Old 12-25-2010, 15:18   #1 (permalink)
Member: 717046
Thanks Meter: 237
Talking $$100% unlock SL3 HIER$$ and graphics card compare for unlock sl3
From this table it can be concluded that the higher performance graphics cards that deliver below $ 128 are GTS250 Nvidia and HD4770, 4850 and 5750, AMD / ATI. The machines used to make the test consisted of a Core i5 661, G6950 Intel Pentium, Intel Core 2 Quad Q9650 and AMD Phenom X4 965, the operating system was Windows 7 x64.
The Following User Says Thank You to nejm For This Useful Post:
Old 12-25-2010, 15:59   #2 (permalink)
Member: 886190
Sonork: 12345678
Thanks Meter: 30
System Information
Time of this report: 12/25/2010, 07:56:54
Machine name: HP11927201172
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_qfe.100216-2016)
Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
System Model: HP Compaq dx2200 MT
BIOS: Phoenix - Award BIOS v6.00PG
Processor: Intel(R) Pentium(R) 4 CPU 3.40GHz (2 CPUs)
Memory: 894MB RAM
Page File: 465MB used, 1700MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
my computer information . this is possible unlock sl3?
Old 12-25-2010, 16:16   #3 (permalink)
malektalha's Avatar
Member: 1062869
Thanks Meter: 80
OS Name Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 3 Build 2600
OS Manufacturer Microsoft Corporation
System Name AIR-9C0420737AC
System Manufacturer INTEL
System Model DG31PR
System Type X86-based PC
Processor x86 Family 6 Model 23 Stepping 6 GenuineIntel ~2666 Mhz
BIOS Version/Date Intel Corp. PRG3110H.86A.0065.2009.0421.1559, 4/21/2009
SMBIOS Version 2.4
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "5.1.2600.5512 (xpsp.080413-2111)"
User Name AIR-9C0420737AC\talha
Time Zone India Standard Time
Total Physical Memory 2,048.00 MB
Available Physical Memory 1.26 GB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.96 GB
Page File Space 3.84 GB
Page File C:\pagefile.sys
my computer information this is possible unlock sl3????????
Old 12-25-2010, 16:17   #4 (permalink)
Member: 886190
Sonork: 12345678
Thanks Meter: 30
System Information
Memory: 894MB RAM
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: ATI RADEON XPRESS 200 Series
Manufacturer: ATI Technologies Inc.
Chip type: ATI RADEON XPRESS 200 Series (0x5A61)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_5A61&SUBSYS_72541462&REV_00
Display Memory: 128.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6587 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 1/5/2006 03:47:00, 252928 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 1/5/2006 03:46:42, 1420288 bytes
Device Identifier: {D7B71EE2-1921-11CF-696E-5E52A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x5A61
SubSys ID: 0x72541462
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0862&SUBSYS_1462725A& REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.5283 (English)
WHQL Logo'd: Yes
Date and Size: 8/1/2006 13:07:02, 4356608 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Description: Realtek HD Audio Input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1002, 0x4375
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 22:08:44, 57600 bytes
| Driver: usbd.sys, 8/17/2001 13:03:02, 4736 bytes
+-+ USB Human Interface Device
| | Vendor/Product ID: 0x03F0, 0x0024
| | Matching Device ID: usb\class_03&subclass_01
| | Service: HidUsb
| | Driver: hidclass.sys, 8/3/2004 22:08:20, 36224 bytes
| | Driver: hidparse.sys, 8/3/2004 22:08:18, 24960 bytes
| | Driver: hid.dll, 2/28/2006 01:00:00, 20992 bytes
| | Driver: hidusb.sys, 8/17/2001 13:02:20, 9600 bytes
| +-+ HID Keyboard Device
| | | Matching Device ID: hid_device_system_keyboard
| | | Service: kbdhid
| | | Driver: kbdhid.sys, 8/3/2004 21:58:36, 14848 bytes
| | | Driver: kbdclass.sys, 8/3/2004 21:58:34, 24576 bytes
| | Vendor/Product ID: 0x062A, 0x0001
| | Service: HidUsb
| +-+ HID-compliant mouse
| | | Matching Device ID: hid_device_system_mouse
| | | Service: mouhid
| | | Driver: mouclass.sys, 2/28/2006 01:00:00, 23040 bytes
| | | Driver: mouhid.sys, 8/17/2001 12:48:00, 12160 bytes
Gameport Devices
PS/2 Devices
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 02:01:08, 40840 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: Standard Modem
DirectPlay8 Modem Service Provider: Agere Systems PCI-SV92PP Soft Modem
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM3
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 55.5 GB
Total Space: 152.6 GB
File System: NTFS
Model: SAMSUNG HD160JJ/P
Drive: D:
Model: LITE-ON DVDRW SHM-165H6S
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/3/2004 21:59:54, 49536 bytes
System Devices
Name: Agere Systems PCI-SV92PP Soft Modem
Device ID: PCI\VEN_11C1&DEV_0620&SUBSYS_062011C1&REV_00\4&FB7 5CB&0&00A4
Driver: C:\WINDOWS\system32\DRIVERS\AGRSM.sys, 2.01.0056.0001 (English), 9/23/2005 06:26:40, 1094751 bytes
Driver: C:\WINDOWS\agrsmdel.exe, 1.06.0009.0001 (English), 5/2/2005 05:10:52, 68096 bytes
Name: Realtek RTL8139/810x Family Fast Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_254C1462&REV_10\4&FB7 5CB&0&18A4
Driver: C:\WINDOWS\system32\DRIVERS\Rtnicxp.sys, 5.635.0923.2005 (English), 9/30/2005 05:11:42, 78720 bytes
Name: ATI RADEON XPRESS 200 Series
Device ID: PCI\VEN_1002&DEV_5A61&SUBSYS_72541462&REV_00\4&1C9 EB71F&0&2808
Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6587 (English), 1/5/2006 03:46:42, 1420288 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0005 (English), 1/5/2006 03:10:16, 40960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativvpxx.vp, 1/5/2006 05:04:26, 25552 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativckxx.vp, 6/8/2005 20:45:54, 58560 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.vp, 10/12/2005 17:05:10, 929 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.cpa, 10/12/2005 17:05:10, 1114674 bytes
Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6587 (English), 1/5/2006 03:47:00, 252928 bytes
Driver: C:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0303 (English), 1/5/2006 03:05:38, 237568 bytes
Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2495 (English), 1/5/2006 03:41:20, 26112 bytes
Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0362 (English), 1/5/2006 03:31:30, 2518176 bytes
Driver: C:\WINDOWS\system32\ativvaxx.dll, 6.14.0001.0079 (English), 1/5/2006 03:25:14, 862336 bytes
Driver: C:\WINDOWS\system32\atiicdxx.dat, 12/23/2005 00:44:30, 112425 bytes
Driver: C:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0007 (English), 1/5/2006 03:39:22, 53248 bytes
Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4200 (English), 1/5/2006 03:11:00, 17408 bytes
Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 16:01:04, 24064 bytes
Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4124 (English), 1/5/2006 03:39:48, 405504 bytes
Driver: C:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4124 (English), 1/5/2006 03:41:00, 61440 bytes
Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2495 (English), 1/5/2006 03:41:44, 110592 bytes
Driver: C:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2499 (English), 1/5/2006 03:41:12, 40960 bytes
Driver: C:\WINDOWS\system32\atikvmag.dll, 6.14.0010.0030 (English), 1/5/2006 03:11:40, 151552 bytes
Driver: C:\WINDOWS\system32\ATIDEMGR.dll, 1.02.2195.38461 (English), 1/5/2006 02:22:04, 258048 bytes
Driver: C:\WINDOWS\system32\atifglpf.xml, 11/28/2005 17:43:40, 6024 bytes
Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.5529 (English), 1/5/2006 03:01:36, 4968448 bytes
Driver: C:\WINDOWS\system32\atioglx1.dll, 6.14.0010.1030 (English), 1/5/2006 03:20:06, 6684672 bytes
Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4004 (English), 1/5/2006 05:19:00, 307200 bytes
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1002&DEV_5A3F&SUBSYS_00000000&REV_00\3&61A AA01&0&08
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 22:07:48, 68224 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1002&DEV_5A33&SUBSYS_00000000&REV_01\3&61A AA01&0&00
Driver: n/a
Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_1002&DEV_437B&SUBSYS_725A1462&REV_01\3&61A AA01&0&A2
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 1/7/2005 16:07:18, 138752 bytes
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_1002&DEV_4379&SUBSYS_72541462&REV_80\3&61A AA01&0&90
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 21:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 21:59:44, 95360 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 12:51:52, 3328 bytes
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1002&DEV_4377&SUBSYS_00000000&REV_80\3&61A AA01&0&A3
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 12:58:02, 35840 bytes
Name: ATI IDE Controller
Device ID: PCI\VEN_1002&DEV_4376&SUBSYS_72541462&REV_80\3&61A AA01&0&A1
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_1002&DEV_4375&SUBSYS_72541462&REV_80\3&61A AA01&0&99
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:38, 17024 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/3/2004 18:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 57600 bytes
Device ID: PCI\VEN_1002&DEV_4374&SUBSYS_72541462&REV_80\3&61A AA01&0&98
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_1002&DEV_4373&SUBSYS_72541462&REV_80\3&61A AA01&0&9A
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/3/2004 23:56:44, 7168 bytes
Device ID: PCI\VEN_1002&DEV_4372&SUBSYS_72541462&REV_82\3&61A AA01&0&A0
Driver: n/a
Device ID: PCI\VEN_1002&DEV_4371&SUBSYS_00000000&REV_80\3&61A AA01&0&A4
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/17/2001 12:53:22 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/17/2001 21:36:12 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/17/2001 21:34:02 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/17/2001 21:36:12 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/17/2001 21:36:12 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/17/2001 21:36:12 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/17/2001 21:36:14 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/17/2001 21:36:14 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:50 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:50 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:04 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:04 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:50 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/17/2001 21:36:14 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/17/2001 21:36:14 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/17/2001 21:36:14 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/17/2001 21:36:16 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 2/28/2006 01:00:00 35328 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 82432 bytes
system.dll: 1.01.4322.2463 English Final Retail 11/8/2010 03:07:10 1232896 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/17/2001 21:36:20 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/3/2004 23:56:44 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/3/2004 23:56:48 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:42 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/3/2004 23:56:44 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:58 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 20480 bytes
qasf.dll: 9.00.0000.3250 English Final Retail 8/3/2004 23:56:46 237568 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:46 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:46 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:46 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:46 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:26 733696 bytes
quartz.dll: 6.05.2600.3665 English Final Retail 2/5/2010 10:40:58 1291264 bytes
strmdll.dll: 4.01.0000.3938 English Final Retail 8/26/2009 00:16:37 247326 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/3/2004 23:56:58 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/3/2004 23:56:58 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/3/2004 23:56:44 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/3/2004 23:56:44 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/3/2004 23:56:44 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/3/2004 23:56:44 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/3/2004 23:56:44 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/3/2004 23:56:58 154624 bytes
mswebdvd.dll: 6.05.2600.3610 English Final Retail 8/5/2009 01:11:47 204800 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 16:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 16:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 16:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 2/28/2006 01:00:00 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 2/28/2006 01:00:00 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 30720 bytes
msyuv.dll: 5.03.2600.3649 English Final Retail 11/27/2009 09:33:35 17920 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:48 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
VP6 Decompressor,0x00800000,1,1,vp6dec.ax,6.04.0002.00 00
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.3665
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.3665
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.3250
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.3665
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.402 6.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.3665
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
RealVideo Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0 001.0001
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600. 2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3 665
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000. 4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.3665
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.3665
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.06.0000.0051
MPV Decoder Filter,0x40000002,1,1,Mpeg2DecFilter.ax,1.00.0000. 0003
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Sonic DVD-VR Navigator,0x00200000,0,2,SonicDVDDashVRNav.dll,1.0 2.0000.0107
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3665
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.3665
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250
FLV File Source,0x00200000,0,2,Flv.ax,2006.02.0028.0001
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.000 0
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.3665
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.32 50
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.3665
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3665
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.3665
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.3665
RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.00 01.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.3250
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000. 4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.000 0
RealAudio Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0 001.0001
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Sonic Cinemaster® MCE Audio Decoder,0x00710000,1,1,CinemasterAudio.DLL,2.05.00 04.1414
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AC3Filter,0x40000000,1,1,ac3filter.cpl,1.00.0001.0 000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.3665
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600 .2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2 180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.260 0.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3 665
Sonic Cinemaster (C) ATI SPDIF Adapter,0x00200000,1,1,CinemasterATISPDIF.dll,1.00 .0000.0019
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.3665
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.3665
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.3665
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.3665
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.3665
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.3665
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
Sonic Cinemaster® DS Video Decoder,0x00710000,2,1,CinemasterVideo.DLL,2.07.00 06.9083
RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00. 0001.0001
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
CyberLink QuickTime Source Filter,0x00200000,0,2,QuickTime.ax,1.00.0000.1016
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.3665
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.3665
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.3665
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Sonic Cinemaster® DS VCD Navigator,0x00200000,0,3,CinemasterVCDNav.dll,1.00 .0000.0177
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3 665
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.3665
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.366 5
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.3665
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3665
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3665
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.3665
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600 .3665
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.3665
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.3665
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.3665
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.3665
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.3665
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.3665
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.3665
Audio Capture Sources:
Realtek HD Audio Input,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.3665
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.3665
WDM Streaming Capture Devices:
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,,5.03.2600.2180
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.3665
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.3665
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.3665
DirectSound: Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.3665
WDM Streaming System Devices:
Realtek HD Audio Input,0x00200000,4,1,,5.03.2600.2180
Realtek HD Audio output,0x00200000,7,1,,5.03.2600.2180
Old 12-25-2010, 16:18   #5 (permalink)
ncoolsoft.'s Avatar
Member: 1458678
Thanks Meter: 381
No, I take many to receive the unlock code
Old 12-25-2010, 16:24   #6 (permalink)
*miguel05_gsm*'s Avatar
Member: 1453900
Thanks Meter: 68
Originally Posted by ronymirza View Post
System Information
Memory: 894MB RAM
i think u need to buy new computer to unlock sl3 phones...
waiting mode to be released unlocking sl3 phones this 2011 that no need to buy this expensive cpu's and fast unlocking........
Page generated in 0.43453 seconds with 7 queries
