Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2003 Location: halagsm Age: 36
Member: 20059 Status: Offline Sonork: 100.73934 Thanks: 72
| Cyclone BOMB ! Standalone : SX4 Emulation, SD Repair, RPL Calc, BB5 NCK Calc, ![]() - WORLD'S UNIQUE : Standalone Superdongle Key Calculator Added! No internet, no logs, no time! Calculation time - 0.003 sec ! Works for any SL1, SL2 and SL3. - WORLD'S UNIQUE : Standalone Unlocking/Relocking using RPL Added! No internet, no logs, no time! Calculation time - 0.002 sec ! Works for any SL1 and SL2. - WORLD'S UNIQUE : Standalone SX4 Authorization Added! Box is now emulating Nokia SX4 card - no need internet, no need logs to authorize ANY Nokia Phone, just box! Works for any SL1, SL2 or SL3. Emulated SX4 works with ORIGINAL NOKIA Superdongle keys (no need rebuild SD), Custom keys (made by Cyclone,MT,UB), etc. In case of Authorization fail, it will automaticly write and authorize using Custom Keys. Authoirzation time - 0.004 sec ! Supported are RAP and RAPIDO mcu, in case of RAPU phones SX4 Remote Card will be used. After authorization with Cyclone, PHONE STILL CAN be Authorized with ORIGINAL SX4 Card! - WORLD'S UNIQUE - Cyclone can now authorize Barred Phones (with Correct superdongle keys, but with higher KeyIndex ever used than 0 (possible KeyIndex 0..7), SX4 card can use any higher keyindex at time, when higher key is used, lower keys are automaticly not used in future, and phone requires to use higher key index) - UB and other custom boxes can't do it as long SX4 emulation is not 100% Nokia-Like - WORLD'S UNIQUE : Starting from now, Cyclone Box have ability to make _FULL RPL BACKUP_ of BB5 phones! Current existing SW on market creating only some part of RPL (NPC,HWC,Simlock) - Cyclone is now backing up missing part: - Added SUPER DONGLE KEY extracting (this Original Nokia one, so after writing it back phone still can be authorized with original SX4 card) - Added CMLA KEY DATA extracting - That means created RPL File by Cyclone is now 100% SAME AS NOKIA'S ONE! - WORLD'S UNIQUE : Added BB5 MCU & DSP Timestamps Reader / Diagnostic Tool. This will help diagnostic of downgraded phone, will read Security Block, decode timestamps of current installed SW (and factory one, or Dejan Hack if exists) with FLASH installed MCU/DSP timestamps. Will have ability to FULL REBUILD downgrade security zone (dead06) soon. - WORLD'S UNIQUE : BB5 Security Block Analyzer added, this will read Security Block and analyze it's health for content of following Security Data: SIMLOCK DATA, SUPERDONGLE KEY DATA, ECC KEYS DATA, DIV DATA, CMLA (DRM) DATA. Also it reads ST_SIMLOCK_TEST and ST_SECURITY_TEST and when problems occur, recommends actions. - WORLD'S UNIQUE : Standalone BB5 Calculator Added. This calculated BB5 NCK (levels 1-7) for unlocking purposes. Calculated codes works only with phones which have been relocked with Cyclone Box. To calculate code is needed only IMEI - no need cable, phone, flashbus logger, etc. - WORLD'S UNIQUE : BB5 Unlock by NCk/RPL, SD Recalc, SX4 auth using USB !! (once log file readen) - Upon box upgrade (maintenance) Bootloader in box is syncronized with server to avoid Activation Problems - Bootagent server upgraded to 1.01, fixed "Box is not activated, ID 09) - Fixed "Access Violation" when Cyclone Box SW is already launched and connection to box opened - After BB5 Relock, unlock codes is displayed - More detailed messages is now shown upon new NCK or RPL calculation - BB5 Security Code Reading is moved to "UserArea" tab (needed space for MCU/DSP timestamp reading and security block analyzing) - Total unlock/relock time added after operation is finished (thx to arash) - Box Firmware version is now checked upon loading of Nokia Module - if box firmware is obsolete, SW asks for upgrade and doing it automaticly - Selected unlock method is now displayed before RootkeyHash support check - Upon first reading of NCK Code (Extracting) or RPL Calculation, "CYC" log file is stored in "StoredFiles" and next time upon BB5 Security Actions (Calculation of SD, Extracting NCK, Calculating RPL (Relocking)) phone is no booted anymore and whole process took only 1 second!! Keep in mind calculated CYC file is paired with Box Serial number, so in case if your box serial number is changed-go to stored files and purge all "cyc" files. - Decrypted AES Subblock of Security Block is now checksum checked (16 bytes checksum at end of block) - Fixed "This is invalid integer..." when parsing phone with damaged IMEI - When another copy of Cyclone Software is running, message is displayed instead of errors - New method of NCK Calculation is now default BB5 unlocking method - When New Method of NCK calculation is selected, PA_SL is not determined already (saves lots of time) - Skin Manager updated to v6.54 (more stability) - When BB5 RPL Don't contain Certificates (NPC,HWC) phone isn't booted - Fixed bug when Flash RPL BB5 Data is being written two times - Added more verbose debug messages when preparing Boot BB5 Phone - Garbage characters when dealing with SLPA phones (#pw+___garbage___+1) bug fixed - New splash screen added, thx to arash, again - When Cyclone fails to boot APE subsystem, it shows hint about TX2 - APE subsystem is now no longer booted upon CheckFlashingBus - Changed "Failed to write CMT Cert Data (3)" message, added TX2 information - BB5 TX2 Line test added after "CheckFlashingBus" - Before RPL Write, Software testing TX2 Line and when its faulty (not adapter) it showing apporiate message - Writing BB5 CMT HWC Certificate from RPL fixed (thx to arash) - Parsing some Simlock Arrays (5130) produced garbage output - fixed (thx to arash again) - Added support for Cyclone Box HW Rev A11D Cyclone box (2010-01-16) Starting from now all calculated SL2 RPLs using Cyclone Server are FREE. One condition you need to met, you need to have 101 credits on your account. Stay tuned for some NCK-thing Cyclone Box (2009-10-26) * Added support for new ASIC 3168 phones/versions. Cyclone Box supports the following phones: o RH-86 2610 v07.04a o RH-87 2610b v07.04a o RM-258 2760 v06.82 o RM-258 2760 v07.60 o RM-259 2760b v06.82 o RM-259 2760b v07.60 o RM-298 2630 v07.60 o RM-298 2630 v57.20 o RM-299 2630b v07.60 o RM-299 2630b v57.20 o RM-340 2600c v06.82 o RM-340 2600c v07.60 o RM-341 2600c-b v06.82 o RM-341 2600c-b v07.60 o RM-391 2760h v05.45 o RM-392 2680s v06.17 o RM-392 2680s v56.17 o RM-393 2680s-b v06.17 o RM-393 2680s-b v56.17 o RM-394 1680c v06.82 o RM-394 1680c v07.60 o RM-395 1680c-b v06.82 o RM-395 1680c-b v07.60 o RM-438 7100s v05.22 o RM-438 7100s v05.41 o RM-438 7100s v06.31 o RM-438 7100s v06.32 o RM-439 7100s-b v05.22 o RM-439 7100s-b v05.41 o RM-439 7100s-b v06.31 o RM-439 7100s-b v06.32 o RM-512 2330c v06.46 o RM-512 2330c v06.75 o RM-512 2330c v08.20 o RM-513 2330c-b v06.46 o RM-513 2330c-b v06.75 o RM-513 2330c-b v08.20 o RM-514 2320c v06.75 o RM-514 2320c v08.20 o RM-515 2320c-b v06.75 o RM-515 2320c-b v08.20 o RM-519 2720f v08.20 o RM-520 2720f-b v08.20 o RM-543 2323c v06.75 o RM-543 2323c v08.20 o RM-544 2323c-b v06.75 o RM-544 2323c-b v08.20 Cyclone Box (2009-09-11) * Added unlock/relock/autolock support for DCT4+ Asic 3168 phones. Supported models/versions: o 7100s RM-438 v5.22 o 7100s RM-438 v5.41 o 7100s RM-438 v6.31 o 2330c RM-512 v6.46 o 2330c RM-512 v6.75 o 2323c RM-543 v8.20 o 2323c RM-543 v6.75 o 2323c RM-543 v6.46 o 2630 RM-298 v57.20 o 2720 RM-519 v8.20 * Unlock is free * First standalone solution (without Internet) * Added new service "Super DCT4" * To perform ASIC 3168 phones unlock activate box with "Super DCT4" (enables DCT4/plus IMEI change in the future) * The activation is done automatically in "Credits" tab and costs 50 credits (100 credits come with a box, if the user had not spent all logs on DCT4 RPLs, the activation is free) * Download the latest version * Download Super DCT4 FAQ Cyclone Box v1.06 (2009-08-10) * New Cyclone Box Firmware v1.06 o Fixed Nokia BB5 booting for 5800, N97, 5220 and others o Fixed problem of the box hanging during BB5 boot procedure o Inverted a meaning of "Repower on boot" button: now BB5 phones are repowered during the boot by default (more stable operating with dead / stuck / unbootable phones) o Fixed box stability during 1208 flash and CP extract, no more "Failed to set Flashbus baud" o General improved FBUS Stack stability o Code revised - Small speed improvement during BB5 TX2 Flashing o Added minor changes/bug fixes * Unlock/relock/autolock support for new DCT4Plus phones: RM-305 1650 v5.91 RH-105 1208 v5.91 RH-105 1209 v5.91 RM-298 2630 v7.60 RM-299 2630b v7.60 RM-258 2760 v7.60 RM-258 2760b v7.60 RH-64 1600 v6.46 RH-92 1100ib v6.46 RH-93 1100i v6.46 RM-291 v06.81 (missing partial) * Introduced new DCT4 loaders v7.49.00, this adds support for new flash chips. * Added new DCT4 UEM CBUS Loaders – Fixed ASIC11 UEM IMEI reading problems. * Introduced new BB5 loaders, adds support for new flash chips. Improved speed during flashing RAP3v3 phones with "slow" Samsung flash chip - 00ec2208 (includes 5200, 5310 etc.) * Old updates included: BB5 RAPIDO NCK Calculator and DCT4Plus Unlock patches released before (after installer): RM-392 2680 v6.17 RM-393 2680b v6.17 RM-392 2680 v5.28 RM-393 2680 v5.28 RM-362 5000d v6.31 RM-363 5000db v6.31 Download the latest Cyclone Box version Cyclone Box pre beta * Added unlock support for BB5 Rapido SL2 phones - 5800, N96, E75 etc. * Added INI selection for BB5 phones flashing * Redesigned GUI * Fixed other major bugs New DCT4Plus unlock/relock Added unlock/relock support for new DCT4Plus models: 2680 v06.31, 2680b v06.31, 5000d v06.17, 5000d-b v06.17. Nokia BB5 unlock * Added SP-Unlock support for Nokia BB5 models (unlock, SP Rebuild) for RAP3Gv2 PA_SL / RAP3Gv3 PA_SL / RAP3Gv3 PA_SL2 / RAPIDO PA_SL / RAPIDO PA_SL2 * Added SX4 bypass for PA_SL2 unlock (if necessary) Launched SX4 Online Service, which includes the latest BB5 Rapido SL2 models support for Cyclone Box users. It works on both: FBUS and USB. Support for DCT4+ New security (2009.03.26) Direct unlock (no downgrade, etc) supported for DCT4+ new security models: * RH-116 7070p v6.82 * RM-258 2760 v6.82 * RM-298 2630 v6.82 * RM-340 2600c v6.82 * RM-362 5000d v5.27 * RM-362 5000d v5.45 * RM-392 2680s v6.82 * RM-394 1680c v6.82 Download the latest Cyclone Box software Download Cyclone Box User Manual Cyclone Box Features * USB BUS power only, current in the idle mode: 55mA * World's first flexible configuration via software. TX2 pin can be used on any RJ48 output i/o pin. * Built-in 10 pin diagnostic service for phone's damage measurement via voltage, current, frequency, STI BUS (World's first) * High speed flasher, real BUS speed up to 10-11 Mbit, when 2 data lines are used * Compatible with UFS/JAF pinout * Switchable VPP: external or internal signal generation; high speed flash/erase * Advanced self-testing system * Support for FLASH BUS and USB connection with Nokia phones * Built-in secure smart-card * No conflicts occur with other devices, as Cyclone Box uses it's own drivers for Smart Card and FTDI * 100 ASK-RPL credits are included into Cyclone Box pack free of charge to enable RPL calculation for Nokia DCT4 and DCT4Plus. The user does not wait ASK-RPL online calculation. Cyclone Box Supported models and features DCT4 DCT4 Features * Flash software (upgrade/downgrade) * Reset SP SIM locks * Lock phone to any network * IMEI repair supported for the latest models * Flash Bluetooth * Save user settings * Full reset to factory (UI) defaults * Settings reset after software upgrade * User lock (security code) reset Supported DCT4 models 1100, 1100, 1101, 1108, 1110, 1110, 1110i, 1112, 1112, 1112i, 1600, 1600, 2112, 2125i, 2126i, 2128i, 2255, 2300, 2300, 2355, 2600, 2600, 2650, 2651, 2652, 2760 Americas, 2760 Europe/Asia, 3100, 3105, 3108, 3120, 3120, 3125, 3128, 3129, 3152, 3155, 3155i, 3200, 3205, 3205i, 3220, 3220, 3230, 3300, 3300, 3320, 3321, 3360, 3361, 3510, 3510i, 3520, 3530, 3560, 3570, 3585, 3586, 3586i, 3587, 3587i, 3588i, 3589i, 3590, 3595, 3595i, 3600, 3620, 3650, 3660, 5070, 5070, 5100, 5140, 5140, 5140i, 6010, 6012, 6015, 6015i, 6016i, 6019i, 6020, 6020, 6021, 6030, 6030, 6050, 6060, 6060, 6061, 6070, 6070, 6080, 6080, 610, 6100, 6101, 6101, 6101, 6102, 6102, 6102, 6102, 6103, 6103, 6108, 6111, 6112, 6152, 6155, 6155i, 616, 6170, 6170, 6200, 6220, 6225, 6225i, 6230, 6230, 6230i, 6235, 6235i, 6236i, 6255, 6255i, 6256, 6256i, 6260, 6260, 6310, 6310i, 6340, 6340i, 6360, 6370, 6385, 6500, 6510, 6560, 6585, 6590, 6590i, 6600, 6610, 6610i, 6620, 6650, 6651, 6670, 6670, 6800, 6800, 6810, 6820, 6820, 6820i, 6822, 6822, 7200, 7210, 7250, 7250, 7260, 7270, 7270, 7280, 7280, 7360, 7380, 7600, 7610, 7610, 7620, 7650, 7700, 7710, 810, 8310, 8390, 8587, 8800, 8800 Sirocco Edition, 8801, 8910, 8910i, N-Gage, N-Gage QD Supported DCT4+ models 1200, 1208, 1208b, 1650, 1650b, 1680c, 1680c-2b Classic, 2310, 2600c, 2610, 2610b, 2626, 2630, 2630 Americas, 2630 Europe/Asia, 2670h, 2680 v06.31, 2680b v06.31, 2680s, 2760, 5000d, 5000d v06.17, 5000d-b v06.17, 7070p All ASIC11 models are supported Nokia DCT-L DCT-L Features * Flash software (upgrade/downgrade) * Unlock * Set FAID * IMEI repair * Set UI defaults Supported DCT-L models 9290, 9210, 9210i (communicator) Nokia BB5 Nokia BB5 Features: * Flash software (upgrade/downgrade) * High speed USB flash * Easy RPL service for damaged phones * SIM lock and IMEI repair to the factory default * Save user settings * Set product code after flashing * Full reset to factory (UI) defaults * Settings reset after software upgrade * Reset/read user lock (security code) Supported Nokia BB5 models: 3109 Classic, 3110 Classic, 3120 Classic, 3250, 3500 Classic, 3600 Slide, 3610 Fold, 5200 XpressMusic, 5200, 5220 XpressMusic, 5300 XpressMusic, 5310 XpressMusic, 5320 XpressMusic, 5500, 5500 Sport, 5610 XpressMusic, 5700 XpressMusic, 5710 XpressMusic, 6085, 6086, 6110 Navigator, 6120 Classic, 6121 Classic, 6124 Vodafone, 6125, 6126, 6131, 6131 NFC, 6133, 6135, 6136, 6151, 6210 Navigator, 6212 Classic, 6220 Classic, 6233, 6234, 6267, 6270, 6280, 6282, 6288, 6290, 6300, 6300i, 6301, 6500 Classic, 6500 Slide, 6555, 6555 Classic, 6556 Classic, 6600 Fold, 6600 Slide, 6630, 6631 (NM850iG), 6650 T-Mobile, 6680, 6681, 6682, 7310 Supernova, 7370, 7373, 7390, 7500 Prism, 7510 Supernova, 7610 Supernova, 7900 Prism, 8600 Luna, 8800 Arte, E50, E51, E60, E61, E61i, E62, E65, E66, E70, E71, E90 Communicator, N70, N71, N72, N73, N75, N76, N77, N78, N79, N80, N81 8GB,N82, N85, N90, N91, N92, N93, N93i, N95, N95 8GB, N95 NAM, N95 8GB NAM, N96 Package contains * Cyclone Box - 1 pc. * Cable adaptor - 1 pc. * 100 ASK-RPL credits Order Now http://www.halagsm.co.uk/Cyclone-Box...BP&layout=list HalaGsm ICQ: 280918251 HalaGsm Ltd E-mail: sales@halagsm.co.uk MSN: halagsm@hotmail.com Skype: halagsm Phone: 00447850327122 Web: www.halagsm.co.uk Sonork: 100.73934 |
| The Following 10 Users Say Thank You to Halas For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| CycloneBox !! Standalone : SX4 Emulation, SD Repair, RPL Calc, BB5 NCK Calc, more!!! | SiRoYa | Main Sales Section | 0 | 03-04-2010 13:52 |
| Cyclone BOMB ! Standalone : SX4 Emulation, SD Repair, RPL Calc, BB5 NCK Calc, more!!! | karwos | Cyclonebox | 185 | 03-03-2010 22:07 |
| Cyclone Update Standalone: SX4 Emulation, SD Repair, RPL Calc, BB5 NCK Calc, more!!! | SiRoYa | GSM News & Updates | 0 | 02-12-2010 17:16 |
