Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > No more Support JAF Products. > JAF No Tp Unlocker by Cinek
Old 04-09-2009, 21:52   #1 (permalink)
Member: 318507
N95 detected by JAF, not by No TP 1.04
JAF version 1.98.63
Detected PKEY: 90*****
Card life counter: 99.61%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.0.2.0
Changing mode...Done!
Booting phone...
FAST PHONE detected!
APE Boot Data:
Asic ID: 24200705
Asic Mode ID: 00
Asic Public ID: F55B43868879251375465EC162606432E49F5C1F
HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
ROM ID: 0000000000000000
CMT Boot Data:
Asic ID: 000000010000022600010006400C192101021103
Asic Mode ID: 00
Asic EM ID: 00000B22
Asic Public ID: 174001161E7B00585D49CBB9A0C3EDB8E6FD137E
HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE00000000
ROM ID: A8C1D6713E691FF8
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_2nd.fg
Loader version: 01.1E.00 -> Revision: 0000
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
CMT Boot Ready
CMT Flash ID: 00350001 <=> SPANSION -> 72NS128N
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_algo.fg
Loader version: 01.23.00 -> Revision: 0000
Patching CMT loader step1...
Patching CMT loader step3...
CMT Loader Ready
APE Boot: C:\Program Files\ODEON\JAF\Flash\omap2420_m1_2nd.fg
Loader version: 01.27.00 -> Revision: 0000
Patching APE boot step1...
Patching APE boot step2...
Patching APE boot step3...
APE Boot Ready
APE Flash ID: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA
APE Flash Data: Not Available
Done!
Restarting phone...Done!
When I try Nokia BB5 No TP 1.04, Sometimes it opens twice.
After many tries I get:
JAF box ATmega firmware version: 1B1
Searching for phone ...
ERROR: Cannot detect phone on FBUS interface
Operation time: 00:12.
Done with error(s).
Thread phone exit.
Old 04-10-2009, 03:43   #2 (permalink)
Member: 318507
Re: Post #1
I have unlocked most N95s no problem but this one will not unlock (I had 1 other one that did not unlock).
I am now using powered USB hub, bench power supply via diode to +batt terminal, 7.5k resistor to BSI and now phone is being detected. I can do CRT backup in JAF and CHK is ok.
I have to click Unlock several time before the procedure finds phone and starts.
I am running out of ideas. Here is log:
Phone found on FBUS interface
Reading phone info ...
SP LOCK status:
Block 1: CLOSED Type 5 Data: 23420F
Block 2: CLOSED Type 5 Data: 23420F
Block 3: CLOSED Type 5 Data: 23594F
Block 4: CLOSED Type 5 Data: 23594F
Read Phone Info OK
Reading PM Field 308 Subfield 1 with length 8192 bytes
Saving to file: RM-159_358998015873568_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v43.1_15-10-07_RM-159_(c)_Nokia__10_04_2009__03_34_46.bin
PM308 backup OK
Searching for JAF box ...
JAF box detected
Initialize JAF box ...
JAF box JAFBOX_BB5_FLASH_bb5challenge ...
ASIC ID: 000000010000022600010006400C192101021103
JAF no TP v1.04
Sending loader...
RAPIDO_OLD selected.
BB5_FLASH_CMTbootload
JAF CMT Boot Ready
Hello ok
bb5king ldr start
bb5king send code ok
Get card info ...
Verify card OK
Get card info ...
Verify card OK
Hello ok
Hello ok
PM send.
Test call...
cpsr - 0x0000001F
p15_1 - 0x00C5387A
p15_2 - 0x00C5197E
p15_3 - 0x00C5397E
PM_308 CRC - 0x000C7E0B
ki - 0x00000001
ri - 0x00000001
pi - 0x00000001
param - 0x03, size - 0x00
UpdSLock - 0x00000001
PM_308 CRC - 0x0019251B
Reciving PM
Hello ok
PM buff recived
After unlock.
Operation time: 00:42.
Done with error(s).
Thread phone exit.
Old 04-10-2009, 11:54   #3 (permalink)
Member: 318507
Re: posts 1 & 2
I have removed diode, connected bench PSU directly to Batt+ and increased BSI resistance to 15k. Phone goes into 'test mode' now (I'm sure it was 'local mode' before) but still the same result. Goes right through the unlock procedure ok but fails right at the end.
Can anyone help please, I am tearing my hair out?
Old 04-10-2009, 20:40   #4 (permalink)
Member: 742967
i have the same problem, i have spent three days trying to understand why, but not any clue. using jaf software..ok
other software....error
Old 04-10-2009, 20:50   #5 (permalink)
Member: 318507
After trying many different combinations of cables and resistors, my N95 gets detected and goes through the unlocking procedure but cannot be detected after unlock. Phone powers up ok and still works with original 3 sim. Phone is still locked to 3.
What is your story?
Old 04-11-2009, 18:55   #6 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
It is almost sw v30.0.0.15,I'm stuck with it here,it can't even detected for unlock
Old 04-11-2009, 20:57   #7 (permalink)
mr.6630's Avatar
Member: 148424
Sonork: 100.93619
just use no tp v1.3
it's work good with n95
br
Old 04-11-2009, 20:59   #8 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Is a slow mobile..
The only system I have to unlock them, without having a mobile not found on fbus interface during the operations is keeping my computer busy coping big files from a directory to another for all the unlocking process..
Normally i use the Divx movies folder (30 gb of files).
if i dont soon or later the job stops for the mobile not found error
Alex
Old 04-18-2009, 11:06   #9 (permalink)
Member: 3811
have you tried to remove screen and disconnect camera flex ...mobile should now go into local mode ...............
Old 04-20-2009, 18:30   #10 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1626059
not work your solution.
And olso this solution not work and phone not stabl in local mode.
1- donwgrade version from 30.0.15 to 20.0.15 but same
2- upgrade version from 20.0.15 to 31.0.17 but same
3- downgrade version from 31.0.17 to original orange flash but same.
finally this is first phone not unlock
i unlock other n95 simply .
i use many soft ( bb5 king w tp) .
lahdache
Old 04-20-2009, 18:51   #11 (permalink)
indikait's Avatar
Member: 241637
Sonork: 100.1620549
Use 1.03
i unlocked 3 pcs 100%
Old 04-20-2009, 19:11   #12 (permalink)
Member: 411486
i've got many problems too with the N95 unlock.but finally i made test point cu'z from my opinion it's the most easiest test point ever made.so for how much time did you lost you coul'd unlock 20 pieces i think .and by the way i also made a power supply for J.A.F for not stable local mode and now works great.
Old 04-28-2009, 02:30   #13 (permalink)
zeroualot_7's Avatar
Member: 112112
Sonork: 100.1621373
a use 1.4 100/100 unlock
27-04-2009 1:09:06 JAF box ATmega firmware version: 1B1
27-04-2009 1:09:16 Searching for phone ...
27-04-2009 1:09:16 Phone found on FBUS interface
27-04-2009 1:09:16 Reading phone info ...
27-04-2009 1:09:16 Type: RM-159
27-04-2009 1:09:16 Version: V_06wk41v59.1_02-06-08_RM-159_(c)_Nokia
27-04-2009 1:09:16 IMEI: 356843028310533
27-04-2009 1:09:16 SP LOCK status:
27-04-2009 1:09:16 Config Key: 2081000000000000
27-04-2009 1:09:16 Block 1: CLOSED Type 5 Data: 20810F
27-04-2009 1:09:16 Block 2: CLOSED Type 5 Data: 20810F
27-04-2009 1:09:16 Block 3: CLOSED Type 5 Data: 64710F
27-04-2009 1:09:16 Block 4: CLOSED Type 5 Data: 64710F
27-04-2009 1:09:16 Key counter: 0/3
27-04-2009 1:09:16 Cable counter: 0/10
27-04-2009 1:09:16 Read Phone Info OK
27-04-2009 1:09:16 Operation time: 00:11.
27-04-2009 1:09:16 Successfully done.
27-04-2009 1:09:29 JAF box ATmega firmware version: 1B1
27-04-2009 1:09:39 Searching for phone ...
27-04-2009 1:09:39 Phone found on FBUS interface
27-04-2009 1:09:39 Reading phone info ...
27-04-2009 1:09:39 Reading PM Field 308 Subfield 1 with length 8192 bytes
27-04-2009 1:09:42 Saving to file: RM-159_356843028310533_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v59.1_02-06-08_RM-159_(c)_Nokia__27_04_2009__01_09_42.bin
27-04-2009 1:09:42 PM308 backup OK
27-04-2009 1:09:42 Operation time: 00:14.
27-04-2009 1:09:42 Successfully done.
27-04-2009 1:12:13 JAF box ATmega firmware version: 1B1
27-04-2009 1:12:23 Searching for phone ...
27-04-2009 1:12:24 Phone found on FBUS interface
27-04-2009 1:12:24 Reading phone info ...
27-04-2009 1:12:24 Type: RM-159
27-04-2009 1:12:24 Version: V_06wk41v59.1_02-06-08_RM-159_(c)_Nokia
27-04-2009 1:12:24 IMEI: 356843028310533
27-04-2009 1:12:24 SP LOCK status:
27-04-2009 1:12:24 Config Key: 2081000000000000
27-04-2009 1:12:24 Block 1: CLOSED Type 5 Data: 20810F
27-04-2009 1:12:24 Block 2: CLOSED Type 5 Data: 20810F
27-04-2009 1:12:24 Block 3: CLOSED Type 5 Data: 64710F
27-04-2009 1:12:24 Block 4: CLOSED Type 5 Data: 64710F
27-04-2009 1:12:24 Key counter: 0/3
27-04-2009 1:12:24 Cable counter: 0/10
27-04-2009 1:12:24 Read Phone Info OK
27-04-2009 1:12:24 Searching for phone ...
27-04-2009 1:12:24 Reading PM Field 308 Subfield 1 with length 8192 bytes
27-04-2009 1:12:32 Saving to file: RM-159_356843028310533_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v59.1_02-06-08_RM-159_(c)_Nokia__27_04_2009__01_12_32.bin
27-04-2009 1:12:32 PM308 backup OK
27-04-2009 1:12:32 Searching for JAF box ...
27-04-2009 1:12:32 JAF box detected
27-04-2009 1:12:33 JAF box ATmega firmware version: 1B1
27-04-2009 1:12:33 Initialize JAF box ...
27-04-2009 1:12:33 JAF box JAFBOX_BB5_FLASH_bb5challenge ...
27-04-2009 1:12:34
27-04-2009 1:12:34 ASIC ID: 000000010000022600010006400C192101031103
27-04-2009 1:12:34 HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
27-04-2009 1:12:34 ROM ID: 4B9B75103E691FF8
27-04-2009 1:12:34 JAF no TP v1.04
27-04-2009 1:12:34 Sending loader...
27-04-2009 1:12:34 RAPIDO_OLD selected.
27-04-2009 1:12:34 BB5_FLASH_CMTbootload
27-04-2009 1:12:34 JAF CMT Boot Ready
27-04-2009 1:12:34
27-04-2009 1:12:35 Hello ok
27-04-2009 1:12:35 bb5king ldr start
27-04-2009 1:12:35 bb5king send code ok
27-04-2009 1:12:43 Hello ok
27-04-2009 1:12:43 PM send.
27-04-2009 1:12:43 Test call...
27-04-2009 1:12:43 cpsr - 0x0000001F
27-04-2009 1:12:43 p15_1 - 0x00C5387A
27-04-2009 1:12:44 p15_2 - 0x00C5197E
27-04-2009 1:12:44 p15_3 - 0x00C5397E
27-04-2009 1:12:44 PM_308 CRC - 0x000C8012
27-04-2009 1:12:44 ki - 0x00000001
27-04-2009 1:12:44 ri - 0x00000001
27-04-2009 1:12:44 pi - 0x00000001
27-04-2009 1:12:44 param - 0x03, size - 0x00
27-04-2009 1:12:44 UpdSLock - 0x00000001
27-04-2009 1:12:44 PM_308 CRC - 0x0018F81D
27-04-2009 1:12:44 Reciving PM
27-04-2009 1:12:46 Hello ok
27-04-2009 1:12:46 PM buff recived
27-04-2009 1:12:46 After unlock.
27-04-2009 1:12:47 JAF box ATmega firmware version: 1B1
27-04-2009 1:12:57 Searching for phone ...
27-04-2009 1:12:57 Phone found on FBUS interface
27-04-2009 1:12:57 Writting PM Field 308 Subfield 1 with length 8192 bytes
27-04-2009 1:13:05 0x13040023
27-04-2009 1:13:05 Operation time: 00:52.
27-04-2009 1:13:05 Done with error(s).
27-04-2009 1:13:27 JAF box ATmega firmware version: 1B1
27-04-2009 1:13:37 Searching for phone ...
27-04-2009 1:13:38 ERROR: Cannot detect phone on FBUS interface
27-04-2009 1:13:38 Operation time: 00:12.
27-04-2009 1:13:38 Done with error(s).
27-04-2009 1:13:45 JAF box ATmega firmware version: 1B1
27-04-2009 1:13:55 Searching for phone ...
27-04-2009 1:13:55 Phone found on FBUS interface
27-04-2009 1:13:55 Reading phone info ...
27-04-2009 1:13:55 Type: RM-159
27-04-2009 1:13:55 Version: V_06wk41v59.1_02-06-08_RM-159_(c)_Nokia
27-04-2009 1:13:55 IMEI: 356843028310533
27-04-2009 1:13:56 SP LOCK status:
27-04-2009 1:13:56 Config Key: 2440700000000000
27-04-2009 1:13:56 Block 1: OPEN Type 5 Data: FFFFFF
27-04-2009 1:13:56 Block 2: OPEN Type 5 Data: FFFFFF
27-04-2009 1:13:56 Block 3: OPEN Type 5 Data: FFFFFF
27-04-2009 1:13:56 Block 4: OPEN Type 5 Data: FFFFFF
27-04-2009 1:13:56 Block 5: OPEN Type 5 Data: FFFFFF
27-04-2009 1:13:56 Block 6: OPEN Type 5 Data: FFFFFF
27-04-2009 1:13:56 Block 7: OPEN Type 5 Data: FFFFFF
27-04-2009 1:13:56 Key counter: 0/3
27-04-2009 1:13:56 Cable counter: 0/10
27-04-2009 1:13:56 Read Phone Info OK
27-04-2009 1:13:56 Operation time: 00:11.
27-04-2009 1:13:56 Successfully done.
6133 cinek bb5 no tp 1.04 Orane JAF No Tp Unlocker by Cinek 0 04-28-2009 00:20
JAF Nokia BB5 No TP Unlocker v1.00 by [c]Cinek WORKING OK,, VERIFIED 100%.. S_R JAF No Tp Unlocker by Cinek 62 04-03-2009 13:14
JAF Nokia BB5Plus No TP Unlocker v1.00b by [c]Cinek Sandeep Mobiles JAF No Tp Unlocker by Cinek 6 03-21-2009 13:04
JAF Nokia BB5Plus No TP Unlocker v1.00b by [c]Cinek Raskal GSM News & Updates 0 03-20-2009 20:17
Using JAF Nokia BB5 No. TP Unlocker v1.00 by [c] Cinek? bosnian J.A.F. By Jafsupport.com 3 12-17-2008 17:09
Page generated in 0.41172 seconds with 11 queries
