01-12-2011, 17:57 | #1 (permalink) |
Registered User Join Date: Oct 2010 Location: iran - mazandaran- shahi Age: 41
Member: 1422911 Status: Offline Sonork: i have done but i forget Thanks Meter: 35 | 1110 invalid sim Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C90B3F:2984DA60 ASIC type: 2 UEM Imei: 35291002677603 Flash Imei: 35895401795179 MasterCode: 2547726660 Invalid imei checksum ! Phone Type: RH-93 SW Version: V 7.02 10-12-07 RH-93 (c) NMP Imei plain: ??????????????-? Product Code: 0532991 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: IJ Language Pack: - not available. Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: 7DE00FCF8F836188 PROFILE_BITS: FCB995FB07012EB9 how can i solve this problem |
01-13-2011, 08:08 | #3 (permalink) |
Member: 1422911 Status: Offline Sonork: i have done but i forget Thanks Meter: 35 | i do this. its seems to be valid but power of after some time ASIC type: 2 UEM Imei: 35291002677603 Flash Imei: 35291002677603 MasterCode: 6425273731 RPL saved to "C:\mobileEx\3.4\data\backup\35291002677603_BACK.r pl" Phone Type: RH-93 SW Version: V 7.02 10-12-07 RH-93 (c) NMP Imei plain: 35291002677603-3 Product Code: 0532991 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: IJ Language Pack: - not available. Imei net: 35291002677603 Version: Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000010002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
01-13-2011, 08:31 | #4 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Hell..... Bcoz i am devil_king Age: 38
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | change network p.a. it is h/w problem |
The Following User Says Thank You to ..:: Devil_king ::.. For This Useful Post: |
01-13-2011, 10:58 | #5 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Now you do "Reset data1" Then full erase - Full flash - write PM - Write RPL By MX KEY online logger Sp unlock if required ... 100% result Post result | |
The Following User Says Thank You to srinibas For This Useful Post: |
01-13-2011, 22:03 | #8 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
The Following User Says Thank You to gbluez For This Useful Post: |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
