03-30-2013, 13:08 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: IRAN
Member: 828490 Status: Offline Thanks Meter: 229 | 1110 RH70 Change IMEI Problem. for change imei i have this problem. how solve this problem? thanx Performing Flash Authentication ...OK UEM ID: 00D9F2C1:2984DA60 ERROR: Packet Error(0xAA), code 0x4A000001 Trying to find patch position ... |
03-30-2013, 17:19 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Ignore the Version on above Image, Perform same operation of Patch IMEI on the Image, The only error in your Logs due to Bad Cable connectivity, So check or change Cable & Clean contact Terminals on PCB & Cable. BR, ZUBER | |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
