05-17-2013, 09:19 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: IRAN
Member: 828490 Status: Offline Thanks Meter: 229 | 1110i rh93 after change imei have signal only for 15 sec 1110i rh93 after change imei have signal only for 15 sec I wrote pm and erase phone but problem not solved. any body know the solution? |
05-17-2013, 10:33 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Can you explain why & how you change the IMEI, Run Selftest, click Initialise & post Logs, Post saved Logs of IMEI change Operation & mention the condition of Phone before & after. BR, ZUBE | |
05-17-2013, 10:43 | #5 (permalink) |
Member: 828490 Status: Offline Thanks Meter: 229 | I tried with all products and all firmware version. my problem is not just for this phone.i have this problem with all asics 2/5/6/7 I changed by method 2 because method 1 not work. Phone Type: SW version: ID Test name Startup Result 46 UEM_CBUS_IF Y passed 15 SLEEP_X_LOOP Y passed 3 EAR_DATA_LOOP Y passed 17 TX_IDP_LOOP Y !no signal 18 TX_IQ_DP_LOOP Y !no signal 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 39 WARRANTY Y passed 33 SIM_LOCK Y passed 10 PPM_VALIDITY Y passed 43 LCD Y passed 41 FLASH_CHECKSUM N !no signal 30 RF_CHIP_ID N passed |
05-17-2013, 11:13 | #7 (permalink) |
Member: 828490 Status: Offline Thanks Meter: 229 | MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C086AF68 Using device: HTI, FW ver: 00.50, SN: 0100AFF7 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 009022BA:2984DA60 ASIC type: 2 UEM Imei: 3589640xxxxxxx Flash Imei: 3589640xxxxxxx MasterCode: 7757472738 RPL saved to "C:\mobileEx\3.5\data\backup\35896401xxxxxx_BACK.r pl" Phone type: RH-93 SW version: V 6.40 12-01-07 RH-93 (c) NMP Imei plain: 355467010xxxxx-x Product code: 0525292 Cellular system: GSM ASIC ID: 0x2201, type: 2 Ppm Id: AD Language Pack: English,French,German,Turkish Master code: 1371570025 Imei net: 355467010xxxxx Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000010002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
05-17-2013, 11:50 | #8 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Try this PM attached, If not solve, then Check in Hardware & change PA Ic. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
