12-07-2010, 17:12 | #1 (permalink) |
Banned Join Date: Dec 2004 Location: MX-KEY is the BEST NOKIA TOOL Age: 51
Member: 101683 Status: Offline Thanks Meter: 26 | 1110 imei ????????????4 (ANSWERED) i have 1110i imei ????????????4 , i do what i do every time in this phone but i get this error from servir , what is the problem ?? need help thankes to all ... this is log from phone Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00DB3187:2984DA60 ASIC type: 2 UEM Imei: Empty Flash Imei: 35806801735664 MasterCode: 0606434746 RPL saved to "C:\mobileEx\3.4\data\backup\_BACK.rpl" Phone Type: RH-93 SW Version: V 6.41 06-04-07 RH-93 (c) NMP Imei plain: ??????????????-? Cellular System: GSM ASIC ID: 0x21FF, type: 255 Ppm Id: IC Language Pack: English,Arabic,French,Swahili Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: 507A4A0DA3981139 PROFILE_BITS: 755A85DDA201C52A |
12-07-2010, 17:26 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hello, from the log, your phone is got new uem. you have to make a new rpl file according to it's asic version and digits on back cover. online logger > login > tick 'calculate manual'. fill desired imei, choose asic, press 'Request RPL' you will received it inside C:\mobileEx\3.4\data\backup\RPL proceed with write rpl by using those new file. BR |
The Following User Says Thank You to gbluez For This Useful Post: |
12-07-2010, 17:52 | #3 (permalink) |
Member: 101683 Status: Offline Thanks Meter: 26 | thankes for help but i do that befor and i get this ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00DB3187:2984DA60 ASIC type: 2 UEM Imei: Empty Flash Imei: 35806801735664 Verify UEM data ... ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00DB3187:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Programming UEM Imei (OTP) ... UEM programmed successfully.Phone Type: RH-93 SW Version: V 6.41 06-04-07 RH-93 (c) NMP Imei plain: ??????????????-? Product Code: 0532991 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: IC Language Pack: English,Arabic,French,Swahili Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: 507A4A0DA3981139 PROFILE_BITS: 755A85DDA201C52A |
12-07-2010, 18:23 | #4 (permalink) | |
Freak Poster Join Date: Dec 2009 Location: Raiganj Age: 37
Member: 1175794 Status: Offline Thanks Meter: 186 | Quote:
http://www.megaupload.com/?d=WXM3B0IA | |
12-09-2010, 18:52 | #9 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Karachi pakistan
Member: 1449003 Status: Offline Sonork: tariq (100.1603714) Thanks Meter: 38 | BOSS JUST DCT4...........you have team Viewer so [email protected] |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
