Old 03-07-2010, 17:25   #1 (permalink)
Y.P.Y's Avatar
Member: 1010502
Sonork: whats this?!
Thanks Meter: 316
Post !!! [+] 100% solution - n96 restart on nokia logo - solution [+] !!!
!!! [+] 100% SOLUTION - N96 RESTART ON NOKIA LOGO WITH MXKEY [+] !!!
First method is that phones part of the Security and Certificate is completely Healthy.(Simlock-SD-HWC_CCC-Sec Test is OK)
First method:
1 - Make full Backup from Phone Service-> Imei & Security-> IMEI Rebuild-> BackupRPL All Section
2 - Erase phone with Universal_BB5Erase_RAPIDO_MCU.bin and Enable Skip APE (put the file in MCU)
3 - Flash phone with N95-8GB.RM-320 Version 30.0.018 only MCU and PPM files with Enable Skip APE
4 - Flash phone with N96 Eno File rm247_ENO_x_2010wk99v99.099_by_Y.P.Y
5 - Flash phone with Version 30.033 N96 RM-247
6 - Write Full Backup Service-> Imei & Security-> IMEI Rebuild-> Write RPL
Second method:
1 -
2 - Downgrade phone Without Enable Downgrade Option
3 - Repair Simlock Service-> Imei & Security-> Simlock-> PA_SL2 -> Make Simlock RPL-> Repair Simlock
4 - Repair SuperDongle Service-> Imei & Security-> IMEI Rebuild-> Repair SD
5- Sx4 through SuperSD Auth key, and write PM Field 1 and 309
6 - if Certificate damaged Repair it by the press Recover Cert. Service-> PhoneTest-> Various-> BB5 Certificate
Validation (For Check Validation Cert)
Third method:
1 -
2 - Repair Simlock Service-> Imei & Security-> Simlock-> PA_SL2 -> Make Simlock RPL-> Repair Simlock
3 - Repair SuperDongle Service-> Imei & Security-> IMEI Rebuild-> Repair SD
4- Sx4 through SuperSD Auth key, and write PM Field 1 and 309
5 -
if Certificate damaged Repair it by the press Recover Cert. Service-> PhoneTest-> Various-> BB5 Certificate Validation (For Check Validation Cert)
6 - Full flash with N96 last version (4 files)
BR.
Y.P.Y
http://forum.**********.com/
The Following 15 Users Say Thank You to Y.P.Y For This Useful Post:
Old 03-07-2010, 21:42   #2 (permalink)
Crazy Poster
Member: 1242264
Thanks Meter: 10
thanksssssssssssssss
Old 07-07-2010, 23:59   #3 (permalink)
dannyogolo's Avatar
Member: 18200
Sonork: 100.1608286
Thanks Meter: 82
Pls where can I get this ENO file ? Link is dead and i cant google it elsewhere. The one I got is 6MB but this seems to be 2MB.
Pls reply asap
Old 07-08-2010, 00:25   #4 (permalink)
maher_asif's Avatar
Member: 330136
Thanks Meter: 37
flash with atf and work 100% ok
!!! [+] 100% solution - n96 restart on nokia logo [+] !!! Y.P.Y Nokia Base Band 5 ( BB-5 ) 21 07-29-2010 12:25
nokia 7610 restart on nokia logo noman shakir Nokia Hardware & Hardware Repair 4 02-24-2009 07:48
Nokia E90 only restarting on nokia logo...??? amanvir Nokia Hardware & Hardware Repair 0 01-11-2009 18:22
3230 Restarting on Nokia logo zmay119 Nokia Hardware & Hardware Repair 3 03-29-2007 13:02
Page generated in 0.26146 seconds with 8 queries
