Old 10-03-2010, 13:38   #1 (permalink)
Member: 801936
Thanks Meter: 37
1100 imie ?????????
ASIC ID: 0x2201 [UPP_2M ver: 2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20
Performing Flash Authentication ...OK
UEM ID: 00148365:2984DA60
ASIC type: 2
UEM Imei: 352726012505D3
Invalid uem checksum, UEM might be damaged !
[InternalErrorFault] IMEI/ESN (352726012505D3) contains non digit char, probably UEM damaged ! (case id=0xCB01)
Old 10-03-2010, 13:50   #2 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
Thanks Meter: 348
bro,
power on your phone and check,if your phone off 30se or 1min you mast change UEM.
Old 10-03-2010, 13:53   #3 (permalink)
uzmantel's Avatar
Member: 163458
Sonork: 100.1606694
Thanks Meter: 503
hi
1.open dct4
2.imei security
3.online logger
4.login
5.dct4 imei Select
5.do selected job
problem slove
not slove problem uem change write new rpl 100% ok
The Following 2 Users Say Thank You to uzmantel For This Useful Post:
Old 10-03-2010, 13:53   #4 (permalink)
Member: 1276771
Thanks Meter: 33
use server for repair of dct4 imei
[email protected]
Old 10-03-2010, 15:26   #5 (permalink)
Member: 392149
Thanks Meter: 199
It is UEM damage so change it and try again
Old 01-22-2011, 17:25   #6 (permalink)
Member: 1421888
Sonork: deenmobilelearner
6070 simlock data coreptet
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010)
ASIC ID: 0x3160 [UPP_8M ver: 6.0]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8
FlashID0: 0020 8804 [ST 58LR128U,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF
Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5718
UEM ID: 009E8457:2984DA60
ASIC type: 2
UEM Imei: 35700301927495
Flash Imei: 35765301927495
MasterCode: 3522473342
Invalid imei checksum !
Phone Type: RM-166 (Nokia 6070)
SW Version: V 04.23 26-10-07 RM-166 (c) Nokia.
Imei plain: ??????????????-?
Imei OTP: 35700301927495
Product Code: 0537282
Cellular System: GSM
ASIC ID: 0x3160, type: 2
Ppm Id: I
Language Pack:
English,Portuguese,Spanish,French
Imei plain is invalid !!!
Imei net: FFFFFFFFFFFFFF
Version: SIMLOCK SERVER VERSION 58
Counter: 0/3, 0/10
CONFIG_DATA: DA57637585A0798F
PROFILE_BITS: 12186AD57975BFC5
SIMLOCK_DATA corrupted!
plz help
Old 01-22-2011, 17:50   #7 (permalink)
Member: 1421888
ASIC ID: 0x1201 [UPP_2M ver: 1]
FlashID0: 0020 8823 [ST 58WR016FU,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF
Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x4C58
UEM ID: 00DF85E9:2984DA60
ASIC type: 2
UEM Imei: 35550485008056
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.5
RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35550485008056.RP L"
Programming FLASH Imei ...
FLASH programmed successfully.
Phone Type: RH-18
SW Version: V 8.11 19-06-06 RH-18 (c) NMP 1100
Imei plain: 35550485008056-7
Product Code: 0512370
ASIC ID: 0x1201, type: 2
Ppm Id: IC
thank you
After imie change no network 8850? xmans Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-18-2002 16:59
Is it possible to change imie on T20s mcrozz Old Ericsson Phones & Sony Phones 7 03-01-2002 07:07
Sagem Pb-IMIE? xmans Infineon C16X M51 & ARM7 M52 BASED 0 10-24-2001 01:59
a35 cer 20 IMIE kurdi99 x1x to x45/x50 1 08-12-2001 21:37
IMIE Unlock Nokia 9110 mrbmw Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 04-08-2000 13:07
Page generated in 0.18105 seconds with 9 queries
