05-12-2011, 09:48 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: canuaght place palika bazaar
Member: 647773 Status: Offline Sonork: 100.1611571 Thanks Meter: 65 | 100% done 3120bto3100 convert without sound problem FIRST ERASE YOUR PHONE IF MANY TRY TO FLASH OR PM THEN FLASH UR PHONE LATEST VERSION RH-19 6.31 WRITE THIS PM FILE ON UR PHONE https://rapidshare.com/files/534462983/Ehab.rar THEN GOTO SIMLOCK TAB AND UPDATE SIM LOCKS YOUR INFO IS Model: Nokia 3100 (Expression Phone) CS type: GSM900/GSM1800/GSM1900 Project Name: Maxine Battery voltage: 4726 mV Battery current: 32768 mA BSI: 3.1 KOhm Imei net: 35378300230186 Version: SIMLOCKLIB VERSION 2.28- More TDS-6 boxes supported Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN THEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 1.016 s {UFS2 SarasSoft disconnected.}AND CONECT TO UFS SARASOFT ORIGINAL SOFTWARE AND CHECK INFO AND WRITE PP BUTOON ON RIGHT SIDE AND SELECT THIS PP FILE https://rapidshare.com/files/7834684...r_earpiece.rar AND CHANGE 900 MHZ FILTER IF NO CHANGED http://www.image-share.com/igif-651-170.html SET WILL BE 100% WORKING WITH SOUND BUT LOSS ONLY TONES AND IMAGES IN GALERRY DONT FORGET THANKS |
The Following User Says Thank You to GNS_KUMAR73 For This Useful Post: |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
