02-05-2009, 18:19 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: UAE Age: 43
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | N80 after unlock will be power off after 20 minutes I have unlocked two units of locked N80 phones, after unlock, everything is ok, but phone will be power off after each 10-20 minutes. problem is not hardware or battery. there's something wrong in bb5unlocker job because i tested it on two different N80 phones. any idea? |
02-08-2009, 22:06 | #3 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: places I repair phones
Member: 621698 Status: Offline Thanks Meter: 405 | Quote:
means that you need to do RPL or repair imei, I think you can do that on BB5 no TP by pressing repair SL ( but i'm not so sure ) | |
02-08-2009, 22:40 | #4 (permalink) |
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | sir, thanks for your reply but imei is OK i made SX4 and wrote full pm on it, but no result i downgrade and upgrade flash, no result phone power off after 20 minutes |
02-13-2009, 18:31 | #5 (permalink) |
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | here is the log: anyone plan to help me here? where are you cinek?! Powering the phone... Reading... MCU SW version: V 05wk33v46 18-06-07 RM-92 (c) Nokia. HW version: 6002 PCI version: RFIC version: 17191719 DSP version: miro_05wk32v42p1 Retu version: 14 Tahvo version: 21 Production serial number: SEJ490123 Product code: 0535062 Module code: 0202689 Basic production code: 0522205 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 358361007780137 IMEI spare to net: 3A 85 63 01 70 87 10 03 IMEI SV to net: 33 85 63 01 70 87 10 33 F0 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-92.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0535062 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-92\ Searching for default location of ini... Checking path: \Products\RM-92\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-92\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! and here is bb5unlocker by cinek log UFS box version: 208 UFS box SN: 37600 Searching for phone ... Phone found on FBUS interface Reading phone info ... SP LOCK status: Block 1: OPEN Type 5 Data: FFFFFF Block 2: OPEN Type 5 Data: FFFFFF Block 3: OPEN Type 5 Data: FFFFFF Block 4: OPEN Type 5 Data: FFFFFF Block 5: OPEN Type 5 Data: FFFFFF Block 6: OPEN Type 5 Data: FFFFFF Block 7: OPEN Type 5 Data: FFFFFF Read Phone Info OK Operation time: 00:23. Successfully done. Thread phone exit. |
02-14-2009, 06:57 | #7 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: Kabul,Afghanistan Age: 35
Member: 496203 Status: Offline Sonork: 100.1583640 Thanks Meter: 232 | Quote:
@ARC I think u have to use ask to rpl server [cineck] soft does not calculate field 308 properly for ur phone. Regards | |
n81 power off after 20 minutes [SOLVED] | cobraro22 | Cyclonebox | 6 | 02-18-2010 10:55 |
bb5 power off after 20, 10 minutes | chahin | HWK | 2 | 09-29-2009 02:05 |
E62 rm88, power off after 10/20 minutes | maurocentec | Nokia Base Band 5 ( BB-5 ) | 6 | 05-08-2009 14:08 |
April 18 through 20, 2009 will be days off | GSM_Support | Smart-Clip | 1 | 04-20-2009 01:48 |
April 18 through 20, 2009 will be days off | GSM_Support | Scout | 0 | 04-17-2009 13:45 |
