Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > No more Support JAF Products. > JAF No Tp Unlocker by Cinek
Old 07-23-2010, 17:05   #1 (permalink)
Member: 1162060
N95 rm-159 help unlocking
hi
I'm trying to unlock this n95 with no success
at first i thought its a cable problem so i got the x-fbus cable
now jaf is reading phone info but bb5 notp unlocker having this Error. 0x10130103
please your help how to unlock this phone
JAF version 1.98.65
Detected PKEY: xxxxxx
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B4, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: d:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: D:\Program Files\ODEON\JAF\
JAF USB LOADERS DIR: d:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: d:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.0.2.0
Changing mode...Done!
Backing up CRT data...
Setting FLASH MODE
FAST PHONE detected!
Loader version: 09.30.00 -> Revision: 0200
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
CMT Boot Ready
CMT Flash ID: 2C7E0001 <=> SPANSION -> 72NS128N
CMT Flash Data: NOT AVAILABLE
d:\Program Files\ODEON\JAF\Flash\RAPIDOv11_XSR15_alg.fg...
........Sending CMT HASH for PASUBTOC
.........................Sending CMT HASH for ALG
...........................Done!
Reading CMT NPC certificate...
Reading CMT VARIANT certificate...
VARIANT CRT empty, skip save...
Reading CMT CCC certificate...
Reading CMT HWC certificate...
Saved to d:\Program Files\ODEON\JAF\ProgData\35806401834642_CRT_backup_1851237.rpl
Backup CRT OK!
Backing up SIMLOCK data...
Setting local mode...
Reading IMEI...
d:\Program Files\ODEON\JAF\ProgData\358064018346423_CRT_backup_1854237.pm
Done!
Backup LCK OK!
Reading SW version...06wk41v59.1 30.0.015
Done!
Total time: 0 Minutes, 0 Seconds
DCT4/BB5 counter: 0
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RM-159, Software version: 06wk41v59.1
IMEI: 358064018346423
APE Ver: 30.0.015
Variant Ver: 30.0.01573.01
Product Code: 0551413
Done!
Old 07-23-2010, 17:39   #2 (permalink)
tariq_h's Avatar
Member: 896307
Sonork: 0096
Thanks Meter: 231
DO u have usf3 instead of jaf
Old 07-23-2010, 18:26   #3 (permalink)
Member: 1162060
no.................................
Old 07-23-2010, 18:42   #4 (permalink)
tariq_h's Avatar
Member: 896307
Sonork: 0096
Thanks Meter: 231
So, make check &info after check and post again please, may be i help u
Old 07-23-2010, 18:59   #5 (permalink)
Member: 1162060
JAF version 1.98.65
Detected PKEY: xxxxxxx
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 06wk41v59.1
02-06-08
RM-159
(c) Nokia
HW version: 6035
PCI version:
RFIC version:  17141715
DSP version:
ICPR62_08w16
APE SW Core version: 30.0.015
APE Variant version: 30.0.01573.01
APE Test version: rm159_eno_Cust2008wk14updv0
Retu version: 15
Tahvo version: 22
APE HW version: 1
APE ADSP SW version: 256
APE BT version: HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.
Production serial number: MJK123863
Product code: 0551413
Module code:
Basic production code: 0530865
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 358064018346423
IMEI spare to net: 3A 85 60 04 81 43 46 02
IMEI SV to net: 33 85 60 04 81 43 46 12 F7
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 4250100000000000
Provider: Orange - Partner Communications;Israel
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: CLOSED -> Lock Data: 42501F
Block 2:
Lock 1: CLOSED -> Lock Data: 42510F
Block 3:
Block 4:
Searching for saved ini...
Checking for file d:\Program Files\ODEON\JAF\JAF_RM-159.ini
Saved INI not found, loading INI list...
Reading product code...
Searching for JAF saved location of ini...
Checking path: D:\Program Files\ODEON\JAF\RM-159\
Searching for default location of ini...
Checking path: d:\Program Files\Common Files\Nokia\DataPackage\Products\RM-159\
No ini files found...
Done!
Booting phone...
APE Boot Data:
Asic ID: 24200705
Asic Mode ID: 00
Asic Public ID: E8952A0CDC192E6C5C41B35BCB208FAB57C8CBA9
HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
ROM ID: 0000000000000000
CMT Boot Data:
Asic ID: 000000010000022600010006400C192101021103
Asic Mode ID: 00
Asic EM ID: 00000B22
Asic Public ID: 12400012926B00526E37533100AF531A902270E4
HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE00000000
ROM ID: A8C1D6713E691FF8
CMT Boot File: d:\Program Files\ODEON\JAF\Flash\RAPIDOv11_2nd.fg
CMT Boot Ready
CMT Loader Ready
APE Boot: d:\Program Files\ODEON\JAF\Flash\OMAP2420_2nd.fg
Patching APE boot step1...
Patching APE boot step2...
Patching APE boot step3...
APE Boot Ready
APE Flash ID: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA
APE Flash Data: Not Available
Done!
Restarting phone...Done!
Old 07-23-2010, 19:10   #6 (permalink)
tariq_h's Avatar
Member: 896307
Sonork: 0096
Thanks Meter: 231
1) backup before doing anything
2)close jaf
3) open jaf nokia bb5 unlocker 104 download from herehttp://support.****************/files/...free%20addons/
4) make pm back up
5) press unlock , wait till finish
6) all done and i hope it works
Old 07-23-2010, 19:14   #7 (permalink)
Member: 1162060
this is the problem its not working
Error. 0x10130103
Old 07-23-2010, 19:27   #8 (permalink)
SHOEB AHMED's Avatar
Member: 161115
Sonork: Here you can find it...
Thanks Meter: 3,039
Error. 0x10130103
use good cable set mast be test mode.
Old 07-23-2010, 19:29   #9 (permalink)
tariq_h's Avatar
Member: 896307
Sonork: 0096
Thanks Meter: 231
[QUOTE=SHOEB AHMED;6121140]use good cable set mast be test mode
MY FRIEND IS RIGHT USE ORIGINAL CABLE IN ORDER TO GO TEST MODE
Old 07-23-2010, 19:40   #10 (permalink)
Member: 1162060
from jaf i can change phone mode to local mode
i was shore my regular fbus cable is no good have been Reading about wrong resistor and connecting another usb power so i bout the x-fbus set
that i can change resistor value and see that pins are setup good and still
cant unlock this phone
BTW i got the same problem with e51-1 rm244
Old 07-24-2010, 07:42   #11 (permalink)
tariq_h's Avatar
Member: 896307
Sonork: 0096
Thanks Meter: 231
Simply jaf has been finished.In other words, after the last update of it ,it makes alot of troubles and is about to disappear in the market .it is good now only for flashin not unlockin.To sum up , buy " the little ....giant" Mxkey ,it is cheap,free,reliable and the best tool in the world for now to unlock and repair Nokia,blackberry,htc,hawai,vodafone
just buy this dongle ,it is going to cost u 65 $ and u will enjoy repair contact service and unlock very easy and fast
Read more here about itMXKEY Nokia Flasher and Unlocker (by Alim Hape) - GSM-Forum
so we cannt help u with jaf (killed in the market)
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Page generated in 0.19422 seconds with 9 queries
