03-31-2009, 15:15 | #1 (permalink) |
Junior Member Join Date: Dec 2008
Member: 920626 Status: Offline Thanks Meter: 0 | BB5+ no tp v 10.00b by Cinek & Done with error(s). Box Activated on bb5+ nokia 6500s-1 v8.30 phone is local mode -------------------------------- Check Account: Connecting to server... Credits: 20 -------------------------------- Chk Connection: Searching for JAF box ... JAF box detected JAF box ATmega firmware version: 1B1 Initialize JAF box ... JAF box JAFBOX_BB5_FLASH_bb5challenge ... Error. 0x10130103 ERROR! Operation time: 00:11. Successfully done. Thread phone exit. ------------------------------------------- Phone Info: JAF box ATmega firmware version: 1B1 Searching for phone ... ERROR: Cannot detect phone on FBUS interface Operation time: 00:12. Done with error(s). Thread phone exit. ------------------------------------------- UNLOCK: JAF box ATmega firmware version: 1B1 Searching for phone ... ERROR: Cannot detect phone on FBUS interface Operation time: 00:12. Done with error(s). Thread phone exit. ------------------------------------------- what's wrong? cable? |
03-31-2009, 17:57 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Ok... Start before of all asking the info.. if you can get the info it is ok.. If you can get the info then do the back-up!!! after the back-up you can try to unlock it... If you are using the universal cable use 7.5 K resistor remeber the bsi is on the left, the red go on the right and the ground in the middle.. some pictures of pinouts are wrong. As well this mobile is a quite slow.. so sometime the software goes in timeout before it goes in local mode... start an antivurs scan before doing the job.. keep busy the computer enough to sort out the problem until cinek decide to use longer timeout timing. BR Alex |
03-31-2009, 18:21 | #3 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Northern Ireland
Member: 554722 Status: Offline Thanks Meter: 60 | 6500S and 6500C slow to boot on fbus. I found the 6500s and 6500c slow to boot with the cable make sure backup do the backup once it is connected. bout to do a 6500c yesterday and it dropped of the cable after backup just as i was about to unlock take your time let the phone sit a min or to before proceeding. Cheers |
03-31-2009, 18:29 | #4 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: Algeria
Member: 218246 Status: Offline Thanks Meter: 58 | Quote:
03-31-2009, 18:37 | #6 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
Bro just n only just cable fault use with UFS_INTERFACE,,,,,10000000% solution... BR | |
03-31-2009, 23:34 | #7 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 322957 Status: Offline Thanks Meter: 6 | Nokia 5310 backup error Hi, When I try to make backup of 5310, I get followin error. I cannot unlock it either because of not having backup. I tested two jaf universal cables, so its not a cable problem. Do I need credits to unlock this phone? I have no sagem credits. JAF box ATmega firmware version: 1B1 Searching for phone ... Phone found on FBUS interface Reading phone info ... Reading PM Field 308 Subfield 1 with length -1 bytes Error. 0x12200002 Error. 0x13030010 Operation time: 00:11. Done with error(s). Thread phone exit. Last edited by shaak28; 03-31-2009 at 23:39. |
08-21-2010, 19:18 | #8 (permalink) |
Junior Member Join Date: Aug 2010
Member: 1375216 Status: Offline Thanks Meter: 3 | Hi im new to all this and a complete amateur lool i installed the JAF suite and the software called zulea v2.01 and ran it and installed it. i am trying to use it to unlokc a Nokia n70 this is what it says: Searching for JAF box ... JAF box detected Box firmware version: 1B1 Searching for phone ... ERROR: Cannot detect phone on FBUS interface i tried two different cable and phones but same thing wat should i do please help |
The Following 2 Users Say Thank You to wasp73mug For This Useful Post: |
JAF Nokia BB5 No TP Unlocker v1.00 by [c]Cinek WORKING OK,, VERIFIED 100%.. | S_R | JAF No Tp Unlocker by Cinek | 62 | 04-03-2009 13:14 |
problem with activation JAF Nokia BB5Plus (+) no TP Unlocker v1.00b by [c] Cinek | fouad1 | JAF No Tp Unlocker by Cinek | 5 | 03-24-2009 03:19 |
JAF Nokia BB5Plus No TP Unlocker v1.00b by [c]Cinek | Sandeep Mobiles | JAF No Tp Unlocker by Cinek | 6 | 03-21-2009 13:04 |
JAF Nokia BB5Plus No TP Unlocker v1.00b by [c]Cinek | Raskal | Service Products News & Updates | 0 | 03-20-2009 20:17 |
JAF BB5 No TP Unlocker v1.00 by [c]Cinek Working Fine No Kill Pkey Video Proof Here | mbcommunication | JAF No Tp Unlocker by Cinek | 3 | 12-14-2008 22:06 |
