Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > No more Support JAF Products. > JAF No Tp Unlocker by Cinek
Old 12-14-2008, 18:16   #1 (permalink)
Member: 277109
Sonork: 100.1590647
can Cinek work with another new ROM version N95?
2008-12-14 19:10:06 JAF box ATmega firmware version: 1B0
2008-12-14 19:10:20 Searching for phone ...
2008-12-14 19:10:20 Phone found on FBUS interface
2008-12-14 19:10:20 Reading phone info ...
2008-12-14 19:10:20 Type: RM-159
2008-12-14 19:10:20 Version: V_06wk41v59.1_02-06-08_RM-159_(c)_Nokia
2008-12-14 19:10:20 IMEI: 356843023277331
2008-12-14 19:10:21 SP LOCK status:
2008-12-14 19:10:21 Config Key: 2081000000000000
2008-12-14 19:10:21 Block 1: CLOSED Type 5 Data: 20810F
2008-12-14 19:10:21 Block 2: CLOSED Type 5 Data: 20810F
2008-12-14 19:10:21 Block 3: CLOSED Type 5 Data: 64710F
2008-12-14 19:10:21 Block 4: CLOSED Type 5 Data: 64710F
2008-12-14 19:10:21 Key counter: 0/3
2008-12-14 19:10:21 Cable counter: 0/10
2008-12-14 19:10:21 Read Phone Info OK
2008-12-14 19:10:21 Searching for phone ...
2008-12-14 19:10:21 Phone found on FBUS interface
2008-12-14 19:10:21 Reading phone info ...
2008-12-14 19:10:21 Reading PM Field 308 Subfield 1 with length 8192 bytes
2008-12-14 19:10:24 Saving to file: RM-159_356843023277331_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v59.1_02-06-08_RM-159_(c)_Nokia__14_12_2008__19_10_24.bin
2008-12-14 19:10:24 PM308 backup OK
2008-12-14 19:10:24 Searching for JAF box ...
2008-12-14 19:10:24 JAF box detected
2008-12-14 19:10:25 JAF box ATmega firmware version: 1B0
2008-12-14 19:10:25 Initialize JAF box ...
2008-12-14 19:10:25 JAF box JAFBOX_BB5_FLASH_bb5challenge ...
2008-12-14 19:10:26
2008-12-14 19:10:26 ASIC ID: 000000010000022600010006400C192101031103
2008-12-14 19:10:26 HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
2008-12-14 19:10:26 ROM ID: 4B9B75103E691FF8
2008-12-14 19:10:26 Operation time: 00:21.
2008-12-14 19:10:26 Done with error(s).
Cinek, can u work on this version?
Old 12-14-2008, 19:12   #2 (permalink)
Member: 40756
Try again and check cable, is SW always show this ? Or message this ROM is not supported ? Because this ROM will be supported without any problem, maybe this is only connection problem.
WBR
Old 12-14-2008, 19:50   #3 (permalink)
Member: 836352
SP LOCK status:
Block 1: CLOSED Type 5 Data: 26803F
Block 2: CLOSED Type 5 Data: 26803F
Read Phone Info OK
Saving to file: RM-159_356843021805919_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v50.2_28-01-08_RM-159_(c)_Nokia__10_12_2008__17_22_40.bin
PM308 backup OK
JAF box detected
Error. This ROM version is not supported yet!
Done with error(s).
Thread phone exit.
Same for me.
I can't unlock with this ROM.
Tried with other cable but allways the same story.
I have 4 like this one.
Can you please help Mr Cinek?
Old 12-14-2008, 23:56   #4 (permalink)
Member: 277109
Sonork: 100.1590647
@Cinek
the message is THIS ROM VERSION IS NOT SUPPORTED YET!
i use UFC cable, and have already unlocked several N95 without problem, only this ROM version never pass. so i am sure that it's a version unsupported. firmware version is 30.0.015, locked by SFR FR(208-10)
hope you find a solution soon! thank you!
Wuwei
Old 12-15-2008, 00:15   #5 (permalink)
Member: 486967
done with errors, what ido with this kind of error use other versions turns out ok?that was before my pkey was killed? i think its a bug in the program? and we dont have a choice to use other versions now
Old 12-15-2008, 23:58   #6 (permalink)
Member: 836352
I also unlocked others N95. Only those give that ansewr.
I also upgrade to last firmware 30.0.015 but still the same error.
BR HighMoon
Old 12-16-2008, 04:23   #7 (permalink)
Member: 70629
BR HighMoon
I've been trying 2 unlock a number of n95 but with no luck it keeps telling me no phones detected on fbus. i'm using a universal cable and i put it on 7.5.
Old 12-16-2008, 10:22   #8 (permalink)
Member: 277109
Sonork: 100.1590647
no phone detected on fbus, means the connection problem. check when phone atached, whether there is blue light on JAFBOX, if not, press one time button power on; make sure phone is constantly in LOCAL MODE, check if u have the right pinout.
Old 12-16-2008, 10:29   #9 (permalink)
Member: 152547
Sonork: 100.1586021
same problem here.................
Old 12-16-2008, 12:02   #10 (permalink)
Member: 152547
Sonork: 100.1586021
what of n95 8g?.................
Old 12-16-2008, 14:43   #11 (permalink)
Patrick's Avatar
Member: 100436
16/12/2008 14:21:00 JAF box ATmega firmware version: 1B0
16/12/2008 14:21:14 Searching for phone ...
16/12/2008 14:21:15 ERROR: Cannot detect phone on FBUS interface
16/12/2008 14:21:15 Operation time: 00:16.
16/12/2008 14:21:15 Done with error(s).
16/12/2008 14:21:26 JAF box ATmega firmware version: 1B0
16/12/2008 14:21:40 Searching for phone ...
16/12/2008 14:21:40 Phone found on FBUS interface
16/12/2008 14:21:40 Reading phone info ...
16/12/2008 14:21:40 Type: RM-159
16/12/2008 14:21:40 Version: V_06wk41v59.1_02-06-08_RM-159_(c)_Nokia
16/12/2008 14:21:40 IMEI: 3530940214*****
16/12/2008 14:21:41 SP LOCK status:
16/12/2008 14:21:41 Config Key: 2343300000000000
16/12/2008 14:21:41 Block 1: CLOSED Type 5 Data: 23433F
16/12/2008 14:21:41 Block 2: CLOSED Type 5 Data: 23486F
16/12/2008 14:21:41 Block 3: CLOSED Type 5 Data: 23433F
16/12/2008 14:21:41 Block 4: CLOSED Type 5 Data: 23486F
16/12/2008 14:21:41 Key counter: 1/3
16/12/2008 14:21:41 Cable counter: 0/10
16/12/2008 14:21:41 Read Phone Info OK
16/12/2008 14:21:41 Searching for phone ...
16/12/2008 14:21:41 Phone found on FBUS interface
16/12/2008 14:21:41 Reading phone info ...
16/12/2008 14:21:41 Reading PM Field 308 Subfield 1 with length 8192 bytes
16/12/2008 14:21:44 Saving to file: RM-159_3530940214*****_Locked_Keycnt_1_Fbuscnt_0__V_0 6wk41v59.1_02-06-08_RM-159_(c)_Nokia__16_12_2008__14_21_44.bin
16/12/2008 14:21:44 PM308 backup OK
16/12/2008 14:21:44 Searching for JAF box ...
16/12/2008 14:21:44 JAF box detected
16/12/2008 14:21:45 JAF box ATmega firmware version: 1B0
16/12/2008 14:21:45 Initialize JAF box ...
16/12/2008 14:21:45 JAF box JAFBOX_BB5_FLASH_bb5challenge ...
16/12/2008 14:21:46
16/12/2008 14:21:46 ASIC ID: 000000010000022600010006400C192101021103
16/12/2008 14:21:46 HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
16/12/2008 14:21:46 ROM ID: A8C1D6713E691FF8
16/12/2008 14:21:46 bb5king SW v1.07
16/12/2008 14:21:46 Sending loader...
16/12/2008 14:21:46 RAPIDO_OLD selected.
16/12/2008 14:21:46 BB5_FLASH_CMTbootload
16/12/2008 14:21:47 JAF CMT Boot Ready
16/12/2008 14:21:47
16/12/2008 14:21:48 Hello ok
16/12/2008 14:21:48 bb5king ldr start
16/12/2008 14:21:48 bb5king send code ok
16/12/2008 14:21:55 Hello ok
16/12/2008 14:21:56 Hello ok
16/12/2008 14:21:56 PM send.
16/12/2008 14:21:56 Test call...
16/12/2008 14:21:56 cpsr - 0x0000001F
16/12/2008 14:21:56 p15_1 - 0x00C5387A
16/12/2008 14:21:56 p15_2 - 0x00C5197E
16/12/2008 14:21:57 p15_3 - 0x00C5397E
16/12/2008 14:21:57 esn_init ret - 0x00000001, <tmp_buff2> - 0x00000027
16/12/2008 14:21:57 esn_read ret - 0x00000001, <tmp_buff2> - 0x00000022
16/12/2008 14:21:57 Normal BB5 found - 0x000B21F0
16/12/2008 14:21:57 LR - FFFF89C4, param - 0x03, size - 0x00
16/12/2008 14:21:57 yeknom - found, aierf - found, noom - found
16/12/2008 14:21:57 UpdSLock - 0x00000001
16/12/2008 14:21:57 ret - 0x01, <tmp_buff2> - 0x23
16/12/2008 14:21:58 PM_308 CRC - 0x00190736
16/12/2008 14:21:58 Reciving PM
16/12/2008 14:21:59 Hello ok
16/12/2008 14:21:59 PM buff recived
16/12/2008 14:21:59 After unlock.
16/12/2008 14:22:01 JAF box ATmega firmware version: 1B0
16/12/2008 14:22:15 Searching for phone ...
16/12/2008 14:22:15 Phone found on FBUS interface
16/12/2008 14:22:16 Writting PM Field 308 Subfield 1 with length 8192 bytes
16/12/2008 14:22:19 Reset phone ...
16/12/2008 14:22:25 PM Field 308 Subfield 1 written OK
16/12/2008 14:22:25 Operation time: 00:59.
16/12/2008 14:22:25 Successfully done.
16/12/2008 14:22:30 JAF box ATmega firmware version: 1B0
16/12/2008 14:22:44 Searching for phone ...
16/12/2008 14:22:44 Phone found on FBUS interface
16/12/2008 14:22:44 Reading phone info ...
16/12/2008 14:22:44 Type: RM-159
16/12/2008 14:22:44 Version: V_06wk41v59.1_02-06-08_RM-159_(c)_Nokia
16/12/2008 14:22:44 IMEI: 3530940214*****
16/12/2008 14:22:44 SP LOCK status:
16/12/2008 14:22:44 Config Key: 2440700000000000
16/12/2008 14:22:44 Block 1: OPEN Type 5 Data: FFFFFF
16/12/2008 14:22:44 Block 2: OPEN Type 5 Data: FFFFFF
16/12/2008 14:22:44 Block 3: OPEN Type 5 Data: FFFFFF
16/12/2008 14:22:44 Block 4: OPEN Type 5 Data: FFFFFF
16/12/2008 14:22:44 Block 5: OPEN Type 5 Data: FFFFFF
16/12/2008 14:22:44 Block 6: OPEN Type 5 Data: FFFFFF
16/12/2008 14:22:44 Block 7: OPEN Type 5 Data: FFFFFF
16/12/2008 14:22:44 Key counter: 0/3
16/12/2008 14:22:44 Cable counter: 0/10
16/12/2008 14:22:44 Read Phone Info OK
16/12/2008 14:22:44 Operation time: 00:16.
16/12/2008 14:22:44 Successfully done.
Old 12-16-2008, 18:32   #12 (permalink)
Member: 836352
Mr Raskal and Mr Cinek N95 This ROM version is not supported yet!
SP LOCK status:
Read Phone Info OK
Saving to file: RM-159_356843021821742_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v59.1_02-06-08_RM-159_(c)_Nokia__16_12_2008__18_24_55.bin
PM308 backup OK
JAF box detected
Done with error(s).
Thread phone exit.
Hi
I know you both are very busy and things are messy but could you please help me?
I wrote a few days ago about this ROM i can't unlock but ansewrs has been very confused and i don't know what to think.
As it's not just me with this problem ans i just use your program JAF Nokia BB5 Unlocker i need to know if you can help us making an upgrade to unlocker so we can unlock or is it impoosible for the moment?
Thks for all your work cause it's great and i hope you both continue and please give me an ansewr soon.
HighMoon
Old 12-16-2008, 18:53   #13 (permalink)
waji mobiles's Avatar
Member: 326871
Sonork: down2 sky.up 2 the earth
Use tp unlock with bb5 box, way to unlock... Or check latest version. Of bb5 king, and make sure .that it not make damages your pkey.
Old 12-16-2008, 19:24   #14 (permalink)
viru's Avatar
Member: 222198
Sonork: 100.102981
This phone is not supported for Unlock in BB5 King.
Kindly read the sticky threads.
B.R.,
Viru
Old 12-16-2008, 19:35   #15 (permalink)
Member: 836352
I donīt have BB5 Box. Just JAF BOX with NO TP Unlock. I just use the one from Raskal but that is the problem.
Cant unlock.
Error. This ROM version is not supported! sorin77 JAF No Tp Unlocker by Cinek 5 03-27-2009 09:29
7500 This ROM version is not supported! humsaga BB5 No TP By Jafsupport 4 03-26-2009 06:52
N95 Error. This ROM version is not supported yet! Any news?! HighMoon JAF No Tp Unlocker by Cinek 11 02-10-2009 20:31
N95_Rm159.. Error. This ROM version is not supported yet! LoveLess BB5KING 3 01-13-2009 09:47
N95: ROM version is not supported yet?? wuwei BB5KING 4 11-25-2008 10:23
Page generated in 0.41248 seconds with 11 queries
