01-10-2009, 02:12 | #1 (permalink) |
Product Supporter Join Date: Jan 2005 Location: HalaGsm Age: 47
Member: 107133 Status: Offline Sonork: 100.73934 Thanks Meter: 76 | Universal Box Is a very secure standalone modular tool for mobile phones. Modular because you can extend its functionally with algorithms to work on more models. The device uses parallel or USB port to communicate with the computer. Description: Universal Box is a very secure standalone modular tool for mobile phones. Modular because you can extend its functionaitly with algorithms to work on more models. The device uses paralell or USB port to communicate with the computer. The box comes with the main software which keeps the box's software modules (algorithms) up to date. This software package is an algorithm for the Universal Box in order to be able to flash, unlock and repair Nokia models. Our Nokia algorithm currently supports Nokia GSM, EGSM, TDMA, CDMA, WCDMA phones. Also supports Sony Ericsson Phones. Features: - Nokia BB5 flasher through FBUS. - Able to flash Nokia models which was produced with 128K flash chip. (6020, 3320, 6060, 7260, etc...) The result was correct ringtones, pictures, ect... - One solution which patches the flashes on the fly for IMEI changing on (ASIC 2) models. This box doesn't require standalone patch files for every single version of phone. Unlike other boxes on the market you don't have to change phone software version which is required by the patch. - Universal Box can handle each DCT-4 software version one by one where you have to select model, version and product code. Like this you can easier load the appropriate falsh file. Also supports the older "Phoenix" style directory structures. - Supports IMEI changing on SonyEricsson UMTS models. As like for Nokia, you don't have to download patch files for changing IMEI on these models because our main software patches them on the fly. - Has implemented SonyEricsson UMTS file explorer for all UMTS models. Works similar like the well known Total Commander tool. With this file explorer you can up/download ringtones, pictures, sms and everything that belongs to a file category. - The main software has built in file manager where you can update your box or download the latest flash files. Every box has an unique identifier, so you don't have to use username and password combination, just a single click and your box will be updated. Also you can set automatic updates and when you start the Universal Box software again it preforms to check for updates. - Empty DCT-3 and DCT-4 uploading - IMEI changing without UEM is not supported yet on the following models: 1100, 2600, 2300, 9500 Currently supported models/types: Nokia BB5: 6630 RM-1, 6680 RM-36, 6681 RM-57, 6682 RM-58, N70 RM-84, N70 RM-99, N90 RM-42, 6270 RM-56, 7370 RM-70. Nokia DCT-4: 1100 RH-18, 1100 RH-36, 1100 RH-38, 1101 RH-75, 1110 RH-70, 1220 NKC-1, 1260 NKW-1, 1600 RH-64, 2112 RH-57, 2220 RH40-42, 2260 RH-39-41, 2270-2272 RH-3P, 2280 RH-17, 2285 RH-3, 2300 RM-4, 2300 RM-5, 2600 RH-59, 2600 RH-60, 2650 RH-53, 2651 RH-54, 30 TME-3, 31 TME-4, 3105 RH-3, 3100-3120 RH-19, 3100-3120 RH-50, 3108 RH-6, 3125 RH-61, 3200 RH-30, 3200 RH-31, 3205 RM-11, 3220 RH-37, 3220 RH-49, 3230 RM-51, 3300 NEM-1, 3300 NEM-2, 3320 NPC-1, 3360 NPW-1, 3360 NPW-PA, 3510 NHM-8, 3510i-3530 RH-9, 3520 RH-21, 3560 RH-14, 3585 NPD-1AW, 3585i NPD-4AW, 3586i RH-44, 3590 NPM-8, 3595-6010 NPM-10, 3600-3620 NHM-10, 3650 NHL-8, 3660 NHL-8, 5100 NMP-6, 5100 NMP-6x, 5140 NPL-4, 5140 NPL-5, 5140i RM-104, 6012 RM-20, 6015 RH-15, 6020 RM-30, 6020 RM-31, 6021 RM-94, 6030 RM-74, 6060 RH-73, 610 TFE-4, 6100 NPL-2, 6101 RM-76, 6101 RM-77, 6108 RH-8, 6111 RM-82, 616-RV-1, 6170 RM-47, 6170 RM-48, 6200 NPL-3, 6220 RH-20, 6225 RH-27, 6230 RH-12, 6230 RH-28, 6230i RM-72, 6235 RM-60, 6255 RM-66, 6260 RM-25, 6310 NME-4, 6310i NPL-1, 6340 NPM-2NX, 6340i RH-13, 6360 NPW-2, 6385 NHP-2AX, 6510 NPM-9, 6560 RH-25, 6586 RH-27, 6590 NSM-9, 6600 NHL-10, 6610 NHL-4U, 6610i RM-37, 6620 NHL-12, 6650 NHM-1, 6651 NMM-1, 6670 RH-67, 6800 NHL-6, 6800 NSB-9, 6810 RM-2, 6820 NHL-9, 6820 RH-26, 6822 RM-68, 6822 RM-69, 7200 RH-23, 7210 NHL-4, 7250 NHL-4J, 7250i NHL-4JX, 7260 RM-17, 7270 RM-8, 7280 RM-14, 7360 RM-127, 7380 RM-111, 7600 NMM-3, 7610 RH-51, 7610 RH-51, 7650 NHL-2NA, 7710 RM-12, 810 TFE-4R, 8310 NHM-7, 8390 NSB-8, 8800 RM-13, 8910 NHM-4, 8910i NHM-4NX, 9300 RAE-6, 9500 RA-2, D211-DTE-1, NGAGE NEM-4, NGAGEQD RH-29, NGAGEQD RH-47, PT6 PT-6. Nokia DCT-3: 2100, 3200, 3310, 3315, 3330, 3350, 3390, 3395, 3410, 3610, 5110, 5120, 5210, 5510, 6080, 6090, 6110, 6130, 6150, 6210, 6250, 7110, 8210, 8250, 8290, 8810, 8850, 8855, 8890, 9210. SonyEricsson Smart card type: A3618, J200, J210, P800, P802, P900, P910, R520, R600, T39, T65, T68, T100, T106, T200, T202, T226, T230, T237, T238, T290, T300, T302, T306, T310, T312, T316, T66, T600, T610, T616, T618, T628, T630, T637, Z200, Z600. UMTS type: D750, F500, J300, K300, K500, K506, K508, K600, K608, K700, K750, S700, V600, V800, V802,W500, W600, W800, W900, Z1010, Z500, Z520, Z800. Requirments: This product doesn't need internet connection for the everyday work, but it is recommended that you use on a computer which has internet connection to update your box with the latest software and algorithms if available. Universal Box requires Windows XP/2000/98/ME operating system. ================================================== ==================== Latest Updates: 27/04/2006 Added support for Nokia BB5 6280 with AMD flash chip. (To repair an already flashed 6280 you only need to flash the UCP again. This will fix empty gallery problem) . 25/04/2006 Added Ericsson Z530, W810 flashing support with SmartCard. Unlock also available, but you have to flash the phone after unlock (after unlock you have to flash the software only by selecting Use SmartCard checkbox, this won't reduce credit) (in the future flashing will be available without SmartCard) 20/04/2006 Fixed Ericsson UMTS flash, and unlock bugs due to CID49 support Added server selection ability 19/04/2006 Fixed Ericsson UMTS filesystem initialization bug Added Ericsson UMTS CID49 flash support without SmartCard Package Contains : 1 x Universal box 6 x cables: 1 x Sony Ericsson T28 service cable 1 x Sony Ericsson K750 service cable 1 x testpoint cable 1 x 10P10C to 8P8C cable 1 x JR45 EXTENSION cable 1 X EASY cable 1 x Power adapter 1 x adapter Price: 319 usd To Order : http://www.halagsm.com/site.php?p=det&prod=84 BR, HalaGsm Last edited by Halas; 01-10-2009 at 02:23. |
The Following User Says Thank You to HalaGsm For This Useful Post: |
01-14-2009, 00:18 | #2 (permalink) |
Product Manager Join Date: Jan 2003 Location: halagsm Age: 47
Member: 20059 Status: Offline Sonork: 100.73934 Thanks Meter: 2,756 | 13/1/2009 Added easy flash erase function You can erase your phone without erasing PM area (for example simlock) Added manual NCK entering Added possibility to unlock supported phones with original lock zone (same as when entering valid nck) Fixed BB5 NoTP unlock bug BB5 simlock repair and certificate restore is now enabled again. This feature is supported only if your phone have valid IMEI no. If your phone is erased fully, or have no valid NPC data (erased flash), then you can't use this service. This service will also not work if your phone have blacklisted IMEI. -but our software will inform you about this if needed- So what u can do if you have a dead phone? Backup the certificates Erase your phone fully Flash it with latest software version Restore the certificates Send ASK Get RPL Write RPL - DCT4 PM write bug (auth failed) - BB5 certificate backup bug when simlock checkbox was not checked - BB5 flashing bug in some modells - Added erase file for 64M flash types (will be usefull for most of new phones like 6301, and many nor flash types) Some bugs are also fixed... Halas |
WHAT is universal box -cost (price) in india i want buy new universal box | Rajan chhetri | Universalbox | 3 | 10-24-2008 08:42 |
