12-17-2008, 21:37 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: usa
Member: 220874 Status: Offline Thanks Meter: 64 | how to unlock nokia 6085h RM198 nokia 6085h rm-198 from att(usa) i tried whit jaf nokia bb5 unlokcer but only error apear please |
The Following User Says Thank You to ALGUIEN For This Useful Post: |
12-17-2008, 22:18 | #3 (permalink) |
Member: 220874 Status: Offline Thanks Meter: 64 | hope it will help i choose BB5 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 04.29 03-05-07 RM-198 (c) Nokia. HW version: 1403 PCI version: RFIC version: 17211721 DSP version: pb06w14v50.1 PPM version: V 04.29 15-05-07 RM-198 (c) Nokia. IAT BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content:att 15-05-07 RM-198 (c) Nokia. Production serial number: OC0865839 Product code: 0544936 Module code: Basic production code: 0534628 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 354831016998528 IMEI spare to net: 3A 45 38 01 61 99 58 02 IMEI SV to net: 33 45 38 01 61 99 58 12 F8 LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 3101700000000000 Provider: CINGULAR - Pacific Bell Wireless;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310150 Block 2: Lock 1: CLOSED -> Lock Data: 310170 Block 3: Lock 1: CLOSED -> Lock Data: 311180 Block 4: Lock 1: CLOSED -> Lock Data: 310410 Block 5: Lock 1: CLOSED -> Lock Data: 310980 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-198.ini FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\354831016998528_CRT_backu p_13161712.pm Done! Backup LCK OK! Setting local mode... Reading simlock data... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 3101700000000000 Provider: CINGULAR - Pacific Bell Wireless;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310150 Block 2: Lock 1: CLOSED -> Lock Data: 310170 Block 3: Lock 1: CLOSED -> Lock Data: 311180 Block 4: Lock 1: CLOSED -> Lock Data: 310410 Block 5: Lock 1: CLOSED -> Lock Data: 310980 Reading imei... Reading codes data... Found codes data... Resetting phone... Waiting for phone... Reading soft info... Reading simlock data... Writing codes data... Read SP data error! or Phone not supported |
12-17-2008, 22:22 | #4 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Earth
Member: 426389 Status: Offline Thanks Meter: 2,356 | I told you helps... You can't unlock this phone with Jaf main exe, use Jaf bb5 no tp unlocker : http://support4.****************/files...5_Unlocker.rar |
12-17-2008, 22:29 | #5 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | yeah its bb5 can not be unlocked in jaf application you have to download addone! called bb5king or notp unlocker by jaff supprot Regards, Asad |
12-17-2008, 22:45 | #6 (permalink) | |
Member: 220874 Status: Offline Thanks Meter: 64 | Quote:
Error. 0x10010401 Error. 0x10010602 Error. 0x13010108 Operation time: 00:00. Done with error(s). Thread phone exit. also when i choose devices and check conection this is what appear JAF box JAFBOX_BB5_FLASH_bb5challenge ... Error. 0x10010301 Error. 0x10130101 ERROR! Operation time: 00:00. Successfully done. Thread phone exit. | |
12-17-2008, 22:49 | #7 (permalink) | |
Member: 426389 Status: Offline Thanks Meter: 2,356 | Quote:
Try to replace the resistor from bsi line with higher value, like 8.2k | |
12-18-2008, 02:15 | #9 (permalink) | |
Searching for JAF box ... JAF box detected JAF box ATmega firmware version: 1B0 Initialize JAF box ... JAF box JAFBOX_BB5_FLASH_bb5challenge ... ASIC ID: 000000010000022600010006010C192101001101 HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Operation time: 00:08. Successfully done. NOW WHAT I'M DOING WRONG | |
12-18-2008, 06:25 | #10 (permalink) |
Crazy Poster Join Date: Apr 2007
Member: 487063 Status: Offline Thanks Meter: 0 | i have problem with rm 198 n6085h....log AF box ATmega firmware version: 1B0 Searching for phone ... Phone found on FBUS interface Reading phone info ... SP LOCK status: Read Phone Info OK Searching for phone ... Phone found on FBUS interface Reading phone info ... Reading PM Field 308 Subfield 1 with length 8192 bytes Saving to file: RM-198_352920029377333_Unlocked_Keycnt_0_Fbuscnt_0__V _06.00_28-11-07_RM-198_(c)_Nokia.__18_12_2008__10_51_09.bin PM308 backup OK Searching for JAF box ... JAF box detected JAF box ATmega firmware version: 1B0 Initialize JAF box ... JAF box JAFBOX_BB5_FLASH_bb5challenge ... ASIC ID: 000000010000022600010006010C192101001101 HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F bb5king SW v1.07 Sending loader... Rap3Gv3 selected. BB5_FLASH_CMTbootload JAF CMT Boot Ready Hello ok ok Get card info ... Verify card OK Get card info ... Verify card OK Hello ok Hello ok PM send. Test call... cpsr - 0x0000001F p15_1 - 0x0005307F p15_2 - 0x0005117F p15_3 - 0x0005317F esn_init ret - 0x00000001, <tmp_buff2> - 0x00000001 esn_read ret - 0x00000001, <tmp_buff2> - 0x00000001 Normal BB5 found - 0x0002B7E0 UpdSLock - 0x00000001 ret - 0x01, <tmp_buff2> - 0x0B PM_308 CRC - 0x00050552 Error. Phone not calculate PM308! Maybe this phone have PM overwritten by PM from other phone or you need upgrade/downgrade phone FW! Operation time: 00:34. Done with error(s). Thread phone exit |
12-18-2008, 08:36 | #12 (permalink) | ||
Freak Poster Join Date: Feb 2006 Location: India
Member: 232566 Status: Offline Thanks Meter: 150 | Quote:
i was Getting the same Error and i needed to upgrade the firmware version of mobile.I upgraded and unlocked. Here is the Log.. 12/17/2008 10:02:59 PM JAF box ATmega firmware version: 1B0 12/17/2008 10:03:13 PM Searching for phone ... 12/17/2008 10:03:14 PM Phone found on FBUS interface 12/17/2008 10:03:14 PM Reading phone info ... 12/17/2008 10:03:14 PM Type: RM-198 12/17/2008 10:03:14 PM Version: V_06.00_28-11-07_RM-198_(c)_Nokia. 12/17/2008 10:03:14 PM IMEI: 354837012345678 12/17/2008 10:03:14 PM SP LOCK status: 12/17/2008 10:03:14 PM Config Key: 3101700000000000 12/17/2008 10:03:14 PM Block 1: CLOSED Type 5 Data: 310150 12/17/2008 10:03:14 PM Block 2: CLOSED Type 5 Data: 310170 12/17/2008 10:03:14 PM Block 3: CLOSED Type 5 Data: 311180 12/17/2008 10:03:14 PM Block 4: CLOSED Type 5 Data: 310410 12/17/2008 10:03:14 PM Block 5: CLOSED Type 5 Data: 310980 12/17/2008 10:03:14 PM Key counter: 0/3 12/17/2008 10:03:14 PM Cable counter: 0/10 12/17/2008 10:03:14 PM Read Phone Info OK 12/17/2008 10:03:14 PM Searching for phone ... 12/17/2008 10:03:14 PM Phone found on FBUS interface 12/17/2008 10:03:14 PM Reading phone info ... 12/17/2008 10:03:14 PM Reading PM Field 308 Subfield 1 with length 8192 bytes 12/17/2008 10:03:16 PM Saving to file: RM-198_354837012345678_Locked_Keycnt_0_Fbuscnt_0__V_0 6.00_28-11-07_RM-198_(c)_Nokia.__17_12_2008__22_03_16.bin 12/17/2008 10:03:16 PM PM308 backup OK 12/17/2008 10:03:16 PM Searching for JAF box ... 12/17/2008 10:03:16 PM JAF box detected 12/17/2008 10:03:17 PM JAF box ATmega firmware version: 1B0 12/17/2008 10:03:17 PM Initialize JAF box ... 12/17/2008 10:03:17 PM JAF box JAFBOX_BB5_FLASH_bb5challenge ... 12/17/2008 10:03:18 PM 12/17/2008 10:03:18 PM ASIC ID: 000000010000022600010006010C192101001101 12/17/2008 10:03:18 PM HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 12/17/2008 10:03:18 PM ROM ID: 191EC665DFAAF68F 12/17/2008 10:03:18 PM bb5king SW v1.07 12/17/2008 10:03:18 PM Sending loader... 12/17/2008 10:03:18 PM Rap3Gv3 selected. 12/17/2008 10:03:18 PM BB5_FLASH_CMTbootload 12/17/2008 10:03:18 PM JAF CMT Boot Ready 12/17/2008 10:03:18 PM 12/17/2008 10:03:19 PM Hello ok 12/17/2008 10:03:19 PM ok 12/17/2008 10:03:30 PM Hello ok 12/17/2008 10:03:31 PM Hello ok 12/17/2008 10:03:31 PM PM send. 12/17/2008 10:03:31 PM Test call... 12/17/2008 10:03:31 PM cpsr - 0x0000001F 12/17/2008 10:03:31 PM p15_1 - 0x0005307F 12/17/2008 10:03:31 PM p15_2 - 0x0005117F 12/17/2008 10:03:31 PM p15_3 - 0x0005317F 12/17/2008 10:03:31 PM esn_init ret - 0x00000001, <tmp_buff2> - 0x00000001 12/17/2008 10:03:31 PM esn_read ret - 0x00000001, <tmp_buff2> - 0x00000001 12/17/2008 10:03:31 PM Normal BB5 found - 0x0002B7E0 12/17/2008 10:03:32 PM LR - FFFF3688, param - 0x03, size - 0x00 12/17/2008 10:03:32 PM UpdSLock - 0x00000001 12/17/2008 10:03:32 PM ret - 0x01, <tmp_buff2> - 0x23 12/17/2008 10:03:32 PM PM_308 CRC - 0x000D48E9 12/17/2008 10:03:32 PM Reciving PM 12/17/2008 10:03:34 PM Hello ok 12/17/2008 10:03:34 PM PM buff recived 12/17/2008 10:03:34 PM After unlock. 12/17/2008 10:03:35 PM JAF box ATmega firmware version: 1B0 12/17/2008 10:03:49 PM Searching for phone ... 12/17/2008 10:03:49 PM Phone found on FBUS interface 12/17/2008 10:03:50 PM Writting PM Field 308 Subfield 1 with length 8192 bytes 12/17/2008 10:03:53 PM Reset phone ... 12/17/2008 10:03:56 PM PM Field 308 Subfield 1 written OK 12/17/2008 10:03:56 PM Operation time: 00:57. 12/17/2008 10:03:56 PM Successfully done. 12/17/2008 10:04:04 PM JAF box ATmega firmware version: 1B0 12/17/2008 10:04:18 PM Searching for phone ... 12/17/2008 10:04:19 PM Phone found on FBUS interface 12/17/2008 10:04:19 PM Reading phone info ... 12/17/2008 10:04:19 PM Type: RM-198 12/17/2008 10:04:19 PM Version: V_06.00_28-11-07_RM-198_(c)_Nokia. 12/17/2008 10:04:19 PM IMEI: 354837012345678 12/17/2008 10:04:19 PM SP LOCK status: 12/17/2008 10:04:19 PM Config Key: 2440700000000000 12/17/2008 10:04:19 PM Block 1: OPEN Type 5 Data: FFFFFF 12/17/2008 10:04:19 PM Block 2: OPEN Type 5 Data: FFFFFF 12/17/2008 10:04:19 PM Block 3: OPEN Type 5 Data: FFFFFF 12/17/2008 10:04:19 PM Block 4: OPEN Type 5 Data: FFFFFF 12/17/2008 10:04:19 PM Block 5: OPEN Type 5 Data: FFFFFF 12/17/2008 10:04:19 PM Block 6: OPEN Type 5 Data: FFFFFF 12/17/2008 10:04:19 PM Block 7: OPEN Type 5 Data: FFFFFF 12/17/2008 10:04:19 PM Key counter: 0/3 12/17/2008 10:04:19 PM Cable counter: 0/10 12/17/2008 10:04:19 PM Read Phone Info OK 12/17/2008 10:04:19 PM Operation time: 00:15. 12/17/2008 10:04:19 PM Successfully done. | ||
12-23-2008, 14:34 | #13 (permalink) | |
No Life Poster Join Date: May 2007 Location: TUNISIA Age: 40
Member: 500637 Status: Offline Thanks Meter: 424 | Quote:
03-06-2010, 22:27 | #15 (permalink) | |
Junior Member Join Date: Sep 2008 Location: Estados Unidos
Member: 869302 Status: Offline Thanks Meter: 1 | yes, bro, youre right, Quote:
it worked for me!!!:d | |
How To Unlock Nokia 6500 slide locked to 3g | longston | Nokia Base Band 5 ( BB-5 ) | 3 | 11-29-2008 16:53 |
how to unlock nokia Nokia 2310 | toto2 | Phone Unlocking Codes & Maps | 13 | 08-28-2007 20:02 |
How to unlock nokia 6070 using crux unlocker | shuak | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 04-18-2007 22:14 |
how to unlock nokia 1600b! Failed to locate PATCH target! | arielcom | MT-BOX | 5 | 03-26-2007 13:14 |
