Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > No more Support JAF Products. > JAF No Tp Unlocker by Cinek
Old 04-01-2009, 12:32   #1 (permalink)
Member: 262614
E65 unlocked wid jaf now phone startup failed.....
Hi,
I have unlocked one E65 wid jaf nokia bb5 notp unlocker v1.04 and it unlocked the fone but now when i turn it on it says phone startup failed contact the retailer.I have checked phone's simlock area it seems fine,I wrote the backup on the phone but its still same plz help me.
JAF box ATmega firmware version: 1B1
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
SP LOCK status:
Block 1: OPEN Type 5 Data: FFFFFF
Block 2: OPEN Type 5 Data: FFFFFF
Block 3: OPEN Type 5 Data: FFFFFF
Block 4: OPEN Type 5 Data: FFFFFF
Block 5: OPEN Type 5 Data: FFFFFF
Block 6: OPEN Type 5 Data: FFFFFF
Block 7: OPEN Type 5 Data: FFFFFF
Read Phone Info OK
Operation time: 00:12.
Successfully done.
Thread phone exit.
Old 04-01-2009, 12:52   #2 (permalink)
Member: 262614
this phone's config key is ok as well its not 0000000 and i have just wrote 308 backup once again and then fone just locked again and then i pressed Repair SL zone button and that worked fine too but even after that fone is still saying startup failed contact service.
SP LOCK status:
Block 1: CLOSED Type 5 Data: 23420F
Block 2: CLOSED Type 5 Data: 23420F
Block 3: CLOSED Type 5 Data: 23594F
Block 4: CLOSED Type 5 Data: 23594F
Read Phone Info OK
Reading PM Field 308 Subfield 1 with length 8192 bytes
Saving to file: RM-208_353262011528287_Locked_Keycnt_0_Fbuscnt_0__V_2 .0615.30_13-09-07_RM-208_(c)_Nokia.__01_04_2009__12_44_49.bin
PM308 backup OK
Searching for JAF box ...
JAF box detected
Initialize JAF box ...
JAF box JAFBOX_BB5_FLASH_bb5challenge ...
ASIC ID: 000000010000022600010006010C192101003000
HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
JAF no TP v1.04
Sending loader...
Rap3Gv3 selected.
BB5_FLASH_CMTbootload
JAF CMT Boot Ready
Hello ok
ok
Get card info ...
Verify card OK
Get card info ...
Verify card OK
Hello ok
Hello ok
PM send.
Test call...
cpsr - 0x0000001F
p15_1 - 0x0005307F
p15_2 - 0x0005117F
p15_3 - 0x0005317F
esn_init ret - 0x00000001, <tmp_buff2> - 0x00000027
esn_read ret - 0x00000001, <tmp_buff2> - 0x00000022
Normal BB5 found - 0x000D20E0
LR - FFFF3698, param - 0x03, size - 0x00
UpdSLock - 0x00000001
ret - 0x01, <tmp_buff2> - 0x23
PM_308 CRC - 0x000D78DD
Reciving PM
Hello ok
PM buff recived
After unlock.
Writting PM Field 308 Subfield 1 with length 8192 bytes
Reset phone ...
PM Field 308 Subfield 1 written OK
Operation time: 00:47.
Successfully done.
Thread phone exit.
I have no idea now wat to do i have even flashed the phone but it still is same plz if somebody know the solution plz help me out thanks in advance.
Old 04-01-2009, 13:08   #3 (permalink)
zaki_barika's Avatar
Member: 135661
heh you get F????D to with this tool
your phone now with this stats
Config Key: 0000000000000000
only RPL if you don't have buckep befor unlock
good luck
Old 04-01-2009, 13:47   #4 (permalink)
Bi0H4z4rD's Avatar
Member: 52560
Are you sure phone wasnt like that before unlocking? I have unlocked several E65 with 1.04 and didnt have this problem...
Anyway, fastest way to solve is to buy RPL as zaki_barika says.
Old 04-01-2009, 14:09   #5 (permalink)
rose4u86's Avatar
Member: 500858
Sonork: 1589054
send logs here
Old 04-01-2009, 15:03   #6 (permalink)
MaFiaaa's Avatar
Member: 57930
use yr backup or go to Rpl servers
Old 04-01-2009, 15:20   #7 (permalink)
Member: 262614
no i m not sure phone was ok before cuz i didnt check it and just tried to unlock it and i was confident because as u have said i have unlocked a lot of e65 myself and never had any problems before and also because of the fact that jaf always makes backup before unlocking so i knew if anything goes wrong i will have the backup of the phone,but the customer is insisting that he checked the phone before he gave it to me and it was working wid 3Uk sim.
I have the backup of the phone but even writing the backup its not working.does jaf have any bug.does it not make the write pm backup,has it happen to anyone before.
how to get rpl i think thats the only way now.I dnt know how to get rpl I used to get the rpl with a number of servers before but for a long time i havent had such a incident so i m not sure if those servers r still working or not besides i have heard someone told me that the servers r down.so i u could plz explain to me how to get the rpl i would be very very obliged thanks in advance.
Old 04-01-2009, 16:04   #8 (permalink)
Bi0H4z4rD's Avatar
Member: 52560
You are the technician, not the customer, and you should know that only wrong PM can make phone go into CS. It is evident that the phone was like that before it came to you.
You need to use SX4 auth to write full PM.
There are many many bb5 rpl providers. Just do a quick search in forum for it.
Next time, check phones (startup, network, calls) infront of customer before getting them! I bet that this phone was killed by trying to unlock with OLD bb5 unlocker by dejan.
Old 04-01-2009, 16:10   #9 (permalink)
Bi0H4z4rD's Avatar
Member: 52560
Check this thread, but be quick!:
http://forum.gsmhosting.com/vbb/show...71#post4310671
The Following User Says Thank You to Bi0H4z4rD For This Useful Post:
credits lost and now phone is on phone startup failed vikas chadha Universalbox 9 03-18-2009 12:29
N95 8gb not unlock and phone startup failed now F@RUK S BB5 Box by D.K. 47 03-02-2009 21:17
e65 phone startup failed schiavo BB5BOX 3 11-08-2007 13:05
Page generated in 0.31718 seconds with 11 queries
