09-12-2013, 10:55 | #31 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: USA
Member: 362515 Status: Offline Sonork: 100.1590585 Thanks Meter: 160 | Quote:
bro; contact me on sonork or pm me | |
09-17-2013, 09:06 | #32 (permalink) |
Junior Member Join Date: Sep 2007
Member: 582782 Status: Offline Thanks Meter: 0 | i9300 flash ok but no on Good morning: I could get one of the i9300 recover, particularly with z3x and with full flash I9300XXEMB5_MGFEMC1_QVZEMC1_SVZEMC1: mx.pit BOOTLOADER_I9300XXEMB5_996085_REV00_user_low_ship. tar.md5 CODE_I9300XXEMB5_996085_REV00_user_low_ship.tar.md 5 MODEM_I9300XXEMB5_REV02_REV04_CL1214143.tar.md5 CSC_MGF_I9300MGFEMC1_CL1026299_REV00_user_low_ship .tar.md5 What flashee by checking the BOOT UPDATE I ABOUSHADY indications indications (http://forum.gsmhosting.com/vbb/9731924-post5.html), although, with the first step (the first flash) and I recovered the phone. After flashing IMEI is 0049 I'll ..., I retrieve the IMEI and S / N with the same z3-x I will try other than I have here to see if I have luck. Greetings: |
09-30-2013, 20:36 | #33 (permalink) |
Freak Poster Join Date: Sep 2011 Location: venezuela Age: 37
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | hi... i think i have any luck.... so im wondering... (just to be sure that my s-boot clip cable is really working)... what will happend if i use this sboot clip... with a non-bricked i9300???? can it get brick? or just rewrite boot and stays normal...???? i really want to know... thanks... |
10-01-2013, 09:42 | #34 (permalink) | |
Freak Poster Join Date: May 2008 Location: kampala, uganda. East Africa
Member: 770206 Status: Offline Sonork: Eed07 Thanks Meter: 23 | Quote:
you'll brick it, dont! | |
10-01-2013, 10:29 | #35 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Germany
Member: 396421 Status: Offline Thanks Meter: 87 | i tested it. nothing bad will happen. you will have imei null/null, then just flash the phone and everything will be good again. but anyway it is recommened not to do this. |
10-04-2013, 21:17 | #38 (permalink) |
Junior Member Join Date: Oct 2013 Location: Paraparaumu Beach, New Zealand
Member: 2040083 Status: Offline Thanks Meter: 0 | Blank SD Card I've tried the unit on two S3 i9300 and always get the phone into download mode, but nothing else happens even after say 7 minutes. This has always occurred since I got the unit - via Ebay I plugged the unit into a S3 SD slot that was powered on. Comes up "preparing SD Card" so it would be reasonable to assume the SD cable is ok. Then it tells me the "SD card is blank". I removed the SD card 2GB from the Unit and connected this up to a Win 7 pc, also shows card is blank. Discussed with Ebay supplier they requested I post my problem here. So can you provide a download image for this Unit that I can write to the existing SD card or to a new SD card. Some questions here. Any instructions on doing this ? Does the SD card have to be 2GB, I do have some 8Gb and 16GB SD cards available? Can the image be used on Win 7 or is it only Linux based ? |
10-05-2013, 09:35 | #39 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Russia N.Novgorod Age: 46
Member: 319131 Status: Offline Thanks Meter: 25 | I bought this cable, in fact it SG SD Boot Card with Download Mode JIG I9000 Down Mode Clip - 1 pc. SD Boot Repair Card - 1 pc. Why only micro sd had to hang on the trail and 300k resistor to the wire? |
10-05-2013, 09:56 | #41 (permalink) |
Member: 319131 Status: Offline Thanks Meter: 25 | GPG S-Boot Cable fused with Paragon Partition Manager 11 Professional |
