02-15-2010, 06:38 | #6 (permalink) |
No Life Poster Join Date: May 2006 Location: Gojra
Member: 279362 Status: Offline Sonork: 100.1594141 Thanks Meter: 500 | same problem with 1650 i trying write rpl see this log and help me ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 327E [AMD S29NS128P,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0057F703A3BDA66 ASIC type: 11 UEM Imei: 35205102235940 Connecting to server ...OK, Login ... Hello C0805726, you have 1990 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35205102235940.RP L" ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 327E [AMD S29NS128P,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0057F703A3BDA66 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RM-305 SW Version: V 5.91 27-03-09 RM-305 (c) NMP Imei plain: 35205102235940-7 Cellular System: GSM ASIC ID: 0x2292, type: 0 Ppm Id: IA Language Pack: - not available. Failed to read SP data |
The Following User Says Thank You to meeza_84 For This Useful Post: |
Patch 1112 Phone Shut off 30 second. | papoo | Universalbox | 9 | 04-25-2009 09:55 |
n90 restart after folding off & lcd led off | gsm_khorshed | Nokia Hardware & Hardware Repair | 2 | 11-16-2008 08:16 |
nokia 6600 hang and power-off after pincode off | rovick | Nokia Multimedia | 3 | 08-04-2008 12:23 |
nokia 7610 auto off after light off | mobiletomobile | Nokia Hardware & Hardware Repair | 3 | 12-10-2007 18:01 |
sl45 power off after lamp off | genocite | Siemens Hardware Repair Area | 10 | 05-08-2004 16:41 |
