> Lock Data: 311180 Block 8: Lock 1: CLOSED -> Lock Data: 311180 Reading imei... Reading codes data... Found codes data... Resetting phone... Waiting for phone... Reading soft info... Reading simlock data... Writing codes data... Read SP data error! or Phone not supported Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Archivos de programa\ODEON\JAF\ProgData\357951006026523_CRT_ba ckup_1355253.pm Done! Backup LCK OK! Setting local mode... Reading simlock data... LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 3101700000000000 Provider: CINGULAR - Pacific Bell Wireless;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310150 Block 2: Lock 1: CLOSED -> Lock Data: 310150 Block 3: Lock 1: CLOSED -> Lock Data: 310170 Block 4: Lock 1: CLOSED -> Lock Data: 310170 Block 5: Lock 1: CLOSED -> Lock Data: 310410 Block 6: Lock 1: CLOSED -> Lock Data: 310410 Block 7: Lock 1: CLOSED -> Lock Data: 311180 Block 8: Lock 1: CLOSED -> Lock Data: 311180 Reading imei... Reading codes data... Found codes data... Resetting phone... Waiting for phone... Reading soft info... Reading simlock data... Writing codes data... Read SP data error! or Phone not supported any help pls??? Thanks in advance |
Cant unlock Sony-Ericsson-J132 | rajhcl0 | Infinity-Box | 3 | 03-29-2010 18:28 |
Help E62 after unlock no disply | MichieMax | BB5BOX | 5 | 12-14-2007 06:57 |
e62-1 unlocking | mrfixit | BB5BOX | 0 | 10-10-2007 02:47 |
E62 Sucsessfull Unlocked With Mtpro | Nasmi | MT-BOX | 9 | 09-19-2007 18:28 |
