Smart Clip + S-card A professional device that unlock, flash and repairs in seconds all Motorola phones avaliable in the market. .................................................. ............................................. 04.12.2007 Congratulations on the first S-Card anniversary! We are pleased to introduce a new version of S-Card v1.53 and SmartMoto v2.47. With this release we present the following options: Unlock and Repair EEPROM for all versions of F3, including the latest boots. Stabilized and improved connection process for W2xx Compal models. 28.11.2007 We are pleased to introduce a new version of SmartMoto v2.46. With this release we present the following options: The Unlock procedure for the Compal based models W205, W208, W209, W215, W218 is totally reorganized and simplified. So, now, it’s performed in just 3 steps: Connect Powered OFF handset. Press Unlock button in SmartMoto. Press Power ON button on the phone. The rest of the procedure will be performed by SmartMoto automatically. Also, released Format FFS (reset user code) and Repair EEPROM options for the specified above models. Added Persian language to the SmartMoto interface. Please remember that all Compal models require to be connected to PC using COM cable or USB cable with virtual COM port emulator. 21.11.2007 We are pleased to introduce a new version of SmartMoto v2.45. With this update we present Unlock solution for the following Compal based models W205 W208 W209 W215 W218 Please remember that all Compal models require to be connected to PC using COM cable or USB cable with virtual COM port emulator. 13.11.2007 We are pleased to introduce new versions of SmartMoto v2.44 and S-Card v1.52. With this update we present the following options. Developed unlock solution for the model W490 (Prepare Smart TestPoint). Released support for SE J110i and J120i with the new type of flesh chip. 09.11.2007 We are pleased to introduce new versions of S-Card v1.51 and SmartMoto v2.43. With this update we present the following options. First in the world released unlock option for Foma M702iS (Prepare Smart TestPoint). Added unlock support for RAZR2 V9 (Prepare Smart TestPoint). Corrected direct unlock process for SE J110 and J120 and disabled read codes option. Released Read User Code option for Chi Mei based phones. Enabled option Reset User Code to default value for Chi Mei based models including SE J110 and J120. 26.10.2007 We are pleased to introduce a new version of SmartMoto v2.42. With this update we add the models with boot versions A.B3 and A.B4 to the range of supported by Prepare function (First in the world). 25.10.2007 We are pleased to introduce new versions of S-Card v1.50 and SmartMoto v2.41. With this update we present some new Special solutions: Released Read codes/Unlock solution for SE J110i and J120i phone models (SmartMoto, Chi Mei tab); World's exclusive, Enabled IMEI repair option for SE J110i and J120i phone models (SmartMoto, Chi Mei tab). Please remember that models SE J110i and J120i require being connected using COM cable or any virtual COM port emulator. 24.10.2007 We are pleased to introduce new version of SmartMoto v2.40. With this update we present a new, World's Exclusive solution: New boot versions of Argon based models are added to Smart Boot Detect system. So, from now on, the boots lower than 3.02 are supported. Model V3xx with boot version 2.Е3 is tested and approved to be supported by Prepare Smart TestPoint function. 18.10.2007 We are pleased to introduce new version of SmartMoto v2.39. With this update we are proud to present. First in the world, released REPAIR PDS option for LTE2 ROM4 based handsets: L72 L9 V3re (V3_06) W510 In order to use REPAIR PDS option for listed above models Prepare Smart TestPoint is required. Smart TestPoint cable schematic can be found in downloadable files section. Please use only original accessories with Smart-Clip. We can not guaranty stable functions of Smart-Clip with the cables from other manufacturers. GSMserver team doesn’t bear any responsibility for the faults caused by cables from other manufacturer or for the faults caused by wrong usage of the original accessories. 03.10.2007 We are pleased to introduce new versions of S-Card v1.49 and SmartMoto v2.38. With this update we present the following: Added support of the new flash chip types on Argon series and for the model V3re. New boot versions are tested and approved to be supported by automatic Smart Boot Detect system of SmartMoto. Smart TestPoint cable schematic can be found in downloadable files section. We recommend to use with Smart-Clip original accessories only. GSMserver team doesn’t bear any responsibility for the faults caused by cables from other manufacturers. 01.10.2007 We are pleased to introduce new versions of Smart-Clip v3.25, S-Card v1.48 and SmartMoto v2.37. With this update we present the following: First in the world, released Smart TestPoint unlock feature for V3re (V3_06). Enabled flash, save/restore backup and lang_pack opiton for V3re (V3_06). Added support of new types of flash chips and new versions of PDS zone. 27.09.2007 We are pleased to introduce new version of SmartMoto v2.36 With this update we have corrected some steps of boot loading process for LTE2 ROM4 based models, connected in flash mode for Smart TestPoint prepare. 26.09.2007 We are pleased to introduce new versions of Smart-Clip v3.24, S-Card v1.47 and SmartMoto v2.35. With this update we present some changes applied the boot loading process of Argon based models. Developed Smart Detect of boot version for Argon based models. From now on all future boot versions are supposed to be supported. At this stage few models were tested and found to be fully compatible with Smart Detect. Listed below models with particular boot versions are approved to be supported for unlock using Smart TestPoint cable: V3xx and V6 with boot version 03.09 (World’s exclusive) K3 with boots 03.90 and 04.10 V3xx untypical* with boot version 03.08. *V3xx untypical includes some models with specific boot versions mostly provided by North American network providers (Cingular, AT&T etc). If the model V3xx can not be processed by Prepare cycle as a usual model, please select V3xx untypical and perform the process again. 22.09.2007 We are introducing a new version of SmartMoto v2.34. With this release we have improved detection and boot loading process for the models with boot version 06.12. 20.09.2007 We are pleased to introduce new versions of Smart-Clip v3.23, S-Card v1.46 and SmartMoto v2.33. With this update we present the following options: First in the world released unlock solution for the model Foma M702iG. World’s first enabled save/restore backup option for Foma M702iG Added Repair PDS for the model L2. Improved and stabilized unlock process and save/restore backup option for Argon platform models. Foma M702iG requires to be connected using Smart TestPoint cable. 17.09.2007 We are pleased to introduce new versions of Smart-Clip v3.22, S-Card v1.45 and SmartMoto v2.32. With this update we enlarge the range of supported models by adding ARGON platform unlock and flash options. So, we are proud to present: World’s first, unlock of V1100. Released unlock for other Argon based models: K3 V3xx V3xx Cingular (North America) V6maxx Enabled save/restore backup option for the specified above models. Note All Argon models require Smart TestPoint cable to be used while performing unlock process. 07.09.2007 We are pleased to introduce new versions of S-Card 1.44 and SmartMoto v2.31. With this update we release the following options: Added model selection by series for Prepare cycle. L9 Prepare Smart TestPoint* procedure is perfected. 05.09.2007 Released new version of SmartMoto v2.30. With this release Prepare function for the models V360 and L7 with boot 09.02 is reorganized and corrected. Also, Prepare Smart TestPoint procedure is improved. We apologize for any inconvenience caused by the previous release. 05.09.2007 Released a new version of Smart-Clip v3.21 and S-Card v1.43. With this release Unlock button issue is fixed. We apologize for any inconvenience. 04.09.2007 We are pleased to introduce new versions of Smart-Clip v3.20, S-Card v1.42 and SmartMoto v2.29. With this update we release the following options: World's first. Released unlock of LTE2 ROM4 models W510, L72 and L9, using Smart TestPoint* cable. No TestPoint Unlock for boot version 09.02, models V360 and L7 (Prepare Cycle). Smart TestPoint cable is a universal device and will be used for future updates, such as unlock of Argon based models. The solution for those models is currently under development. 10.08.2007 We are pleased to introduce new versions of SmartMoto v.2.28 and S-Card v.1.41. From now on S-Cards that were registered with Asian Smart-Clips are compatible with SCout flasher! With this update we also implement the following options for i-mode handsets: Reset Permanent Block feature added Format User Area feature added 07.08.2007 We are pleased to introduce new versions of S-Card update client v1.04 and SCout updater v1.04. Connection between S-Card/SCout dongle and these new versions of update clients is improved and stabilized. 02.08.2007 Smart-Clip team presents you a second stage of SCout integration. If yesterday, the majority of Smart-Clip users thought that we forgot about them, then today we would like to prove the opposite. So, today, we are introducing SCard v1.40 and SmartMoto v2.27*. Most of you will ask: What are the advantages of that? Then let us give to all of you a wide explanation. SCout is a powerful multiflasher with access to flash files, fully functional support and upcoming updates. Advantage. Those, who need to perform flashing of big numbers of handsets and don’t require full Smar-Clip functions, can get a powerful multiflasher with free year of access to the biggest ever flash files collection SCard becomes compatible with SCout software. Advantage. All S-Card users get an opportunity to flash I-mode and Compal (Calypso+) models using SCout software. All Smart-Clip users get access t o that section right after update of their S-Cards to the latest version (v1.40). PC-Flash option is fully moved from SmartMoto to the SCout software*. Advantage. SmartMoto installation package is lowered in size. So, we have released the request of many users who were desperate to save the downloading traffic. SCout proves its name: SC out, functions without Smart-Clip, flashing directly via PC USB port. With this release we prove another time that our *******rs are important for us and we consider their interests. * Note to Chinese users. Please be aware that Chinese version of SmartMoto currently stays the same (2.26) and still contains PC-Flash option. SCout compatibility for all Chinese S-Card users will be launched within few days. We apologize for any inconvenience caused by that delay. 02.08.2007 We are glad to inform you that V8 is tested and proved to be supported by PC flash features. 31.07.2007 We are pleased to introduce new versions of S-Card v1.27 and SmartMoto v2.26. With this update we release the following options: Corrected OTP status detection on V3x (AMD flash chip) and older models of C series (C450, C550 etc). Improved and stabilized flashing process for some versions of *.pcf files. 30.07.2007 We are glad to inform you, that the following models: K3, L9, L72, Z6, W510 are tested and proved to be supported for PC flash features. Warning Some of the flashes might contain SP lock. So it is strictly required to reset Subsidy Code before flashing. 25.07.2007 We are pleased to introduce new versions of Smart-Clip v3.19, S-Card v1.26 and SmartMoto v2.25. With this update we release the following options: World’s first, No TestPoint Unlock (Prepare cycle) for the models K1, L7e, L71 and Z3 with the following boot versions: 0A.B2, 0A.C0, 0A.C3. Boot version 0A.42 (models V3i, V3t, V3r & V3v) is added to support of Prepare function. IMEI repair patch for K1, Z3, L7e, L71*. View OTP status (locked/unlocked) option added. Improved Prepare Cycle procedure. If the Prepare is performed from the powered handset, all information about the phone is saved by SmartMoto, so it the information like: fw version, flex, operation band, etc, will be recorded in backup. Added Repair PDS for the model V3i, firmware version R4441D_G. Improved flashing of the model A1200, E2, E6 from boot mode with *.pcf file. * - please be aware that after performing repair IMEI for the models K1, Z3, L7e and L71 any future flashing will be possible by performing TestPoint connection only. Note Update Smart-Clip first and perform S-Card update after that only. We recommend to use only the latest versions of Smart-Clip, S-Card and SmartMoto. 12.07.2007 We are proud to announce the premiere of COMPLETELY NEW, WORLD’S FIRST, DIRECT, STANDALONE unlock solution for Motofone F3, developed by – F3 Unlock Clip. F3 Unlock Clip – is the easiest unlock solution, available on the market yet. It is operated by one button and requires to be powered from mains adapter or even 9V battery. F3 unlock procedure description Connect power to F3 Unlock Clip (9V battery can be used). Connect F3UC to the handset, powered on or switched into boot mode*. Press Unlock button on the clip. LED on the clip starts to blink frequently. Unlock process is in progress. On successful unlock, LED stops blinking and lights up for about 10 seconds. *To switch F3 into boot mode, please power off the phone and press 3 keys combination: *#Power On. The handset display will remain blank. NOTE If the LED on F3 Unlock Clip, after frequent blinking starts to blink slower instead of lighting up – the unlock process failed. Please disconnect the phone from the cable, remove and insert the battery, switch the phone to boot mode and perform unlock again. 23.06.2007 We are pleased to introduce new versions of Smart-Clip v3.18, S-Card v1.25 and SmartMoto v2.24. With this version we release the following options. Unlock via TestPoint for E2, E6 and A1200 phone models. Unlock via Remove RSA option for V560 (boot ver. 8.26) model. Repair PDS option for A1200, E6 and V560 models. ================================================== ============= Description: A professional device that removes SP/ SIM / phone/ user lock from Motorola phones. This simple standalone one-button operation Clip unlocks phones in just a couple of seconds. |No PC, disassembling or special technical knowledge needed. We are pleased to announce... First in the world... Unlock of Motorola v1050 as well as long awaited Motorola v975 (ver R245_xxx) and Motorola E378i Tested and proved as supported: C117 (Acer) and V170 (Acer) New version of SmartMoto (1.02 RC2): Backup and restore flash for A830, C975, C980, V980, V975, E1000, A1000, V1050, V150 (R313LT_xxx) Support new boot V3 (8.2.3, 8.2.4) and boot Axxx (6.1.2) improved procedure for flashing certain types of flash for C350L Clear life timer Master clear Master reset Change bands Unlock initialization for certain phone models (V1050 and V975) Improve Win XP compatibility option Please be advised that new SmartMoto requires registration When you run the software for the first time it will ask for registration. You be will be offered a link, follow it and you will receive the key needed to activate the program. Copy the key and paste it into a registration window in SmartMoto software. No more registration is needed. The following option is recommended on Windows 2000/XP to improve communication stability: Disable OS parallel port polling (requires reboot) Unlock procedure for V1050 and V975 (ver R245_xxx): You need to use SmartMoto to unlock these models Power on the phone. Connect it to PC via smart-clip, detect your phone in SmartMoto. Go to Unlock bookmark, pick your model, press "Start unlock procedure" button. Phone goes into boot mode, reserve copy of security area is created. Part of phone Firmware is reflashed. Phone doesn't power on after that. SmartMoto will give you the message requiring to take phone into boot mode using keys combination: *,#, PWR ON (at this moment the phone has to be connected by usb cable) or using repair cable. Press "OK" button. Wait till the process ends. The phone powers on and is ready to be unlocked by Smart-Clip using simple "press one button" method (press Unlock button on Smart-Clip). Unlock procedure for E378i: Power on the phone, connect it to Smart-Clip, press Unlock button. Phone goes into boot mode. E/G starts blinking. Power the phone ON manually within 2-3 seconds after display turns off. Wait for unlock procedure to complete. Alternatively you can try to unlock this phone with battery charger on. Flashing Support only for Motorola P2K series with SmartMoto Which you can use the PST Flash File Supported Phones: Motorola P2K Series (Unlocking & Flashing) Motorola A-series: A630, A830, A835, A845, A920, A925, A100 Motorola C-series: C236, C250, C260, C266, C268, C330, C331, C332, C333, C334, C335, C336, C350, C350L (incl. R312ULS_G_09.10.2CR), C350V, C353, C355V, C359V, C370, C380, C385, C450, C450L, C550, C650, C651, C975, C980 Motorola E-series: E370, E375, E378i, E380, E396, E398, E550, E920, E1000 Motorola T-series: T280, T280i, T720 (incl. T720_G_05_08_81R), T720i, T721, T722i, T725e Motorola V-series: V3 (incl. R374_G_0E.40.74R, R374_G_0E.40.96R), V60, V60i, V66, V66i, V70, V80 (incl. R37_G_0E.03.26R), V150 (incl. R313LT_G_09.20.05R), V151, V180 (incl. R364_G_0B.D1.1CR), V186, V188, V220 (incl. R365_G_0B.D2.0.FR, R364_G_0B.D1.1FR), V226, V300, V303, V330 (R472_xx), V400, V500, V505, V525, V525M, V535, V547 (incl. R472_xx), V545, V550, V551 (incl. R472_xx), V600, V620, V635 (ver R474_G_08.48.6CR), v975 (ver R245_xxx), V980, v1050 ACER platform: (Unlock) C115 (incl. v.1.0.50), C116, C117, C155, C156, c157, E365 , V170, V171 Sendo: (Unlock) Sendo snd2xx, snd3xx (incl. snd360 s360), snd5xx (incl. snd570 m570), Sendo snd6xx (incl. snd600 p600/s600), Sendo snd8xx Features: Standalone Unlocking operation, no computer needed Flashing for P2K Series With SmartMoto Computer is needed Read/Write/Backup Flash file with SmartMoto Large list of Smart-Clip supported phone models (all versions), constantly growing Free Motorola firmware upgrades (A, C, E, T, V series) through internet Unlocks in just few seconds SmartMoto Backup Full Flash The function is implemented for fully safe SmartMoto tool operation with Your Motorola phones. With the backup files you upload our team continuously replenishes flash files database Restore full flash You can always restore your phone to initial state using this function and previously made backup file. Note: backup files are created only for the clip that they were made with. You can't use "restore" feature with the backup file made by any other clip Auto backup/restore security area For those models where security area does not restore it will be autosaved while entering boot mode. If needed this zone can be restored with restore security area function. Read phone info You can get full information on your phone, namely: Model IMEI User code Security code Operation band Firmware Flex version Language pack Flashing Simple phone flashing Repair flashing Full phone flashing (including EEPROM zones) by a working flash file. Repair flash files are prepared by Smart-Clip developers team and put out for Smart-Clip users on our server. In phones with unrestorable security area it will not be changed during flashing PC flash Emulation of PST flasher. It works via computer USB port and does not require phone connection via Smart-Clip. Flashing requires standard PST files with *.shx extension. S-Card dongle is a portable USB key for: Smart-Clip updates. SmartMoto software operations. Access to flash files database. Use of S-Card dongle frees Smart-Clip users from SmartMoto licensing process. From now on, Smart-Clip with S-Card dongle can be used on any PC and will not be bound to the computer hardware. NOTE:No future version of Smart-Clip or SmartMoto will be usable without S-Card dongle connected. Smart-Clip registered with the USB key will provide an access to the new level of flash files database at portal boot loader. New flash file formats will be supported by SmartMoto, also direct flashing with original flash files will be allowed (TestPoint connection method is not necessary for flashing anymore). Package Contains : 1 x Smart-Clip device 1 x S-Card dongle 6 x cables: Motorola C series, Motorola V series, Motorola C115, Motorola E365, Sendo S200, Sendo M550 Battery connector Free 1 year access to download site to keep updated with software and flash files New Update Released full support: Backup/Restore phone flash (Word’s exclusive); Flash; Read/Restore ESN and MEID; Read hardware ESN, MEID and IMEI (word’s first); Reset codes, Backup/Restore PRL, A-key, SSD and more for the following CDMA models: A840, A860. These models are hybrid platform (CDMA-GSM). Released Restore IMEI option for them. (First in the world) C290 (supported first in the world), C343, C364 E815 K1m L7c T720c V260, V262, V265, V266, V276, V323, V323i, V325, V325i, V325xi, V3a, V3c, V3m, V710, V810, V9m, VU204 (supported first in the world) W315, W385, W755 Z6c, Z6m, Z6tv Unlock and Repair EEPROM solution for the model EM325 (Compal-Locosto unlock). W233 and W397v are added to SmartMoto list (Compal-Locosto unlock). PRICE: 250 To Order: http://www.halagsm.com/site.php?p=det&prod=16 BR, HalaGsm |
I tried to unlocking W233 (G8/19) S/W:0.0.64K2 not success the log show like below for long time http://img256.imageshack.us/img256/4294/eepromlog.png I tried to Flash with W230 (file like below) http://img299.imageshack.us/img299/5...ashfilesfo.png After finished Phone show FORMATING..on screen a few minute turn off, next i take battery out and put back press power on the phone show only logo MOTO after turn off I have tried many many time even i wrote firmware W233 from boot-loader support the phone show only logo and turn off I tried to repair EEPROM /FF FORMATE but smart moto show the same like below http://img256.imageshack.us/img256/4294/eepromlog.png |
